BMWClub: Recomandare motor benzina e46 coupe - BMWClub
  • 2 Pages +
  • 1
  • 2
  • You cannot start a new topic
  • You cannot reply to this topic
Recomandare motor benzina e46 coupe fiabilitate/eficienta raport putere-consum/intretinere
Poll: Recomandare motor benzina e46 coupe
This is a public poll. Other members will be able to see which options you chose
cel mai bun motor pe benzina pentru e46 coupe
You cannot see the results of the poll until you have voted. Please login and cast your vote to see the results of this poll.
Vote Guests cannot vote
#1 User is offline   catacfc
  • Membru
  • Group: Members
  • Gender:Male
Posted 28 May 2013 - 13:50
Moda dieselurilor trece usor,multi realizeaza acum ca daca nu faci multi km pe an achizitia unui diesel nu mai este o idee asa buna.Am cautat dar nu am gasit multe informatii despre care este cel mai recomandat motor pe benzina pe e46 din punct de vedere al problemelor specifice,raport performanta/consum,si mai ales fiabilitate.Parerile pro si contra si mai ales argumentele sint binevenite.
0
#2 User is offline   .Bogdan
  • [ unknown ]
  • Group: Contributors
  • Gender:Male
Posted 28 May 2013 - 13:56
M52/M54.
2
#3 User is offline   Dan_316i
  • Securist
  • Gender:Male
  • Interests:BMW e36
Posted 28 May 2013 - 14:08
Variante de compromis
M52TUB25 e46 323
M54B25 e46 325
Sau compromisul perfect ;)
e46 320 cu un M54B30
This post has been edited by Dan_316i: 28 May 2013 - 14:28
0
#4 User is offline   alex230ro
  • Fan dependent
  • Group: Members
  • Gender:Male
Posted 28 May 2013 - 14:13
M54 -2.5 sau 3.0 daca iti permiti impozitul. daca nu sunt bani de impozit M52-2.0
1
#5 User is offline   1983
  • Începător
  • Group: Members
  • Gender:Male
Posted 28 May 2013 - 15:03
da de M43 1,9 benzina de pe e46 ce parere aveti?am eu si desta intreb :twitch: ,eu am auzit numai de bine de el
0
#6 User is offline   Nicoara Alex
  • Pasionat
  • Group: Members
  • Gender:Male
  • Interests:Sex, drugs and rock'n'roll
Posted 28 May 2013 - 16:28
Si eu sunt tare curios, fiind posesor sunt constient ca e cam puturos dar am auzit ca e fiabil. :-??
This post has been edited by Nicoara Alex: 28 May 2013 - 16:28
0
#7 User is offline   BC11CZY
  • Membru
  • Group: Members
  • Gender:Male
  • Interests:totul si nimic
Posted 28 May 2013 - 16:40
e cel mai putin fiabil dintre cele pe benzina m43-ul. Pentru mers pe oras e ok... mananca cam 11-13 depinde cum mergi. O sa pice ba una ba alta ... nu sunt piese scumpe dar la cea mai mica problema relantiul oscileaza... eu cel putin nu mi-as cumpara inca 1 data. As merge pe 2.5 sau 3.0.
