Resetare interval service e60
Adi_UZI
Salut. Am incercat sa resetez intervalul de service dupa metoda de mai jos:
Firstly with the ignition switched on, set the odometer trip meter back to zero by pushing it once. Then switch the ignition back off again. (I found this step was critical, otherwise I couldn't get to the "Service" menu).
Now you are ready to go through the reset steps as follows:
1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car.
2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon.
3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu).
4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window.
5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on.
6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear.
7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above).
Hints & Tips
Before actually resetting anything, go through steps 1, 2 and 6 above until you are familiar (and sure) what you want to reset. Practice this a few times and note down in what order the icons appear after the initial "Service" icon appears.
If you do happen to hold the button down too long against an item you don't want to reset and the "RESET?" appears, just leave the button alone for 10 seconds or so and it will not let you reset the item. (Alternatively just switch the ignition off and start again).
Sometimes if you have not released and pressed the button again quickly enough, when you hold it down again the German technical writing will appear after about 15 - 20 seconds instead of the Service item icon you were expecting. (If this happens just switch off the ignition and start again).
Once you are sure what item you want to reset and are confident of the sequence, then give it a go. If you do hesitate between releasing and pressing the button at any time, you will have to go back to the beginning and start again as "he who hesitates is lost".
... dupa care intervalul de la placutele de frana fata+spate s-a dat singur la -25000 si acum nu mai pot sa-l resetez. Am incercat de o groaza de ori si tot nu merge. Precizez ca placutele si senzorii de frana sunt schimbate. Poate sa ma ajute cineva? Mersi.
Hints & Tips
dute la reprezentanta sa iti reseteze costa 50ron si dureaza 1 minut.eu atit am platit acum 2 saptamini pentru e39
Ăn primul rând puneti contactul, apoi apasati o data butonul de reset al kilometrajului partial. Apoi puneĂži din nou, contactul. (Am gĂŁsit acest pas a fost imprescindibil, altfel nu am putut ajunge la "Service" din meniu).
Acum sunteĂži gata sĂŁ treceĂži prin paÂşii de resetare, dupĂŁ cum urmeazĂŁ:
1. Puneti contactul (astfel Încât acul de la rezervor ºi luminile de frânã de parcare si bateria, sunt afisate) ºi de cheia este gata pentru a porni motorul - dar de fapt nu pornim.
2. ApãsaÞi pe buton pentru a reseta kilometrajul partial, Între 5 ºi 10 secunde pânã când un triunghi galben cu un semn de exclamare În centru apare În partea de sus a ferestrei Între ceasuri (În cazul În care temperatura de afara / ora sau data apare În mod normal) - aceasta este "Service" icon .
3. Ridicati putin degetul de pe buton ºi apãsaÞi butonul din nou imediat, care aduce o imagine cu simbolul lichid de frânã (aceeaºi cu cea care se vede cand accesati meniul service cu IDRIVE).
4. Dacã doriÞi sã resetaÞi "Service" la lichidul de frânã pentru un alt interval de 2 ani, tineti apasat acelasi buton pana apare cuvântul "RESET?" În partea de jos a ferestrei.
5. Lasati butonul o fractiune de secunda ºi ÎmpingeÞi-l din nou ºi menÞineÞi apãsat pentru aproximativ 5 - 10 secunde pânã ce o noua data apare În fereastra de jos. Apoi, puteÞi lua contactul.
6. Dacã doriÞi sã resetaÞi "Service" la Ulei de motor, Placute de frana, Filtru de aer Microfilter de frânã sau indicatori, va trebui sã urmaÞi aceeaºi paºi ca secvenÞa 1 ºi 2 , dar când ajungi la pasul 3 ºi apare pictograma de lichid de frânã, luati iar degetul si apasati, cu miscari scurte si ritmice pana apare pictograma din "Service" pe care doriti sa o resetati.
7. PuteĂži continua cu miscari de apĂŁsare a butonului iar cand doriti sa resetati un "Service" mentineti apasat timp de 5 – 10 secunde, pânĂŁ apare din nou cuvântul "RESET?" ca ĂŽn pasul 4 de mai sus. DupĂŁ ce cuvântul "RESET?" a aparut, trebuie sĂŁ elibereze butonul o fractiune de secunda Âşi ĂžineĂži-l din nou apasat aproximativ 5 - 10 secunde pânĂŁ când "Service"-ul se ĂŽnlocuieÂşte cu nou interval de serviciu (ca pe pasul 5 de mai sus).
Sugestii & Sfaturi
Ănainte de resetarea propriuzisa,nu faceti nimic, trece prin paÂşii de la 1, 2 Âşi 6 de mai sus pânĂŁ când va sunt familiari (Âşi siguri),cu ceea ce vreti sa resetati. Practicati de câteva ori Âşi retineti ordinea pictogramelor ce apar dupĂŁ iniĂžiale de "Service".
Dacã se Întâmplã sã ÞineÞi butonul prea mult timp apasat pe un element nu doriÞi sã-l resetaÞi ºi "RESET?" apare, doar lasati singur butonul timp de 10 secunde (Sau luati si puneti din nou contactul pornind iar de la zero).
Uneori, dacã nu a-Þi lasat ºi apãsat din nou butonul suficient de repede, atunci când vã poate aparea alt meniu(1-21) undesunt date tehnice ale masinii cum ar fi numarul de sasiu, temperatura apei, consumul, etc. In acest caz incepeti iar de la zero
pentru cei care nu stiu engleza.
Din cate am citit in forumuri de afara, senzorii la placutele de frana nu trebuiesc resetetati, decat daca pui un senzor NOU. daca faci greseala sa resetezi senzorul si nu e nou, se intampla la fel ca la tine, si poti sa arunci la gunoi senzorul si sa mergi asa pana se duc placutele de tot, sau daca placutele sunt relativ noi, sa pui un senzor NOU.
Alt detaliu demn de tinut cont este faptul ca trebuie resetate in ordine si anume, resetat mai intai cel de pe spate si apoi cel de pe fata(in cazul in care schimbi cu aceasi ocazie placutele fata/spate).
Si nu trebuie resetat pana nu ai ambii senzori montati.
Edited by livio
