ISTA 4.08.13 Standalone / SDP 4.08.11 / ISTA-P 3.63..0400
Pentru a instala doar ISTA-D trebuie sa bifati din Torrent doar: ISTA-D , SQLiteDBs(debifati RU si DE) si Tools (Pentru cine are ICOM si vrea sa faca si programare cu ISTA-D poate sa bifeze si SDP care se dezarhiveaza si se copiaza in folderul PSdZ din ISTA-D)
Pentru a instala ISTA-P aveti ghidul in folderul Tools - FAQ-EN.pdf iar pentru ISTA-D trebuie doar sa urmati ghidul de mai jos.
Installation:
1. Install .Net Framework 4.5.2 version and up, from Microsoft or Tools folder.
2. Install Java.
3. Download and install the Microsoft Visual C++ 2010/2013 Redistributable Package x86/x64 from Microsoft for your language in Windows.
*** for computer x86:
- vs90_piaredist
- vcredist_x86_2005
- vcredist_x86_2008
- vcredist_x86_2010
- vcredist_x86_2012
- vcredist_x86_2013
- vcredist_x86_2015
*** for computer x64:
- vs90_piaredist
- vcredist_x64_2005
- vcredist_x64_2008
- vcredist_x64_2010
- vcredist_x64_2012
- vcredist_x64_2013
- vcredist_x64_2015
If the system is x64, vcredist must install x86 and x64, otherwise not start Rheingold.
4. Install Ediabas 7.3
5. Unblock archive if necessary. It is important to not skip this step! Unblock file, uncheck Attributes - Read-only. Then unzip.
6. Unzip to any directory, for example: C:\Rheingold, D:\Rheingold, E:\Rheingold..., C:\Program Files\, C:\Program Files (x86) - this folder for 64bit computers. You can run from USB stick too.
7. Unzip and copy SQLiteDBs in Rheingold\SQLiteDBs\
8. Add additional languages if necessary in SQLiteDBs
9. Start RCleaner. Run as administrator.
10. Apply ISTA-D and SQLiteDBs Reg Fix bit for your system from the Tools folder.
11. Start Rheingold (...\Rheingold\TesterGUI\bin\Release\ISTAGUI.exe) Run as administrator.
12. Enter the license key from the license.txt, if ask.
13. Enter 1 in the field of ISIS, ignore the error.
ISTA-D 4.08.13.rar
Edited by OPaul
  • Like 5
Salutare.
Weekendu asta am reusit si eu sa instalez ISTA/D. Porneste doar ca am o problema.
Atunci cand apas sa identific auto fara test (sau cu test) imi apare o fereastra goala.
Am reusit totusi cumva sa ma conectez la masina prin tab-urile acelea de "New", "Finished", "Active".
Problema este ca nu am reusit sa cites nici o informatie
Iar cam un urma unei actiuni raman cu fereastra de "Ongoing background process" ce nu dispare (am lasat minute intregi si nimic) singura optiune fiind sa opresc conexiunea din tab-ul "Active".
Ceva pareri? :D Ce as fi putut sa fac gresit?
Salutare.
Tu ce fel de cablu folosesti? Enet sau dcan?
Eu reusesc sa ma conectez si sa fac diverse operatii de service cu Ista si cablu dcan (2versiuni) dar am o senzatie ca nu toate ECU sunt vazute bine.
Imi apare ca mai jos:
Si am incercat diverse variante de drivere, setari de port sau versiuni mai vechi de Ista dar tot nu le dau nicicum de cap. Si nu imi dau seama daca ceva este intr-adevar prost vazut sau asa trebuie sa apara.
Numai bine,
Paul
Daca s-a mai lovit cineva de problema mea, am reusit sa o rezolv :)
In PDF-ul respectiv este un pas care iti cere sa modifici ip-ul si subnet mask. Am scos setarile alea, am lasat pe default iar in ISTA la config am selectat ENET direct connection.
All good now :)
Salut . Se poate folosi si la e46 320 d 2002?? Daca da se poate un link la cablul necesar. Multumesc colegi.
Cu siguranta merge - este softul de diagnoza folosit de BMW.
Iti trebuie un cablu in genul acestuia: https://techstar.ro/247-bmw-inpa-kcan.html - eventual vezi si pe OLX sau china pentru preturi mai bune. Vezi ca unele au un buton extern din care poti uni/dez-uni pinii 7/8.
Tie teoretic iti trebuie cu pinii uniti.
Unul care sa mearga sigur - nush sa iti zic (eu ce am luat de pe olx mi se comporta ciudat pe E83 din 2010 - trebuie uniti pinii 7/8 desi la masinile de dupa 2007 se zice ca nu mai trebuie uniti - inca nu m-am prins poate e o ciudatenie de E83 din 06/2010 fiind foarte aproape de modelul nou F25), acelasi cablu pe un E61 din 2005 merge atza cap coada.
numai bine,
paul
08 e cu probleme. nu recomand :thumbsup:
Si eu sunt curios ce probleme ai intalnit.
Mie vad ca imi sterge chiar si erorile (desi am citit ca nu se mai pot sterge cu versiunile noi cu cablu dcan).
Este adevarat ca imi reapar dupa prima pornire - inca investighez daca chiar e de ingrijorat sau doar o eroare software BMW:
D71N47D0 --- 0x004B1C DDE: Fuel-filter heating, activation
TELIBUS3 --- 0x000091 TCU: Main telephone antenna, fault
Aceleasi erori le vad si cu Inpa, le pot sterge dar la fel - reapar dupa prima pornire.
Masina porneste ok chiar si la temperaturi negative, relanti corect dar nush de ce tot da eroarea de fuel filter heating. Daca testez modulul acela de incalzire din Ista - ii creste temperatura corect la combustibil deci nu vad ca ar fi o problema reala nici cu siguranta, nici cu releul si nici cu elementul de incalzire in sine.
Mai caut.
PS - acum imi bat capul un pic cu NCS Expert sa vad cat de complicat e de modificat maruntisuri.
Paul
Edited by ivanp
Daca nu rezolvi problema e normal sa reapara erorile.
PS: Vezi ca este recall pentru preincalzitorul de la filtru de motorina , mergi la BMW si il schimba gratis.
De acord cu tine ca daca sunt permanente nu au cum sa dispara erorile.
Legat de recall - nu ma incadrez:
E70 E71 E8x F01 F02 N47 M57 N57. According to VIN selection (20.08.2008 - 12.06.2009)
E83-ul meu este din 06.2010.
Mai caut pe net sa vad cum s-a rezolvat. Nu am o problema sa il inlocuiesc dar parca vad ca o sa dea eroarea si dupa inlocuire.
Numai bine,
Paul
