evlmaster
Everything posted by evlmaster
  1. timtara, ma bucur ca totul este ok si multumesc si eu !! ser23, Daca esti interesat de o piesa noua lasa-mi aici sau mesaj privat cu seria de caroserie pentru a identifca corect reperul- desi eu recomand mai mult o piesa second hand - pretul piesei noi este mult peste!! multumesc anticipat Radu 0724223552
  2. Salutare timtara, a sosit si noua sonda lamda , comandata pe seria masinii; model NGK NTK cu mufa si cablu; model OZA572-E6 - PRET CU TRANSPORT INCLUS;390 RON ATASAT POTI VIZUALIZA POZA SONDEI MERCI RADU
  3. salutare timtara , A fost comandata sonda lamda: NGK- NTK- originala cu mufa completa: 380 ron multumesc radu
  4. timtara Sonda lambda BMW 318I TURING, MOTOR M43, AN 1997 - bosch oem: 350 ron + 20 ron transportul la tine. cOMANDA A ASOSIT SI AM CONSIDERAT NORMAL SA TE ANUNT CA SONDA A SOSIT ORIGINALA PE BOSCH , DESI A FOST COMANDATA DUPA COD MOTOR SI PART NO, CU MUFA ATASABILA DUPA CUM SE VEDE IN POZA PENTRU CA PIESA A SOSIT DIN GERMANIA LA COMANDA IMPORTATORUL MA VA PENALIZA INTRE 10 SI 12% DIN VALOAREA PIESEI SI NU FACEM NICI EU NICI TU NICI O AFACERE- PRET NOU 320 RON( INCLUSIV TRANSPORT PLATIT- SAU DACA NU VARIANTA DE RETUR SI COMANDAREA UNEI PIESE CU MUFA INTERGRATA PS; NU ESTE VINA MEA ESTE VINA IMPORTATORULUIL, IMI ASUM PARTEA DE RESPONSABILITATE PRIN PRET, RADU 0724223552 0751897607
  5. lucian_v preturile solicitate: Pentru partea de mecanica propun: Pachet Mecanica complet pret 1200 ron(contine) - brat stanga fata+ brat dreapta fata - bucsa brat stanga+ dreapta - bielete antiruliu stanga +dreapta - bielete directie +capete bara stanga +dreapta discuri frana fata................textar 170 ron/buc..............RH 140 ron/buc placute fata +senzori.............textar 145/set,RH 110ron set...............senzori 35(textar) discuri frana spate ..............textar 165 ron/buc.............RH 130ron/buc placute spate + senzori...........textar 135 ron/set,RH 90/set....................40(textar) flanse amortizor Sachs fata + spate..............95 ron/buc...............50 ron/buc telescoape fata - ATP/MAPCO- 450 ron set telescoape spate - ATP- 300 RON /SET KIT AMORTIZOARE FATA SACHS- 80 RON KIT AMORTIZOARE SPATE- 80 RON kit ambreiaj + volanta................1030 Luk(placa,disc,rulment) .....................860 LUK(pe stoc originala Luk) bucse bara stabilizatoare-.............. doar OE BMW- 120 set filtru ulei mann---38 ron filtru aer mann---90 ron / filtru aer filtron...... 70ron filtru motorina mann---110 ron/ filtru polen mann-- 70 ron / filtru polen filtron 60 ron Ulei castrol 5w40- 5L- 160 ron ulei castrol 5w4 castrol edge- 1L - 35 ron multumesc anticipat, Radu 0724223552 0751897607
  6. salutare Adrian, am pus deja bratul la curier- astept confirmare din partea ta. lucian_v pentru piesele solicitate am nevoie de serie completa de caroserie - pentru a nu gresi reperele solicitate. timtara sonda lambda BMW 318I TURING, MOTOR M43, AN 1997 - bosch oem: 350 ron + 20 ron transportul la tine. merci multumesc Radu 0724223552 0751897607