0
#8 User is offline   1983
  • Începător
  • Group: Members
  • Gender:Male
Posted 28 May 2013 - 19:01
eu il am de circa 2 luni,nici o problema pana in prezent ,am luat masina de la un amic(deci o cunosc si tot ce sa facut la ea)de un an o are amicu asta al meu de la care am si luat-o si in afara de benzina si revizie nimic,cand a cumparat-o el era cu motoru desfacut si sa schimbat si tot in afara de pistoane si arbore ,aici ma refer la chiulasa facut tot ce trebuie ,de le acea interventie motoru a ramas cu o mica bataie la un piston adica de acum 1 an si merge fara probleme,probabil pe viitor o sa o rezolv ,el mi-a zis ca rezolvarea ca la carte ar fi un set de pistoane echipate (in jur de 2400 roni sau alt motor din SH)si atunci e practic motor nou,deci eu de M43 nu pot sa zic decat de bine masina are 192 000 la bord si sunt reali,si se comporta ff bine,ce am eu pe creier este acea bataie dar sper sa o rezolv pe viitor
This post has been edited by 1983: 28 May 2013 - 19:03
-1
#9 User is offline   B-490-RZV
  • El Diablo
  • Group: Members
  • Gender:Male
Posted 28 May 2013 - 19:12
Am avut 325ci un an jumatate, l-am luat cu vreo 100.000km, l-am dat cu vreo 115.000 (nu mai tin minte cifrele exacte). La motor nu a avut nici un fel de probleme si nici nu dadea semne ca ar urma. Problemele au fost la articulatie si la volant, in rest nimic deosebit. Si acum intorc capul dupa E46 coupe facelift in trafic, daca mai prind cate unul negru...:rolleyes:
Recomandarea mea ar fi 325ci, e un compromis ideal ca performanta/cheltuieli de intretinere. Dupa resoftare masina mea avea cca 210cp si 270nm :thumbsup:
This post has been edited by B-490-RZV: 28 May 2013 - 19:14
1
#10 User is offline   dragosel_bmw
  • Pasionat
  • Group: Members
  • Gender:Male
Posted 28 May 2013 - 19:50
iei un 320CI si ii pui motor de 3000 cmc
ai motor mare cu taxe de 2200 cmc
-2
#11 User is offline   1983
  • Începător
  • Group: Members
  • Gender:Male
Posted 28 May 2013 - 20:58
eu sunt la primul BMW deci nu am ce sa zic multe,asa ca stau deoparte si citesc de la voi :thumbsup:
0
#12 User is offline   DOMI
  • Fan dependent
  • Gender:Male
Posted 28 May 2013 - 21:00
daca faci multi km urbani cumpara unul 4L. adica 318Ci
alea 6L sunt misto dar urban sari de 14%
0
#13 User is offline   KIP
  • Group: Banned
  • Gender:Male
Posted 28 May 2013 - 21:11
In Bucuresti nu e departe de 14 nici 318ci !
0
#14 User is offline   DOMI
  • Fan dependent
  • Gender:Male
am zis ca sare..
e diferenta de la un 10 -11 la 14+..
1
#15 User is offline   KIP
  • Group: Banned
  • Gender:Male
Posted 28 May 2013 - 21:14
In jur de 13 ia. Ptr 2 litri in plus mai bine un 6L !
-1
#16 User is offline   Sly
  • primitiv
  • Group: Banned
  • Gender:Male
Posted 28 May 2013 - 21:18
2,5i in oras poate sari de 15 fara probleme
0
#17 User is offline   DOMI
  • Fan dependent
  • Gender:Male
Posted 28 May 2013 - 21:36
sau la mine 17 de exemplu :)
Bine in Bucuresti doar 15.. dar oricum..
totusi imi vine greu sa cred ca ajungi cu 318i la consumul ala.. multi cred ca merg fara sonde lambda sau cine stie ce probleme..
0
#18 User is offline   Mike88
  • Nou venit
  • Pip
  • Group: Members
Posted 30 May 2013 - 10:18
Posesor al unui 318CI 143cp,achizitionat anul trecut in iunie cu care am facut aproximativ 25 000 km fara sa schimb nimic decat consumabile...am codus prin oras dar cel mai mult pe autostrada cam 15 000km.Sunt foarte multumit de masina,consum aprox 10+ prin oras si 7 la drum intins...as fii preferat un 330CI dar cu asa consum si taxe nu prea are rost,pentru romania un 318/320CI e foarte bun datorita lipsei autostrazilor si a numarului mare de...gropi?...:))
0
#19 User is offline   ZyZ
  • Membru
  • Group: Banned
  • Gender:Male
Posted 30 May 2013 - 10:28
Dupa 5 ani de M52TUB20, iti recomand cu caldura ori M52, sau daca iti permiti M54. Sunt atat de multe diferente intre 6L si 4L incat ar trebui deschis un topic nou. Incepand cu fiabilitatea si terminand cu diferenta de cuplu si felul in care e echilibrat un 6L, diferenta de consum e prea mica pentru a o lua in considerare. Ai totusi in vedere ca E46 nu e o masina usoara si ai nevoie de ceva cuplu ca sa nu fie nevoie de fiecare data sa tragi de motor.
0
#20 User is offline   cristiansan7
  • Pasionat
  • Group: Members
  • Gender:Male
Posted 30 May 2013 - 10:32
Posesor de 318i 143 cp , ma declar super multumit ! Nu as cumpara niciodata o masina diesel decat daca as face mai mult de 25000 km pe an ! Plus ca intretinerea unui benzinar este mult mai ieftina !
This post has been edited by cristiansan7: 30 May 2013 - 10:38
1
Share this topic:
  • 2 Pages +
  • 1
  • 2
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
www.bmwclub.ro trafic.ro
