salut,
am si eu o problema si sper sa ma ajute cineva..
am pus masina la service pentru ca sa schimb supensiile, si a ramas masina la ei 6 zile :) , si dupa aceea am vrut sa iau masina de acolo dar a murit bateria, si cheia era in contact tot timpul.. si acuma nu mai merge telecomanda de la cheie !!!! stie cineva care e problema sau o solutie..
multumesc anticipat
cauta ca era pe undeva un topic despre reinitializare cheie, nu mai stiu unde
merci man, am resolvato,dar nu merge decat pentru o cheie
Remote Key Re-Initialise - If a key fails to operate remotely, it will have to be re-initialised (all keys in sequence at the same time)
- Get in and “close all doors”
- Turn ignition on & off quickly (no more than 5 seconds) to start the process. Next action must take place within 30 seconds
- First key - hold down button #2 (unlock) while striking button #1 (lock) three times. Release button #2. Confirmed by door lock operation.
- Repeat for second key within 30 seconds of first.
- After last key then cycle the ignition on/off to finalise the process (not necessary to start the engine.
Both keys should now have new "randomly selected" security "code words" - asigned by the car's system.
Those codes will be continuously incremented within the new sequence each time you hit a button. It is when they get out of sequence with the car that they loose the capability to be recognised and you then have to do this again.
That occurs when you take longer than 1 minute changing the battery, or if you hit buttons more often the 1000 times when it is out of range of the car.
__________________
UPDATE:
If you place a new transmitter into service
(either a replacement or an additional
transmitter), it must be initialized:
1 Enter the vehicle and close the doors.
2 Turn the ignition key briefly (max.
5 seconds) to position 1 in the steering
lock and then turn it back to position
0. Remove the key.
3 Press button 1 (refer to the illustration)
and hold it. Maintain pressure on
button 1 while rapidly pressing button
2 three times in succession within a
period of 10 seconds.
463de028
4 Release button 1.
5 The central locking system activates
and releases all lock mechanisms in
rapid succession to indicate that the
initialization procedure has been successfully
completed.
If the central locking system does not
react, you must repeat the initialization
procedure.
If you possess additional transmitters
for your vehicle (up to a maximum of
four units), you must now initialize these
as well. Be sure that no more than
30 seconds is allowed to elapse between
the individual initialization procedures.
Repeat steps 3 and 4 for each of
the transmitters when doing this. The
central locking system will confirm every
initialization procedure as described in
step 5.
In the event of a system malfunction,
please contact your BMW center. You
can also obtain replacement transmitters
here
