Anyone using a portable inflator on their BMW instead of the factory kit?
Featured Replies
I drive a 3 Series with runflats and the factory compressor in the trunk is slow and the gauge is hard to trust. I'm thinking about a small handheld inflator to keep in the car, mostly for topping up pressures at home before a trip and for the occasional slow leak. The car calls for fairly precise pressures and I don't want something that overshoots or reads a couple of psi off, since that throws off the TPMS. I also wonder how these cope with the 12V socket versus a battery unit, and whether the hose and chuck fit the valve stems without an adapter. If you've used a portable inflator on your BMW, how accurate has it been against a proper gauge, and does it hold up over repeated use?
Recently Browsing 0
