Martor motor aprins
Am un BMW X1 E84, 18d, 09.2011 motor N47, automata. Masina are acum 150.000 km.
Ieri dupa ce am plecat cu masina, dupa aprox 200m, s-a oprit in mers si s-a aprins martorul de motor in bord de culoare galbena.
Am pornit din nou motorul si daca acceleram in modul D nu inainta masina. Am trecut-o in mod manual si a plecat masina. Motorul merge cursiv, nu am observat vreo diferenta fata de cum merge inainte.
Dupa 1-2 km am parcat masina. Dupa aprox 30 min am pornit-o din nou si nu mai era aprins martorul de motor si acum merge in mod automat (R si D).
I-am facut o diagnoza a doua zi si apareau urmatoarele erori, poate unele sunt mai vechi si nu stiu care ar putea sa fie corelata problema avuta:
Engine / Motor
Fault Code: 0040E9
Fault Explanation: Abgasrueckfuehrsteller, position control
Fault Code: 003FF0
Fault Explanation: Air flow sensor
Fault Code: 004B81
Fault Explanation: Abgasrueckfuehrraten control, control deviatio
Dynamische Stabilitaets Kontrolle / DSC
Fault Code: 005F12
Fault Explanation: :Lining Wear: Front wear limit reaches --- (DSC:
brake lining wear Front brake pads) / Lining Wear: wear limit Front
achieved. / Lining Wear: wear limit reaches Front / EMCD Error: Supply
voltage fault / CAN message error EMF / Coding error: EEPROM
Configuration: ACB: Hydraul brake assistant value in EEPROM invalid.
/ Lining Wear error: Front wear limit reached
Instrument cluster / Kombiinstrument
Fault Code: 00A559
Fault Explanation: :Klemme30g f shutdown / KL30g f shutdown /
KL.30g f shutdown / KL30g f Cutoff
Air conditioning / Klimaanlage
Fault Code: 009C53
Fault Explanation: :EH (LIN) / PTC Heaters / PTC (LIN) / Rear air valve
engine center console left motor address 1Chex / Motor stratification
rear left / reserve 2
Phone / Telefon
Fault Code: 00D690
Fault Explanation: :Ring break diagnosis was performed (Error ring
diagnosis). / TCU: ring break diagnosis was performed (Error ring
diagnosis) / MOST: ring break
Fault Code: 00A8F9
Fault Explanation: :Software Reset: Reset monitoring circuit has
tripped
Car Communication Computer CCC
Fault Code: 00E1CD
Fault Explanation: :Total ring could not be started (Error WakeUp
Failed). / Awakening device has three times unsuccessfully, the
network tries to awaken (Error WakeUp Failed)
Fault Code: 00E1CF
Fault Explanation: :Central Registry does not match the target
configuration (Error Registry New) / The central registry is incorrect
(Error Registry New). / 0xE1CF: COMBINATION transmitter failure
Raportul de diagnoza complet e aici: https://drive.google.com/open?id=1x0A6-yjnZue3UYsGei4f-SLBDu-77iSo
Am resetat toate erorile si am mers cu masina o perioada dupa care i-am facut din nou diagnoza si nu mai apare nicio eroare.
Cat de mult ar trebui sa ma ingrijorez? Pot sa plec la drum mai lung cu ea?
Va multumesc de sfaturi.
Edited by ffr
Ai avut o garla de erori pe ea.. in cel mai bun caz posibil ai patit ceva la baterie atunci..
Anul trecut in ianuarie am schimbat discuri frana fata/spate si placute frana fata/spate la reprezentanta (e posibil sa nu imi fi sters erorile legate de frana).
Anul trecut in mai am facut revizia (ulei, filtre aer si filtru motorina) tot la reprezentanta, iar resetarea valorilor pentru urmatoarea revizia a facut-o dupa ce le-am zis.
Anul acesta in ianuarie primeam la fiecare pornire ca e bateria slaba si am schimbat-o. Cel care a schimbat bateria a facut initializarea ca e baterie noua, nu a sters erori.
Cred ca multe erori sunt vechi, dar nu stiu daca vreuna din ele e legata de faptul ca s-a oprit masina si a aparut martorul de motor.
E posibil sa fi fost ceva mizerie in motorina si dupa ce a evacuat-o sa nu mai apara martorul de motor?
Am vazut ca martorul de motor poate sa apara din mai multe cauze. Ex: nu inchizi bine busonul la rezervor, pana la probleme serioase ex: span in pompa de inalte.
Edited by ffr
