[Vand] Pachet piese - Noi - mecanica, telescoape, etc. BMW E46 / E36
Salut.Poti sa-mi dai si mie niste preturi pentru brate fata stg+dr, bucsi bascula , bielete directie si caseta directie pentru bmw 320d e46 136cp nfl din 2000 ? CA62521
  • Replies 406
  • Views 94.9k
Imi puteti furniza un pret la urmatoarele piese?
1) un set de bascule MEYLE HD cu tot cu bucse pentru bascule si eventual defalcat si pe componente
2) amortizor fata SACHS - suspensie standard, pe gaz
3) set discuri de frana + set placute, fara senzori - doar TEXTAR, ZIMMERMANN (coat z) - dimensiune disc fata 300, spate 286,294, pe ambele punti discuri ventilate interior
pentru un 320D 2002, 110 KW.
Edited by Clau D.
Salutare,
vataselu_bogdan
BRATE STANGA +DREAPTA
- 370 RON / BUCATA- FORTUNALINE POLONIA- CALITATE OK GARANTIE 1 AN
- 430 RON/ BUCATA- TALOSA -SPANIA - FOARTE FOARTE REZISTENTE- GARANTIE 1 AN
- 400 RON/ BUCATA- VAICO GERMANIA- GARANTIE 1 AN
BUCSI BRATE
- 115 RON / BUCATA - FLENNER GERMANIA- GARANTIE 1 AN
- 150 RON/BUCATA - FEBI BILSTEIN- GARANTIE 1 AN
- 200 RON / SET- ATP GERMANIA- GARANTIE 1 AN
-530 RON - Brat Stanga cu bucsa – SWAG –Germany-garantie 1 an -pe stoc
-530 RON - Brat dreapta cu bucsa - SWAG – Germany- garantie 1 an - pe stoc
bielete directe
- 105 RON / BUCATA- lemforder- stoc- GARANTIE 1 AN
- 75 RON/BUCATA- RTS – STOC- GARANTIE 1 AN
CASETA DIRECTIE
2300 RON- MARCA SPIDAN GERMANY- SUSPENSIE SPORT
Operating Mode HydraulicFor steering gear manufacturer ZFSuspension For vehicles with sports suspension
2200 RON - MARCA SPIDAN-GERMANY - SUSPENSIE STANDARD
NameValueOperating Mode HydraulicHeating / Cooling For vehicles with oil coolerFor steering gear manufacturer TRW & ZF
CASETA DE DIRECTIE SH ORIGINALA BMW +BIELETE DIRECTIE SI CAPETE BARA - CU GARANTIE 3 LUNI: 250 EUR
CLAU D.
- Amortizor fata sachs: 370 RON/buc stoc- standard gaz
- disc frana fata textar: 210 ron/buc term livrare 1 zi
- disc fr spate textar: 210 ron/buc term livrare 1 zi
- placute frana fata textar: 190 ron stoc
- placute fr spate textar : 170 ron term livr 1 zi
NU COMERCIALIZEZ MAYLE SAU MAYLE HD- DATORITA UNUI INCIDENT NEPLACUT CU ACEASTA MARCA
POT SA OFER CA SI MAI SUS:
BUCSI BRATE
MULTUMESC
RADU
0724223552
0751897607
Edited by evlmaster
SALUT ,un pret pt 2 arcuri spate 318ci e46 WBABL31040JP55966
Salut Radu , imi dai si mie un pret pt amortizoare fata - spate , kit protectie amortizoare fata -spate, flanse fata-spate, ce marca recomanzi tu.si in cat timp poti trimite piesele? Masina e Bmw 320D an 2000 . Mersi
Salutare,
lorand81
- arcuri spate - LEJFORDS- KME KME 4208431- SUEDIA - GARANTIE 2 AI- 230 RON/ BUCATA
Adryan 89:
- amortiazoare fata- disponibile ATP: pretz pachet 550 ron
- amortizoare spate : disponibil AL-KO germany: 300 ron
- flanse amortizoare FATA: SCAHS: 110 RON /BUC
- flanse amortiaoare SPATE SACHS: 85 RON / BUC
- kit-uri amortizoare SACHS: FATA 95 RON/ SPATE 90 RON
Anunta-ma telefonic cum procedam cu comanda, stiu ca ai mai comandat de la mine piese, o sa calculam si un discount pentru total comanda
Merci
Radu
0724223552
0751897607
UP CU MARFA DE CALITATE !!!!!!
SE FAC REDUCERI MASIVE PENTRU PACHETE MECANICA, ARCURI, AMORTIZOARE SI SISTEME DE FRANARE!!!
