M coupe Digi-Tec Tuning la superlativ
m_fan
Atat masina cat si tuningul la care a fost supusa mi se par incredibile.
Trebuie sa recunosc ca pt mine este tuningul absolut.
In viziunea mea o masina sport trebuie sa aiba putere mare si cuplu mare la turatie mare.
Desi la inceput imi suradea ideea supraalimentarii motorului acum nu mai sunt de aceeasi parere.
Bineinteles ca este o parere personala si de aceea astept comentariile voastre.
Masina este dupa cum vedeti un m coupe care dupa o cura de slabire drastica a ajuns la 1200kg (capota, aripile, usile si barile sunt din carbon)
Am extras dupa site-ul firmei vinovate de cele suferite de masina (www.digi-tec.de) cateva detalii tehnice pe care, in cazul in care nu la-ti vizitat, vreau sa vi le impartasesc:
- Gr. A piston with titanium piston rod
- changed cam shafts with valve springs
- new programming of the Vanos (cam shaft adjustment)
- cylinder head easily revises
- new programming for the engine expensive equipment
- no air mass measurer, open alpha N programming
- carbon fiber air collecting tank with changed air circulation
- rotor 70% facilitates, all mobile parts fine-heaved
- 2 disks sinter metal clutch 180mm
- oil household and return revises
- high-grade steel exhaust system with 100 cells sport catalysts
- rear axle ratio and rear axle suspension changed
- rear axle cooling with electrical pump
- body at the shock strut cathedrals strengthens
- ueberrollkaefig - adjustable chassis with university ball joints
- adjustable cathedral camp
- BBS Magnesium Motorsport Wheels 8,5 und 10,5x18
- 245/35 ZR18, 285/35 ZR18
- 400PS bei 8500 U/min :blink: , Ăźber 400Nm bei 4000-6500 U/min
- 0-100 Km/h in ca. 4 sec
- V-max.: bis 290 Km/h
Era sa uit!
Ceva poze:
-http://www.digi-tec.de/de/pressestimmen/detail_new.php?id=13&show=13_1.jpg
-http://www.digi-tec.de/de/pressestimmen/detail_new.php?id=15&show=15_1.jpg
-http://www.digi-tec.de/de/pressestimmen/detail_new.php?id=18&show=18_1.jpg
-http://www.digi-tec.de/de/pressestimmen/detail_new.php?id=42&show=42_1.jpg
Apropo de M Coupe-ul Digi-Tec prezentat mai sus de m_fan... seamana foarte mult cu masinuta lui personala doar ca el e mai timid si ne ascunde ce masina are  :blink:
14266[/snapback]
Cred ca asa ar fi trebuit!
Si poate am sa o si fac dar cand vor mai aparea mai multi pasionati de ///M cu care sa poti sa stai de vb in aceasta sectiune.
Noi doi ne stim foarte bine masinile si am vorbit mult despre ele in discutii particulare, si o sa continuam sa vorbim si poate intr-o buna zii si aici pe acest forum!
Pana atunci, la mai mare!!! :)
P.S. putere!!!
puteai si doar sa editezi postul anterior... dai edit in dreapta jos  :blink:
ce faci omule... intri pe net tocmai din partea ailalta de tara? sau te-ai intors p'acasa? ai rezolvat cu bara aia? ai mai pornit M-ul? cum se mai aude ?  :)
14265[/snapback]
Ce sa fac? Intru si eu cand pot si de unde pot :)
L-am pornit bineinteles si sa stii chiar mi-a placut cum se aude :)
Cu bara n-am apucat nici macar s-o comand, dar am aranjat-o p-aia, nu e asa grav si s-ar putea sa nu trebuiasca inlocuita.
Ma intorc vineri noapte si poate ne vedem sambata sa dam o tura.
A, era sa uit, ai vazut ce sistem de racire au scos aia Eurobahn?
Ce parere ai?
