BMW - Campanie inlocuire airbag
PuMA measure
Information about the Technical Campaign "Replace the airbag", list with chassis numbers V1-R2-RO 63103341-02 - 27/02/17
Complaint:
In addition to the Technical Campaign of the company Autoliv, this PuMA measure provides the chassis numbers and the associated required part numbers
BMWi 00 72 76 01 00 - I01 I12 Replace airbag
Mini 00 72 77 01 00 - F5x Replace airbag
BMW 00 72 78 01 00 - F0x F1x F3x F4x Replace airbag
BMW 00 72 82 01 00 - F0x F1x F33 F4x F83 Replace airbag
Cause
The list of the chassis numbers and the suitable part numbers is not representable in some markets
in the documents of the Technical Campaign.
Therefore this PuMA measure was also created as additional information for the workshops.
Measure
20.02.2017 Langthaler
Alteration to Version -01:
Further Technical Campaign 00 72 82 01 00 Replace airbag with the chassis numbers and part numbers added.
On the basis of the attached lists please check which part number(s) are needed for each vehicle.
Further information about the procedure as well as the invoicing can be taken from the respective Technical Campaign.
Hint:
These lists can in part also already be present in the documents of the Technical Campaign.
Validity information
Model series:
[F10, F54, F45, F56, F12, F11, F55, F33, F57, F46, F48, F07]
Engine range:
[ALL]
Body style:
[ALL]
Fault codes:
Production period:
Un moderator poate atasa fisierele PDF ale acestei campanii care contin seriile de sasiu ce necesita inlocuirea de airbag?
Sunt 4 fisiere PDF cu dimensiuni de aprox. 3MB fiecare, eu nu pot atasa deoarece forumul are limita la 2MB.
Edited by neo_andersson
