dragos e87
Everything posted by dragos e87
  1. Code: K MUEB MUE_BELEUCHTUNG //NachrĂźstsatz Heckleuchten LCI Massnahme E87N, Projektnr.:FZ 000000246 I'm not sure what hte format for adding K-words to the VO is. My guess is that the string you'd need to add is "+MUEB". If I'm right, this is what you'd do. Add "+MUEB" to your VO, and do FA_WRITE on both the FRM and CAS. Then load up the standard expertmode file, and do SG_CODIEREN on the FRM module. Edit: Compared the resulting FSW_PSW from adding the +MUEB to the VO. First column is without the +MUEB, 2nd column is with. Theoretically those are all the differences. Code: C:\NCSEXPER\WORK\FSW_E87.TXT C:\NCSEXPER\WORK\FRM_E87_.TXT PWM_ANSTEUERUNG_NSL_SL PWM_ANSTEUERUNG_NSL_SL wert_03 wert_01 wert_02 RL_BL_1_PARKL_FKT RL_BL_1_PARKL_FKT aktiv nicht_aktiv RL_BL_1_PO_RL_FKT RL_BL_1_PO_RL_FKT aktiv nicht_aktiv RL_BL_2_PARKL_FKT RL_BL_2_PARKL_FKT nicht_aktiv aktiv RL_BL_2_PO_RL_FKT RL_BL_2_PO_RL_FKT nicht_aktiv aktiv PWM_ANSTEUERUNG_RL_BL_2 PWM_ANSTEUERUNG_RL_BL_2 wert_02 wert_05 wert_03
  2. Ne-am gandit si la schimabrea modulului, insa eu nu am xenon (am faruri simple) si nici nu am bani momentan sa le cumpar, nu da eroare daca schimb modulul actual cu FRM3? Si totusi codare, sa anulez functia de pozitie sus jos nu exista? Sa ramana doar ceata sus si stop pe frana jos? Multumesc!
  3. Buna, Am montat stopuri LCI pe un E87, an 12/2004, care avea stopuri normale (facelift fara LCI). Am tras cablu suplimentar de la luminile de la numere, pentru Led. Toate bune, insa raman aprinse becul de sus (cel de ceata) si becul de jos (cel de stop pe frana), ca si inainte la stopul simplu facelift + LED-ul din stopul cu LCI, deci am 3 poziti acum:) Am inteles ca se poate coda si anula pozitita pe becul de sus (ceata) si becul de jos (stop pe frana) si sa rana doar LCI-ul (cele 4 benzi aprinse cum ar fi normal)??? Sau ar mai fi o varianta de "plug and play"de la mufa de facelift cu 5 fire la mufa de LCI cu 6 fire, insa nu stiu unde gasesc asa ceva?? Multumesc anticipat!!
