mud
    E39
mud's Achievements
  1. I gave up after a few hours soldering. :twoup:. The hole was very small.
  2. Hi Gabriel! How do you know Point A and Point B will active the mirrors??. Is point B a P-Bus????
  3. Gabriel! I dismuonted the master door modul. I saw the hole which was very small. It was difficult to sold the wire A and B . Do you have any tips??Thank in advance.
  4. This is for E46 Hi Gabriel! This is 12 pin from the mirror. Pin #1 and Pin #2 for fold up and down. Is this like for A and B. Thank you A1_General_module_control_unit_e46.pdf WDS_BMW_Wiring_Diagram_Syst.._windows_switsch.pdf
  5. Thanks for info. I had sent a email to Blorax, but this topic from 2006. No respond from him. Do you know what the wire A and B call or signal? WDS_BMW_Wiring_Diagram_Syst.._09.pdf WDS_BMW_driver_door_am_Syst.._door_modul.pdf
  6. Hi Gabriel! Can I use this rectifier diode P600 50 V 6 A, P 600A https://www.elfaelektronikk.no/elfa3~no_no/...2&toc=18884? instead of this 1N4007 or 1N4004 diode. Thank you.
  7. Hi Gabriel! Thank you so much. Can I use the SPDT relay from a old BMW?? (picture in post #25), or I must buy a SPDT like you. I try to understand and want to trigger with alarm arm like this DIY for E46 post #24 http://forum.e46fanatics.com/showthread.ph...9444&page=2 In E46 they use to short Pin 2 and Pin 4. post #23 http://forum.e46fanatics.com/showthread.ph...1981&page=2 Instead Pin 2 and Pin4 I use A and B form your schema and PAC-Tr7 http://cgi.ebay.com/PAC-TR-7-TR7-Alpine-Vi...=item2c5a138bc8 to koble to GM. Do you have any comments for this methode? Do you have a close picture of A and B in the master door modu? Thanks so much. Regards Brian
  8. Hi! Google traduce. Vã mulÞumim pentru DIY foarte frumos. Am de gând sã facã la fel ca dumneavoastrã. scurtcircuitarea punctul A si punctul B va activa oglinzi, este corect??. Pot folosi acest releu? care este vechi de la BMW. Ai avea o imagine aproape de A ºi B, care sudurã În Întrerupãtorului principal bord. Thank You Hi! Google traduce. Pot folosi place cã pinul 2 = A ºi B = 4 pin???la alarma
