BogdanCristian
    320D
BogdanCristian's Achievements
  1. AU FOST VERIFICATE - NU SA GASIT NIMIC. AZI AU RESOFTAT SI CICA NU MAI FACE. ORICUM CRED CA O SA MA PREGATESC SI CU O RECLAMATIE. IDEEA ESTE CA NU STIU CE ARE SAU CE A AVUT MASINA.
  2. Multumesc pentru sfaturi - cred ca o sa inebunesc cu chestia asta. mi-au bagat pe gat debitmetru ala de motorina si acum trebuie sa revin. Asta se numeste INSELACINE, am dat bani pe ceva care nu ma ajuta deloc, masina este la fel.. SA INTELEG CA TU AI AVUT ACEIASI PROBLEMA ??? CAND PORNEAI MASINA DUPA 12 - 24 ore - la prima cheie tremura timp de 5-10 minutte ??
  3. SURPRIZA - AZI CAND AM PORNIT MASINA - FACEA LA FEL - DECI ASTIA DE LA BAVARIA AU SCHIMBAT ALA DEGEABA. MA DUC IAR LA EI - FAC SI UN EMAIL CATRE GERMANIA
  4. SAl - dar nu debitmetru cel exterior (cel obisnuit) - este altul - legat de fluxul de motorina etc - maine intru in posesia hartiei oficiale si revin cu denumirea oficiala, se da admisia jos ca sa se poata schimba etc
  5. GATAAAAAAAAAAAA !!!!!!!!!! SA REZOLVAT - MAINE RIDIC MASINA PROBLEMA >>>> UN DEBITMETRU - CARE REGLEAZA MOTORINA AM RASPUNS - CA SA NU MAI REPROSATI ;P ( unii dintre voi)
  6. MASINA ESTE IN SERVICE - E LASATA DE SEARA CA SA SE VADA MAINE LA PORNIRE PROBLEMA. REVIN CU UN RASPUNS IN 48 ORE.
  7. SALUTARE !! SCUZE CA NU AM RASPUNS PE FORUM - DAR AZI MI-AM REPARAT LAPTOPUL, AVEAM O GRAMADA DE SALVAT INCLUSIV RECOVER LA PASWORD REFERITOR LA MASINA E CA DR**U. TOT ASA ESTE MASINA - ,, TREMURA LA PORNIRE CAND E RECE" IN MERS CAND O ACCELEREZI USOR INDIFERENT DE TREAPTA IN CARE TE AFLI SACADEAZA - SAU ZICI CA SE INEACA. TREBUIA SA AJUNG LA BAVARIA - DAR PERSOANA CARE O CUNOSC DIN INTERIOR MI-A SPUS CA ELECTRICIANUL SEF NU ESTE PE ACOLO - SARBATORI BLA BLA BLA. DEJA MA SATUR SI DE ASTIA, DAR CRED CA O SA AJUNG ZILELE ASTEA - O SA O LAS DE SEARA CA SA POATA ASTIA SA PUNA TESTERUL DIMINEATA PE EA SA VADA TREMURATUL, CA DACA SE MERGE CU MASINA 5 KM nu mai tremura asa rau, nu se simte. UN PRIETEN MI-A RECOMANDAT SA SCHIMB DEBITMETRUL - PROBLEMA ESTE CA NU AM EROARE IN BORD - DAR IAR POVESTI. IN CAZUL IN CARE ,,SPECIALISTII" DE LA BAVARIA NU REUSESC SA-I GASEASCA BUBA - O SA MA DUC UNDEVA PE LA FILARET - AM AUZIT CA E UN SERVICE BUN PE ACOLO,. VA TIN LA CURENT - SI SCUZE CA NU AM RASPUNS - DAR SARBATORILE SI PROBLEMA CU LAPTOPUL - DREPT DOVADA VA SCRIU ASA DE TARZIU ( LA ACEASTA ORA )
  8. O SA FAC SIGUR UN TEST LA MOTOR - E MAI BINE - DECAT SA ARUNC CU BANII PE DIVERSE PIESE.
  9. INCEARCA IN BUCURESTI LA AUTOGLAS: Cal. Serban Voda Nr. 231A sect. 4, Bucuresti eu mi-am reparat un parbriz la ei la bmw 320d (e90)
  10. SA ZICEM CA ARE CU 2 CAI IN PLUS, DAR SA STII CA TOT NU AM REZOLVAT PROBLEMA, AM FOST AZI PANA LA PLOIESTI SI I_AM DAT PE DN1. ARE PUTERE SE DUCE, DAR DIN CAND IN CAND ZICI CA SE INEACA - MERGE IN RELUARE FRACTIUNE DE 1-3 SECUNDE. IAR ZIUA CAND O PORNESC SE SCARPINA DE PURICI LA RELANTY - TREMURA - DUPA CE MERG CU EA ISI REVINE - DE EXEMPLU LA SEMAFOR (DUPA CE MERG CU EA 1Km,) e ok relantiul IN FINE MA DUC LA O DIAGNOZA MOTOR. CA VAD CA NU MA AJUTAT SCHIMBURILE (ULEI+FILTRE) si EGR. TOT CE POT SA SPUN ESTE CA CURATAREA EGR ESTE BUNA, se simte ceva.
  11. REVIN - AM SCHIMBAT FILTRELE / ULEI - AM CURATAT SI EGR ( ERA VARZA IN INTERIOR) MOMENTAN MASINA ESTE OK. NU VAD SA MAI AIBA PROBLEME. MULTUMESC END TOPIC
  12. Merci, am vb cu el si mi-a confirmat si el ca se rezolva rapid , Saptamana care vine ma duc la el pentru tratament sper sa remediez aceasta mica problema multam
  13. masina mea are 163 CP - o sa curat si EGR - problema este ca nu o sa fac revizia la reprezentanta, o sa o fac la cineva care lucreza cu bmw. Ma gandesc daca poate sa curete EGR fara aparatura de ultima generatie O sa tin cont de sfaturile tale.
  14. Pai te anunt daca reusesc sa gasesc problema. In cateva zile o sa fac schimburile si dupa aceea vad cum se comporta. Daca persista problema ma duc pana la Bavaria la un TEST MOTOR.
  15. Peste 5 zile ma duc sa schimb toate filtrele (ulei+motorina+aer+polen). Pe urma vedem - Uleiul si filtrele le schimb mereu la 10.000 - 11.0000 km./ asa mi-a spus cineva de la Bavaria ca este bine. daca este ok - DAU BEREA