  7. Salutare Timtara, Am pe stoc numai sonde lamda pentru: Bmw 316 i - motor M43 - E36 Bmw 318 i - motor M43B19- E46 Pot aduce la comanda pret : 350 ron bucata(anunta-ma daca vrei la comanda) radu 0724223552 0751897607
  8. SALUTARE , 850 RON - PACHET MECANICA COMPLET MERCI
  9. 'Ciumidel' SALUTARE, PACHETUL PENTRU E36 CONTINE: - BRATE STANGA +DREAPTA- CU AMBII PIVOTI PE BRAT - BUCSI BRATE FATA- PLINE (ATEC DURABILITY)- BUCSA ESTE PLINA , NU ARE PARTI GOALE DE CAUCIUC - BIELETE DIRECTIE + CAPETE DE BARA STANGA +DREAPTA - ATEC/ATP - BIELETE ANTIRULIU- STANGA +DREAPTA MULTUMESC PENTRU INTERES, RADU 0724223552 0751897607
  10. DANIEL.URS A doua oferta acum a sosit, scuze adminilor pentru completare, doresc a fi foarte promt: Senzor poz ax came; BMW OE OE 4-5 Zile 1buc 410 ron 020 SENZOR POZITIE AX CU CAME; A.I.C. AM Stoc 24h 1buc- 150 ron 030 SENZOR POZITIE AX CU CAME; A.I.C. AM Stoc 24h 1buc- 95 ron 040 SONDA LAMBDA IN FATA CATALIZATORULUI; BMW OE 4-5 Zile 1buc 780 ron 050 SONDA LAMBDA INAINTEA CATALIZATORULUI; DENSO 3-4 Zile 1buc- 318 ron 060 SONDA LAMBDA INAINTEA CATALIZATORULUI; BOSCH 3-4 Zile 1buc - 435 ron 0_7_0__SO_N_D_A_ _LA_M_B_D_A_ U_N_I_V_E_RS_A_L_A_;_ B_O_S_C_H_ O_E_M 3-4 zile 1buc- 340 ron MULTUMESC, RADU 0724223552 07518976073
  11. sALUTARE TIMTARA BMW E 36, 318I, 1997, MOTOR m43, SERIE SASIU: WBACE41020EU66730,- CATALIZATOR HJS OEM- TERMEN LIVRARE 4-5 ZILE- 2260 RON DANIEL.URS SENZOR AM DISPONIBIL DOAR PE Evacuare 110 RON Swag - sonda lamda, inainte de catalizator 325 RON bosch MULTUMESC, RADU 0724223552 07518976073
  12. Salutare, timtara - pot sa -ti fac o oferta supr buna , dar am nevoie de serie se sasiu! adryan89- pentru un client vechi, caruia trebuie sa-i multumesc pentru numeroasele recomandari in Sibiu, - brat dreapta fata - VAICO- NOU+GARANTIE- 400 RON(TRANSPORT INCLUS) va multumesc pentru interes, radu 0724223552 0751897607
  13. Salutare, Au sosit din Germania Saptamana trecuta/ pe stoc: - Debitmetru ATEC - garantie 1 an / 3 luni (cu piesa noua a schimb) - 300 ron - Debitmetru Bosch original: 820 ron / cod bbmw original:13621433565 multumesc Radu 0724223552 0751897607
  14. SALUTARE, PACHET MECANICA COMPLET ATP GERMANY(GARANTIE ORICE PIESA 3 LUNI- PIESA NOUA LA SCHIMB): E46 + FILTRU BENZINA MANN: PRET TOTAL(INCLUSIV TRANSPORT):1290 RON MAINE SE VA FACE LIVRAREA , CONFORM ADRESEI FURNIZATE CU URGENT CURIER. MERCI RADU 0724223552 0751897607
  15. OFERTA SACHS!!!!! OFERTA SUSPENSIE COMPLETA SACHS BMW SERIE 3 E46- AN FABRICATIE 1999-2005 TELESCOP FATA – 285 RON/BUC - SACHS TELESCOP SPATE– 195 RON/BUC - SACHS FLANSA TELESCOP FATA– 85 RON / BUC – SACHS FLANSA TELESCOP SPATE – 50 RON/BUC - SACHS KIT PROTECTIE COMPLET AMORTIZOR FATA -85 RON/ SET - SACHS KIT PROTECTIE COMPLET AMORTIZOR SPATE – 80 RON / SET - SACHS OFERTA TELESCOAPE ECD/ATP!!! SET TELESCOAPE FATA BMW E36/E46/ECD/ATP: 400 ron(SET 2 BUCATI) SET TELESCOAPE SPATE BMW E36/E46/ECD/ ATP: 300 RON(SET 2 BUCATI) PRODUSELE SUNT NOI!!! RADU 0724 223 552 0751 897 607
