VAND JBL gto 1202 d, statie si condensator
Gully
post-2078-0-33823700-1353011636_thumb.jpgvand subvoofer JBL gto 1202d, cu statie Mgnat Phantom 2000 si condensator DIETZ 1 fr
  • condensator 1 Farad
  • 21 VDC
  • voltmetru digital cu LCD
  • activare remote
  • cod dietz: 2100
Magnat Phantom 2000
* amplificator stereo, 2 canale
* putere:
o 4 ohmi, stereo: 2 x 100 W RMS
o 4 ohmi, in punte: 1 x 300 W RMS
o 2 ohmi, stereo: 2 x 280 W RMS
* raspuns in frecventa: 5 Hz - 50 kHz (-3dB)
* impedanta: 2-8 ohmi
* bass boost variabil 0 - 12 dB la 45 Hz
* filtru low pass variabil 30 - 500 Hz (12 dB)
* filtru high pass variabil 50 - 500 Hz (12 dB)
* selector mod de functionare 2/1 canale
* circuit de protectie impotriva scurtcircuitelor si a supraincalzirii
* neoane albastre incorporate
JBL gto 1202d
  • subwoofer 30 cm, 12 inch
  • putere: 300W RMS, 1200W max
  • raspuns in frecventa: 23Hz - 400Hz
  • sensibilitate: 93dB
  • impedanta: 4/1 Ohm (2 bobine x 2 ohm)
  • diametru de taiere: 285mm (11-3/16")
  • adancime de instalare: 129mm (5-1/16")
diametru exterior: 316mm (12-7/16")
600 lei,
0722.211.095 Bucuresti
  • 21 VDC
  • activare remote
  • cod dietz: 2100
Magnat Phantom 2000
* putere:
JBL gto 1202d
600 lei,
Edited by Gully
Vrei un set de jante originale BMW style 13, dim. 5x120, echipate cu cauciucuri de vara pe 15
daca erai in Bucuresti era OK, puteam sa le vad
in principiu am nevoie de bani dar accept si schimburi cu ceva interesant.
asadar UP!
