GOD*S3
Everything posted by GOD*S3
  1. amortizor fata stanga 50 lei suport casetofon,clima 30 lei bloc lumini fara buton proiectoare 50 lei oglinzi stanga dreapta fara incalzire 50 lei ambele maneta semnalizare fara bc. 20 lei consola centrala pentru geamuri electrice fata 30 lei
  2. Vand Presuri BMW E46 Pret 70RON Senzor axa came BMW E46 318i facelift (a fost doar probat pe masina si nu a fost defectiunea de la el) 50RON
  3. 4 bucati Jante de tabla (15') + Cauciucuri de iarna + capace negre cu abĂžibild BMW PRET 100Euro http://imageshack.us/a/img16/1489/img1079qy.th.jpg http://imageshack.us/a/img502/8779/img1078gf.th.jpg http://imageshack.us/a/img203/8171/img1077u.th.jpg
  4. se poate inchide sa dat la schimb multumesc bmw club.
  5. http://www.bmwclub.ro/forums/topic/112516-vand-e46-seria3-318i/page__st__20__gopid__1874558#entry1874558 Pretul este mai sus decat oferi tu ,dar dotarile pe masura.
  6. http://www.bmwclub.ro/forums/topic/112516-vand-e46-seria3-318i/page__st__20__gopid__1874558#entry1874558
  7. PRET NOU 5700 !!! URGENT !!! SAU VARIANTE SAU OFER DIFERENTE PENTRU SERIA 5 DIESEL E60
  8. cumpar fete usi culoarea crem e46 sedan,geamuri electrice doar fata.
  9. se poate inchide topicul,multumesc userului roscatu m3
  10. up,,,,,, mai nou alarma pager,senzor perimetru.
  11. cumpar,ornamente stalpi interiori,fata,mijloc,spate pe negru sau crem,e46 sedan.
  12. read this on e46 fanatics website titled THROTTLE ADAPTATION aimed at 1999 323i owners with m52u engine. 1.turn key to on position[not start] position,just before the starter turns over. 2.press accelerator pedal to the floor,with the key in the on position. 3.hold the pedal to the floor for 5 seconds,then turn back key to off position [dont remove key] then release accelerator pedal. 4.wait for 2 minutes for full alignment. 5.then drive off as normal. For those with M54 M54 MS43 lumps under the bonnet with throttle drive by wire ( electronic ) and not by a cable there is a reset than can be made that may improve throttle response. This is typically done if a customer complains after an a new EDK is installed - allthough it should be done as part of the procedure anyway). Its easy and quick just 20 seconds thats all !! 1 Place key in ignition and turn to detent 1 and count for 10 seconds ( only postion 1 do not start the engine. ) 2.Turn key back to 0 postion and count for another 10 seconds 3.Now turn the key all the way to detent 3 to start the engine Thats it your throttle is now reset. this can help to improve the cars throttle response. this little trick is always worth a go if you feel the car is a little sluggish or has been bought off someone who has just gone to the shops n back in thier BM. In theroy the throttle should now adapt slightly to your driving style
  13. Deci, daca aveti in general un stil de conducere calm, de-a lungul timpului acceleratiei va deveni din nou lipsit de vlaga si va fi nevoie din nou de o astfel de resetare. Se recomandĂŁ ca acest lucru sĂŁ fie efectuat la fiecare 3-6 luni dacĂŁ simĂžiĂži nevoia ca masina dvs. sa fie iar "nervoasa".IatĂŁ paÂşii de urmat pentru un E46. Acestia sunt simpli Âşi uÂşor de urmat. IatĂŁ paÂşii de urmat pentru un E46. Acestia sunt simpli Âşi uÂşor de urmat. Ăn primul rând, cu cheia scoasa din contact, stati ĂŽn scaunul Âşoferului Âşi apoi introduceĂži cheia. RotiĂži cheia ĂŽn poziĂžia "2". PoziĂžia "2" este acea pozitie ĂŽnainte aceleia in care se porneste motorul. AÂşteptaĂži 10 secunde Âşi apoi reveniti cu cheia la poziĂžia "0", care este poziĂžia iniĂžialĂŁ. DupĂŁ care aÂşteptaĂži din nou 10 secunde Âşi apoi porniĂži motorul. Acum ati resetat masina in privnta modului de rĂŁspuns al acceleratiei, masina va demara iarasi ca la inceput, dar cu timpul se va adapta la modul dvs, de conducere pe care il veti adapta dupa aceasta resetare.
  14. pret nou 6000 eurasi descriere; bmw e46,318i an 2002 km.160000 carte servis,proprietar,masina se vinde cu doua randuri de jante dvd dedicat cu gps,tv,bluetooth,camera marsalier folii omologate
  15. amortizor fata stanga 50 lei suport casetofon,clima 30 lei bloc lumini fara buton proiectoare 50 lei oglinzi stanga dreapta fara incalzire 50 lei ambele maneta semnalizare fara bc. 20 lei volan sport 50 lei trim volan sport 20 lei consola centrala pentru geamuri electrice fata 30 lei
  16. navigatia,1900 lei cu tot cu camera marsalier,montaj in ploiesti,un servis specializat in alarme si dvd etc.
  17. up...pret negociabil.sau schimb cu seria 5 e60 plus diferenta.
