alexbacila
Everything posted by alexbacila
  1. Am gasit pe un forum ceva oare sa mearga? STEP 1: Connect to Your Car Plug the ENET cable into the OBD port (driver’s footwell). Plug the Ethernet end into your laptop. Turn ignition ON (do not start the engine). Launch E-Sys. Under “Connection”, choose: Target: F020 Interface: ENET Click Connect STEP 2: Read & Modify Vehicle Order (VO) In E-Sys, go to “Expert Mode” > “Coding” In the left panel, expand “FA”, right-click it and choose Read FA (VO). Expand FA > F020 (your car). Right-click SALAPA-Element → Click Edit In the VO list: Remove: $6VB (CID Mid) Add: $6VA (CID High) Click Save, then click the Disk icon to save the new FA file. STEP 3: Write VO to the Car In the FA tree, right-click F020, then click “Calculate FP” Go to “VCM” tab, click “Write FA” VO is now written into your car. STEP 4: Code HU_CIC Module Go to Coding → Read ECU list (Read ECU tree) Right-click on HU_CIC, click “Code” This will apply the new VO settings, including screen resolution.
  2. Salut,am un f31 cu hu_cic cu navigatie si ecran de 6,5 inch , as vrea sa pun un ecran de 8,8 fara sa trec pe nbt . Stie cineva daca este posibil? Ecranele sunt acelasi tip numai ca una este mid si una high, mersi