Buna ziua pt un 320d e46 WBAAS71080CH12129 urmatoarele
bielete directie fata , capete bara fata , flanse amortizoare fata cu tot cu rulment , bucse bara stabilizatoare fata ,amortizoare spate ,filtru aer , polen carbon , ulei ,motorina , filtru epurator , bujie incandescenta beru , ulei cutie viteze si diferential .
Daca se poate oferte de la mai multi producatori , multumesc !
Salutare Razvanee,
Am ceva probleme cu netul, incercam sa ne updatam cu fibra optica:
bielete directie fata LEMFORDER -- 85 ron DEPLHI -- 75 ron +
capete bara fata - AM - variante --- LMEFORFDER -- 110 ron MOOG -- 72 ron
-flanse amortizoare fata cu tot cu rulment - variante --BOGE --95 ron/1buc- Boge si sachs au montat pe original
-bucse bara stabilizatoare fata - variante /oe -- OE -- 55 ron/buc
-amortizoare spate - variante -- BOGE -- 175 ron /1buc, al-ko germany- 310 ron/ SET
- filtru aer MANN -- 75 RON/ FILTRON --65 RON , polen carbon MANN -- 81 RON , FILTRU ulei MANN -- 34 RON ,motorina MANN -- 95 RON/ KNECT-85 RON
- filtru epurator VAICO -- 130 RON OE -- 145 ron
- bujie incandescenta BERU-- 45 RON
- ulei cutie viteze CASTROL 75W90 1L -- 52 RON si diferential CASTROL 75W140 -- 52 RON
varianta 2:
- bielete directie fata + capete bara fata , .....2x205 Swag germany
-flanse amortizoare fata cu tot cu rulment , .....2x 115 ron sachs
- bujie incandescenta NGK........60 ron
Merc,
RADU
0724223552
0751897607
Salut!
JN27945. Ma intereseaza sondele lambda, amandoua, preturi separate pentru fiecare in parte (dinainte si dupa catalizator).
As prefera o oferta pe Bosch si alta oferta pe ce mai recomanzi tu
Salutare,
Cosmin,
cea mai buna varianta pentru motorul tau ( aceleasi sonde am si eu montate pe masina mea) , raport pret calitate:
SONDE LAMDA NGK-NTK(TECHNICAL CERAMICS)
- SONDA LAMDA FATA: COD- OZA447-E28- 350RON
- SONDALAMDA SPATE COD: OZA660-EE5 - 350 RON
DISPONIBILE PE STOC, PRET CU DISCOUNT (AMANDOUA FATA +SPATE) PENTRU UTILIZATORII FORUMULUI: 670 RON
Bartol,
Pentru 320 i - E36 au fost montate mai multe modele de telescoape, te rog da-mi o serie de sasiu pentru a face oferta corecta- original/ after market
multumesc anticipat pentru interes,
Radu
0724223552
0751897607
Salut un debitmetru pt. un 318 i,din 2000, 105 Cp, E 46.
multumesc
Da - disponibil pe stoc marca ECD Germany- 300 ron
sau ATP/ ATEC germany- 300 ron
"Bartol,
multumesc anticipat pentru interes"
Serie sasiu WBABF11030JA1065
sal ma intereseaza niste amortizoare fata pentru e46 VIN JN24655 +kit protector.ms
Pentru JM40816, suspensie M-tech poti aduce?
Doua brate fata pentru un 316i din 03.95 gasesc la tine ?
Salutare DEST ,
mai am un pachet mecanica fata de E36 pe stoc:
- brate fata - stanga+ dreapta-
- bielete antiruliu fata -stanga +dreapta
- bielete directie+capete de bara stanga +dreapta
PRET PROMO: 700 RON ....CE ZICI E OK?
RESTUL O SA RASPUND IN SEARA ASTA, AM FOST AGLOMERATI CU FOARTE MULT COMENZI- MULTUMIM PENTRU INTELEGERE
rADU
  • 5 weeks later...
back ...cu stoc nou preturi imbatabile la mecanica si sisteme franare!!!!
Radu
0724223552
0751897607
sal Radu. bascule fata bmw e36 touring an 1997 318i. complecte. Ms.
salut, piesa cu tepi mai ai pentru e46? ce pret? merci.
SAlutare,
spune-mi ce model ai, motorizare, eventual o serie de sasiu, exista diferente de tensiune la aceste piese in functie de model.
merci
Radu
evlmaster, vezi postul meu mai sus :rolleyes:
SAlutare,
merci
Radu
320d e46 facelift 150cp cu clima digitala - an 2002
Edited by Gelu 320d
