probleme cu cheia nu o mai recunoaste
Featured Replies
salut am si eu o problema cu cheiala bmw e46 318 din 98 nu o mai citeste nu porneste masina si pe deasupra mai si porneste alarma.usile se deschid si alarma se armeaza dar masina nu mai porneste.ciudat este ca nici cheia de rezerva nu mai merge,si toate astea din senin asa in parcare,nu a mai vrut sa porneasca.daca stioe cineva sa ma ajute ce poate fii cheia(cheile)de vina sau e centralina care nu mai citeste?va multumesc
  • 1 year later...
Trebuie sa faci matalutza o reinitializare la chei.... la ambele.... eu asa am facut..uite aici de la un site amrican
Remote Key Re-Initialise - If a key fails to operate remotely, it will have to be re-initialised (all keys in sequence at the same time)
- Get in and “close all doors”
- Turn ignition on & off quickly (no more than 5 seconds) to start the process. Next action must take place within 30 seconds
- First key - hold down button #2 (unlock) while striking button #1 (lock) three times. Release button #2. Confirmed by door lock operation.
- Repeat for second key within 30 seconds of first.
- After last key then cycle the ignition on/off to finalise the process (not necessary to start the engine)
Recently Browsing 0
