TV + Rear camera + GPS (IGO 8) pt modelel cu iDrive
Salutare
Pt ca in Romania (cat si pe forum) sunt foarte multi posesori de modele cu idrive (indiferent de varianta) m-am gandit sa aduc in atentia voastra o ''scula'' care ne cam salveaza de prinicpalul dezavantaj al iDriveul-ui: lipsa GPS detaliat pt tarile din Europa de Est si redarea video.
Cautand pe internet am gasit la vecinii unguri un site care vinde asa ceva.
Mai jos aveti cateva poze cu interfata respectiva la care puuteti conecta:
- box GPS pe care sa instalati IGO8;
- camera pt mersul inapoi;
- TV;
- DVD/Divx Player;
- PS2
etc.
Deocamdata alte info nu am in afara de ceea ce gasiti pe site-ul lor. Tot acolo veti vedea si niste filme cu ceea ce poate afisa idriveul dupa atasarea respectivei interfete.
post-2079-1231947953_thumb.jpg post-2079-1231947974_thumb.jpg post-2079-1231947992_thumb.jpg
http://autohifidiszkont.hu/bmw-tuning.hu/
Una alt site din UK, ofera un produs similar:
http://www.xcarlink.co.uk/product.php?prod...t=16&page=1
Features are as follows:
* Watch any Video source on your original Factory fitted Screen. Can be used with both BMW 8.8" and 6.5" Monitors
* Easily switch to the desired video source using the included toggle switch, or connect to BMW CAN bus, and switch over by holding the iDrive control for more than 1 second.
* Two display modes on 8.8” monitor [16:9/ultra wide]
* De-interlacing video processing for PAL/NTSC/SECAM video with Automatic PAL/SECAM /NTSC selection
* High quality image processor makes PAL/SECAM 625-line image displayed on BMW original 240-line screen without picture distortion or line cropping
* OSD shows the input channel and interface status.
* Automatic rear view camera input switch and Navigation talkover switch.
* 3 Video AV inputs
* Anti-audio-POP noise in audio input selection
* 2 RCA video outputs for rear seat entertainment
The kit includes the following:
* Multimedia Main interface
* I-Drive monitor connection cable
* 3 X AV Input connectors (for connecting video source)
* Rear Camera Connection
* Audio Output cable
* RGBS for adding a Satellite navigation GPS unit
* Toggle switch (can be placed anywhere on the dash)
* User Manual
The Multimedia interfaec is an a plug and play vido interface, it works simply by interupting the singal from the iDrive control when you press the toggle switch or hold down the iDrive control for more than 1 second. Installation involves removing the original connector on the back of your iDrive screen and connecting it to the interface, then connect the supplied from the video interface back into your iDrive screen. Then connect 12v pwer, ACC and Ground, and connect the devices that you want to view on your idrive screen. Sound is provided by connecting the interface to the Aux input.
Compatibility:
Compatible with BMW 5 Series (E60/E61) 6 Series, 7 Series (E90) and X50 with Idrive System.
Specifications
* BATT/ACC range : 7V~25V
* Power : 0.3A @12V
* Video input/output: 0.7V~1V
* Audio input : 0~5Vpp
* Audio output : 4Vpp max.
* Video input formats: PAL B.G.D.K.I / SECAM /NTSC
Din ce m-am mai interesat se pare ca BOX-ul GPS se comanda printr-o telecomanda si nu prin Idrvive si foloseste monitorul iDrvive doar pt afisare; in gen NavNGO Limousine:
http://www.navngolimousine.com/
Iata IGO functionand pe Idrive :)
Edited by paulgsm
  • Replies 158
Am scris in primul post: ''BOX-ul GPS se comanda printr-o telecomanda si nu prin Idrvive si foloseste monitorul iDrive doar pt afisare; in gen NavNGO Limousine''.
E cam incomoda solutia ... dar asta e. Cel putin asa am vazut intr-un videoclip de pe Youtube (aveau o telecomanda si in alt video .... un mouse wireless ) pe consola dintre scaune.
In primul videoclip de aici: http://autohifidiszkont.hu/bmw-tuning.hu/tipusok/e90.htm se vad 2 telecomenzi !
Pretul este 74.900 forinti adica 1145 RON ... adica 267 euro.
Edited by paulgsm
dar daca am lua-o pe cea de pe site-ul englezesc am iesi mai ieftin ... undeva la 170 de euro ... plus ca daca am lua in grup sunt sigur ca ne-ar face un mic discount si am imparti si transportul ...
nu era pretul in lire sterline?
pai 150 lire ... euro undeva la 4,3 iar lira undeva la 4,7 cam pe acolo e ... 170 euro ... cu rotunjiri mari.
eu cred ca o sa imi comand. dupa ce il am in mana o sa vad eu ce si cum ...
cine face primul pas?? , eu daca-l vad pus pe o masina in secunda 2 imi comand si eu
eu am luat un xcarlink pt audi a3 al sotiei, sunetul este extraordinar, montajul este foarte usor, l-am instalat in 20 min
au o reprezentanta si in romania - www.wcarlink.ro si asteptam sa aduca si pt bmw produsul, insa nu a aparut
e ciudat ca a aparut pe site-ul asta englezesc pt ca produsul pt bmw nu a aparut nici acum pe site-ul producatorului - xcarlink.com....bmw e la "coming soon" de vreo 8 luni :)
poate nu au auctualizat site-ul!
oricum poza e de e46 de la "coming soon"
da, ma rog, e ciudat ca nici aia si nici astia din romania nu si-au actualizat site-ul in conditiile in care cerere cred ca exista la greu...in fine, eu mai astept sa il iau direct din romania
pe ala de audi a3 am dat 4,2 milioane si mi-a sosit in 2 zile cu curier
pai asta ar fi interfata la care vom adauga ulterior dvd player, camera, navi, tv, etc ... e doar modulul de legatura cu celelalte aparate. produsul vine cu toate elementele pentru a fi montat. dupa ce avem asta incepe distractia. le-am trimis un mail celor din anglia sa mai imi dea cateva detalii. astept raspuns.
in ce loc le montam si de unde cumparam navi ?sau merge orice gps?
cum e treaba cu tv? ce trebuie cumparat? :)
Trebuie cumparat si modul tv (daca produsul vandut de Xcarlink nu are incorporata si functia de TV) si cel GPS; aparatul este doar o interfata intre diverse module si displayul Idrive.
Voi reveni maine cu, cateva fotografii ale unu GPS BOX-uri ce se leaga la acest modul.
Pana atunci aveti mai jos un videoclip cu un GPS box conectat la un display:
GPS Box in actiune pe un BMW 335 - E90 si un seria 5, E60
- aici se vede in sfarsit cum se controleaza cursorul de pe ecran ... printr-un touchpad aflat pe o telecomanda ....
Asta e siteul celor care produc (sau vand) GPS BOX-ul din linkul de mai sus (cel cu touchpad):
http://navbras.com/gps_box.html
Traducerea siteului brazilian: http://translate.google.com.br/translate?u...BR&ie=UTF-8
Edited by paulgsm