  16. Salutare Micutzu, Pret Pachet telescoape SPATE E46/E36: 299 RON - set 2 bucati Pret Pachet telescoape FATA E46/E36; 400 RON - set 2 bucati Multumesc radu 0724 223 552 0751 897 607
  17. Salutare, BTU pentru e46 316: PACHET 8 piese NOI MECANICA + DIRECTIE BMW E46,E36: MARCA ATP GERMANY(ECHIVALENT MAYLE HD) -GARANTIE PE MAGAZIN CU PIESA NOUA LA SCHIMB- 3 LUNI DE ZILE PENTRU ORICE PIESA DIN PACHET -GARANTIE PACHET 1 AN CU DOCUMENTE DOVEDITOARE DE MONTAJ : CONSTATARE +MONTAJ -1 buc. BRAT + Pivot dreapta fata -1 buc. Brat + Pivot stanga fata -1 buc. Bucsa dreapta brat fata -1 buc. Bucsa stanga brat fata -1 Buc. Bieleta directie + capat bara dreapta -1 Buc. Bieleta directie + capat bara stanga -1 Buc. Bieleta antiruliu stanga fata -1 Buc. Bieleta antiruliu dreapta fata PRET PACHET :1250 RON Sorin7650 pentru :BMW serie 5, e39, 2003, ultimele 7 de caroserie GW71310 - 06/2003 E39 525d Sedan M57 Europe Left hand drive - brat superior cu tot cu bucsa...................470 ron Lemforder.................265 ron SWAG - brat inferior..................410 Lemforder....................230 ron Swag Multumesc anticipat, Radu 0724 223 552 051 897 607
  18. Salutare, Piesele solicitate: - filtru ulei MOTOR- mann....................25 ron Knecht Mahle - kit filtru ulei cutie hidramata.............95 ron SWAG - filtru benzina..................72 ron Knecht - FILTRU BENZINA MANN- SERIE:WK 516/1- INCEPAND CU AN FABRICATIE 09.94 .....91RON - discuri frana fata + spate- AM- ATE .....................fata 2x130 ron................spate 2x115 ron - placute frana fata + spate -AM- ................fata RH 105/Textar 140 ron........................spate RH 75,Textar 117 ron - filtru aer-...............55ron Knecht - FILTRU HABITACLU- MANN- MODEL CU2835- 78 RON AI PE MASINA CUTIE DE VITEZE MODEL: A4S 310R - CANTITATE DE UMPLETE 8,8 LITRI ULEI MOTOR DISPONIBIL PE STOC: - CASTROL EDGE:5W40 EDGE 1LT- 35 RON/LITRUL- SINTETIC - MOBIL 1 NEW LIFE 0W40/4LT -170 RON - SUPER SINTETIC/GERMANIA- UN PIC SUBTIRE LA PORNIRE DAR CU PROPRIETATI SUPERIOARE DUPA INCALZIRE - MOBIL SUPER 3000 X1- 5W40/4LT- 120 RON - SINTETIC - ULEI CUTIE VITEZE: DEXTRONII/III- CASTROL 35 RON/LT CantitãÞi de umplere ºi specificaÞiiUlei de motor cu filtru 4,00 litri Specificare ulei de motor Variantã 1 BMW Longlife-04 Variantã 2 BMW Longlife-01 Variantã 3 BMW Longlife-98 Transmisie manualã Cutie de viteze S5D 200G Cutie de viteze S5D 250G, Cu reumplare 1,10 litri Cutie de viteze S5D 200G Cutie de viteze S5D 250G, Cantitate de schimb 1,00 litri Cutie de viteze S5D 260Z Cutie de viteze S5D 310Z, Cu reumplare 1,30 litri Cutie de