da_pgeo
Everything posted by da_pgeo
  1. am schimbat si eu la seria 1 cu MHS-ul. devizul a fost 2300 lei. s-a inlocuit si senzorul de aburire. au facut treaba buna in sensul ca nu am observat nimic ciudat, decat un parbriz nou. s-au purtat frumos, m-au sunat cand a fost gata sa o ridic.
  2. uite ca au aparut si oglinzi de vanzare http://www.bmwclub.ro/forums/index.php?showtopic=41593
  3. am patit-o si eu de doua ori pe anul asta. zona cismigiu. eu am asigurare la omniasig. am fost si am deschis dosarul de dauna. apoi direct la Automobile Bavaria. Am cumparat geamul de oglinda, l-am infipt la locul lui, m-am intors la Omniasig unde am lasat factura de la bavaria si numarul meu de cont. Intr-o saptamana am gasit banii pe card (vreo 357 ron parca - oglinda stanga seria 1).
  4. Imi aparea pe bord notificare ca trebuie sa schimb bujiile. Am facut schimbul la un service oarecare si nu au stiut sa imi reseteze si calculatorul. Asa ca am cautat pe net si mi-am resetat singur. Merge pentru toate chestiile din service info(filtre, placute,etc.) Cam astia ar fi pasii: Step 1 Insert key into slot Step 2 Press start/stop button without depressing clutch/brake and wait for the service reminder to dissapear. Step 3 Immediately after service reminder goes out, press and hold the odometer reset. After 3 secs a warning triangle will appear, keep the odo. button pressed and after another 2-3 secs the Oil can will appear. I f you hold it too long (10 secs in total) you will overshoot the runway and some German writing will appear giving the software level/ can bus etc. of the car. Go back to the beginning and start again. Step 4 You are now in the service menu, use the toggle switch on indicator stalk to scroll up/down through the various service items. Step 5 When you have the item you want to reset showing, press the BC button on end of indicator stalk. Reset should now appear in the display. Press in and hold the BC button for 2-3 secs and a clock will start whirling around and hey presto, its done Step 6 You can now either scroll up/down to select another item (as in step 4) or you can press the start/stop button to exit.
