dariepl
Everything posted by dariepl
  1. Buna dimineata, Cam asta e comanda de piese. La cateva repere am aproximat pretul. Dupa ce rezolv pierderea de ulei si intratul in viteze o sa vreau placute frana, telescoape si niste bucse din cauciuc daca aveti de unde. Am inteles ca aveti magazin de piese - imi puteti recomda un un tub de vaselina pentru pus peste garnitura care vine la corpul filtrului de ulei (daca se pune). Piesele sunt originale BMW presupun. Cod Buc Denumire P ftva Tva Total 11157501567 1 CRANK CASE VENT VALVE 178 33,82 211,82 07119901679 2 HEX BOLT WITH WASHER M7X30-Z2 1,45 0,28 3,45 11421716192 1 SET OIL-FILTER ELEMENT 28 5,32 33,32 11421709513 2 O-RING 24X3 (NO.5) 5,2 0,99 12,38 11421709800 2 GASKET ASBESTOS FREE 5,5 1,05 13,09 07119912955 4 HEX BOLT WITH WASHER M6X75-Z1 (NO.9) 1,3 0,25 6,19 25111220600 1 BEARING, SHIFT LEVER (NO.7) 29 5,51 34,51 25111221849 1 BEARING BOLT D=10MMX40MM (NO.3) 14,5 2,76 17,26 25117519669 1 BEARING SLEEVE, ROUND L=26MM (NO.2) 18 3,42 21,42 25111220439 6 WASHER, PLASTIC (NO.10) 0,8 0,15 5,71 25111222451 2 LOCK RING (NO.13) 1,2 0,23 2,86 25111434194 2 WASHER, PLASTIC (NO.14) 2,11 0,4 5,02 25111220379 3 CIRCLIP (NO.11) 1,75 0,33 6,25 51161881149 5 EXPANDING RIVET 0,58 0,11 3,45 07129904150 5 BODY NUT ST4,8-9-ZNS3 0,47 0,09 2,8 41358220110 5 HEX HEAD SCREW WITH WASHER ST-6,3X13 0,49 0,09 2,92 07119901299 5 HEX HEAD SCREW ST4,8X16-ZNS3 0,47 0,09 2,8 07147129160 5 HEX HEAD SCREW WITH WASHER ST4,8X16MM 0,64 0,12 3,81 41358203482 5 TORX BOLT ISA ST6,3X21 0,47 0,09 2,8 51718242741 5 PLUG-IN NUT 0,47 0,09 2,8 07119901787 4 HEX BOLT WITH WASHER M6X20-Z1-ZNS (NO.9) 1,3 0,25 6,19 07119901137 3 HEX BOLT WITH WASHER M8X30-Z1-ZNS (NO.8) 2,5 0,48 8,93 07119901943 4 HEX BOLT WITH WASHER M6X30-Z1-ZNS (NO.10) 1,3 0,25 6,19 51118174185 6 EXPANDING RIVET SCHWARZ 0,8 0,15 5,71 51718205286 4 SECURING BOLT M8X16 1,8 0,34 8,57 41132291403 4 BLIND RIVET NUT M8 2,4 0,46 11,42 07119903862 2 HEX BOLT WITH WASHER M6X50-U1-ZNS3 07119902140 3 FILLISTER HEAD WITH WASHER M8X20 11121726242 1 DOWEL D=8,5MM 07119901787 2 HEX BOLT WITH WASHER M6X20-Z1-ZNS sa imi spuneti cum platesc -ramburs sau sa va trimit in cont prin ING (ajung a doua zi) tel 0723192627 darieplugariu@yahoo.com
  2. BUNA ZIUA Asi dori urmatoarele repere: CRANK CASE VENT VALVE 11157501567 HEX BOLT WITH WASHER M7X30-Z2 07119901679 SET OIL-FILTER ELEMENT 11421716192 O-RING 24X3 (NO.5) 11421709513 GASKET ASBESTOS FREE 11421709800 HEX BOLT WITH WASHER M6X35-Z1-ZNS (NO.7) 07119901973 -4 BUCATI- HEX BOLT WITH WASHER M6X75-Z1 (NO.9) 07119912955 -4 BUCATI- SUPPORT LIFTING PLATFORM 51718268885 BEARING, SHIFT LEVER (NO.7) 25111220600 BEARING BOLT D=10MMX40MM (NO.3) 25111221849 BEARING SLEEVE, ROUND L=26MM (NO.2) 25111220832 WASHER, PLASTIC (NO.10) 25111220439 -6 BUCATI- LOCK RING (NO.13) 25111222451 -4 BUCATI- WASHER, PLASTIC (NO.14) 25111434194 -2 BUCATI- CIRCLIP (NO.11) 25111220379 -4 BUCATI- cat costa si in cate zile pot ajunge? Eu sunt din Bacau. tel 0723192627, darieplugariu@yahoo.com Un nr de tel??
  3. Buna seara, Ma intereseaza pretul si in cit timp pot primi o valva noua PCV pt e46 318i '98 motor M43 1. CRANK CASE VENT VALVE 11157501567 2 SET OIL-FILTER ELEMENT 11421716192 acesta e codul pt filtru ulei de hirtie cu garnituri de cauciuc care se schimba cand schimbi uleiul? si informativ urmatoarele ;un surub 2. HEX BOLT WITH WASHER M7X30-Z2 07119901679 3. EXPANSION TANK, MANUAL TRANSMISSSION 17111436255 BC 0723192627 va multumesc si astept raspunsul dumneavoastra
  4. Salut, pune te rog o poza cu "Macara geam electric cu motoras, cu totul, E46 dreapta fata, 180 lei." daca e in stare perfecta - ma intereseaza