viteze S5D 260Z Cutie de viteze S5D 310Z, Cantitate de schimb 1,20 litri Transmisie automatã Cutie de viteze A5S 300J Cutie de viteze A5S 310Z, Cantitate de schimb 3,00 litri Cutie de viteze A5S 300J Cutie de viteze A5S 310Z, Cu reumplare 7,80 litri Cutie de viteze A4S 270R Cutie de viteze A4S 310R, Cu reumplare 8,80 litri Cutie de viteze A4S 270R Cutie de viteze A4S 310R, Cantitate de schimb 3,00 litri SpecificaÞie ulei transmisie automatã > Ulei original DiferenÞial osie spate Ax 168N 1,10 litri Ax 188N 1,70 litri SpecificaÞie ulei osie spate > Ulei original ServodirecÞie 1,20 litri Specificare ulei servodirecÞie > DirecÞie cu cremalierã ZF Uleiuri prin BMW distribuÞia pieselor Numele comercial Culoarea uleiului Numãr de pieseã BMW Ambalare Ulei cutie automatã de viteze BMW Roºu 81 22 9 400 272 1 litri Pentosin CHF 11S Verde 83 29 0 429 576 1 litri Recipientele de ulei pentru uleiul hidraulic au un marcaj pe marginea recipientului de ulei, care indicã ce tip de ulei poate fi folosit. Lichide de rãcire 6,50 litri Specificare lichid de rãcire > Etilen-glicol Lichide de frâna la schimbare 1,20 litri Specificare lichid de frânã DOT 4 Agent de rãcire instalaÞie de climatizare Condensator cu tub circular 975 - 1025 Grame Condensator cu tub plat 800 - 850 Grame SpecificaÞie agent de rãcire R 134a Pentru datele de service- BMW 318I/E36/M43 Interval de Înlocuire a filtrului de aer la fiecare 2. Service Interval de Înlocuire a filtrului de combustibil la fiecare 2. Service II Interval de schimbare a lichidului de frânã la fiecare 2 ani Interval de schimbare a agentului de rãcire a motorului pânã la 1994/08 la fiecare 2 ani de la 1994/09 la fiecare 3 ani Interval de schimbare a uleiului transmisiei manuale la fiecare 2. Service II Interval de schimbare a uleiului transmisie automate la fiecare 2. Service Interval de schimbare a uleiului transmisiei osiei posterioare la fiecare 2. Service Interval de schimbare a uleiului de motor ºi a filtrului la fiecare service Interval de Înlocuire a filtrului de habitaclu la fiecare service MULTUMESC ANTICIPAT RADU 0724223552 0751897607
  19. salutare prietene, am si eu nevoie de o serie completa de caroserie si te pot informa cu toate detaliile de care ai nevoie, cantitati de umplere, uleiuri folosite pentru motorul tau, indicative si multe alte detalii,,etc maine vei primi toate raspunsurile supa ce primesc informatiile necesare multumesc Radu 0724223552 0751897607
  20. REDUCERI DE PRIMAVARA!!! PACHET 8 piese NOI MECANICA + DIRECTIE BMW E46,E36: -1 buc. BRAT + Pivot dreapta fata -1 buc. Brat + Pivot stanga fata -1 buc. Bucsa dreapta brat fata -1 buc. Bucsa stanga brat fata -1 Buc. Bieleta directie + capat bara dreapta -1 Buc. Bieleta directie + capat bara stanga -1 Buc. Bieleta antiruliu stanga fata -1 Buc. Bieleta antiruliu dreapta fata Pachet doua TELESCOAPE SPATE BMW E46, E36: - telescop gaz stanga spate -Telescop gaz dreapta spate Pret Pachet piese E46: 1250 RON Pret Pachet piese E36: 900 RON Pret Pachet telescoape SPATE E46/E36: 299 RON - set 2 bucati Pret Pachet telescoape FATA E46/E36; 400 RON - set 2 bucati RADU 0723 223 552 0751 897 607
  21. SALUTARE GEO, REVIN CU OFERTA DE MAI JOS- CEA MAI BUNA CALITATE!! Merci. te astept cu mare placere. OFERTA SACHS!!!!! OFERTA SUSPENSIE COMPLETA SACHS BMW SERIE 3 E46- AN FABRICATIE 1999-2005 TELESCOP FATA – 285 RON/BUC - SACHS TELESCOP SPATE– 195 RON/BUC - SACHS FLANSA TELESCOP FATA– 85 RON / BUC – SACHS FLANSA TELESCOP SPATE – 50 RON/BUC - SACHS KIT PROTECTIE COMPLET AMORTIZOR FATA -65 RON/ SET - SACHS KIT PROTECTIE COMPLET AMORTIZOR SPATE – 65 RON / SET - SACHS PRODUSELE SUNT NOI!!! Pret: 1490 LEI SAU SAPTAMANA VIITOARE PE GERMANIA: - 380 ron - SET AMORTIZOARE FATA E46 RADU 0724 223 552 0751 897 607
  22. Salutare ROBERT, ai mai jos ce contine + GARANTIE 3 LUNI- PRNTRU ORICE PIESA - SE SCHIMBA CU UNA NOUA IN 24H!!! PACHET 8 piese NOI MECANICA +DIRECTIE BMW E46, E36: -1 buc. BRAT+Pivot dreapta fata -1 buc. Brat +Pivot stanga fata -1 buc. Bucsa dreapta brat fata -1 buc. Bucsa stanga brat fata -1 Buc. Bieleta directie+ capat bara dreapta -1 Buc. Bieleta directie +capat bara stanga -1 Buc. Bieleta antiruliu stanga fata -1 Buc. Bieleta antiruliu dreapta fata MERCI RADU 0724223552 0751897607
  23. SALUTARE COSMYN13, ASA CUM AM STABILITA LA TELEFON: Fa-mi te rog o oferta pt un set reparatie mecanica si o sonda lambda pt un BMW 3 (E36) Berlina (1993) 318 i (83 / 113; 1796; M 40 B 18) WBACA31010FB70083 OFERTA PROMOTIONALA- - PACHET MECANICA COMPLET- ATEC/GERMANY-2 BRATE, 2 BUCSI, 2 BIELETE ANTIRULIU, 2 BIELETE DIRECTIE+CAPETE BARA + - SONDA LAMDA BOSCH OEM(PE PART NO ORIGINAL) CU CABLU SI MUFA PRET COMPLET CU TRANSPORT ASIGURAT: 1250 RON MERCI RADU 0724223552 0751897607
  24. SALUTARE COSMYN13, AM URMATOARELE VARIANTE: Producator Facet: 366 RON PRODUCATOR BOSCH : 500 RON PRODUCATOR NGK: 580 RON MULTUMESC ANTICIPAT, BBOGDAN- am discutat la telefon, multumesc de comanda, astazi sau maine piesa va fi livrata de un prieeten de-al meu- am inteles necesitatea si urgenta. merci DISPONIBILITATE PE STOC 20 BUC: PIESA CU TEPI(PENTRU CLIMA/AEROTERMA)-Final Stage Unit E46 99-05 All- COD ORIGINAL: 64116920365 - MARCA DEUTCHE PARTS: 220 RON/BUCATA - PIESA NOUA SIGILATA + GARANTIE RADU 0724223552 0751897607
  25. Salutare all, sorinescus Merci. te astept cu mare placere. OFERTA SACHS!!!!! OFERTA SUSPENSIE COMPLETA SACHS BMW SERIE 3 E46- AN FABRICATIE 1999-2005 TELESCOP FATA – 285 RON/BUC - SACHS TELESCOP SPATE– 195 RON/BUC - SACHS FLANSA TELESCOP FATA– 85 RON / BUC – SACHS FLANSA TELESCOP SPATE – 50 RON/BUC - SACHS KIT PROTECTIE COMPLET AMORTIZOR FATA -65 RON/ SET - SACHS KIT PROTECTIE COMPLET AMORTIZOR SPATE – 65 RON / SET - SACHS PRODUSELE SUNT NOI!!! Pret: 1490 LEI RADU 0724 223 552 0751 897 607
