[Vand] Pachet piese - Noi - mecanica, telescoape, etc. BMW E46 / E36
evlmaster
nu este cu cod avand in vedere ca masina este din 93 , imi trebuiesc incuietorile cu clape pt ca este un intreg nedemontabil si contact-ul (toate sa aiba aceasi cheie ) am luat de la altcineva incuietorile cu contact-ul insa un destept a stricat contac-ul fara sa se uite la sistemul de prindere la contact 0766 56 37 36 Edited by sfantu007
  • Replies 406
Salutare
Sfantu 007- cer scuze pt intarziere , astazi am primiti preturile:
BMW E36 318i,an: 1991,serie sasiu: WBACA31040EG47627
1 Buc. Butuc contact cu cheie 133,68 133,68
parte mecanica
OE
Livrabil depatament central
1 Buc. Maner exterior usa stg fata pt 491,86 491,86
model cu cheie fara cod
OE
Termen mediu livrare 4 zile lucratoare
Poz. 1
1 Buc. Maner ext usa dr fata model fara 390,94 390,94
inchidere centralizata
OE
Livrabil din DEP.BUCURESTI CENTRAL
RON 1.150,48
Fara TVA
Au sosit pe STOC pe stoc din America embleme tuning - calitate OE cu part number OE:
- HAMANN(3 PIESE/PORTBAGAJ/CAPOTA/VOLAN -ADD ON) -220 RON
- AC SCHNITZER (3 PIESE/PORTBAGAJ/CAPOTA/VOLAN -ADD ON) -220 RON
- BMW CARBON NEGRU(3 PIESE/PORTBAGAJ/CAPOTA/VOLAN -ADD ON) - 220 RON
- BMW CARBON ALBASTRU (3 PIESE/PORTBAGAJ/CAPOTA/VOLAN -ADD ON) - 220 RON
Exista embleme disponibile E46/E36
Hood Emblem Diameter = 82MM Fit BMW all models
Part # 51.14-8 132 3
Trunk Emblem Diameter = 82MM, 78MM or 73MM
73mm Part # 51.14-8 219 237 fits: 2007+ E87 1-series hatchback
(OEM replacement parts)
1999~2005 E46 3-Series Sedan & Coupe
2001~2006 E46 M3 Coupe
2006+ E90/E91 3-Series Sedan & Wagon
Z4 Hood (Slightly modification required)
78mm Part # 51.14-8 203 864 fits:
1997~2003 E39 5-series include E39 M5
(OEM replacement parts) BMW 8-Series.
2001~2005 BMW E65 7-Series
2000~2006 BMW X5
BMW Z3 side emblem (Slightly modification required)
82mm Part # 51.14-8 132 375 fits:
1993~1998 E36 3-Series Sedan & Coupe
1995~2000 E36 M3 Coupe
1988~1991 E30 M3 Coupe
1988~1995 E34 5-series Sedan
1989~1996 E34 M5 Sedan
2004+ E60/E61 5-series Sedan & Wagon
2006+ E60 M5 Sedan
2004+ E63 6-Series Coupe (Slightly modification required)
2004+ E63 M6 Coupe (Slightly modification required)
2009+ E66 7-Series Sedan
2006+ E65 7-Series Sedan (Slightly modification required)
1988~2000 E32 & E38 7-Series Sedan
2007+ X5 (Slightly modification required)
2004+ X3 (Slightly modification required)
Z4 (Slightly modification required)
Z3
__________________________________________________________
Radu
0763041741
0771461268 / 0348430486
0724223552
0751897607
office@auto-pit.ro
Edited by evlmaster
Buna seara,
Am comandat acum o saptamana in drum spre Romania o cantitate mai mare de fulii de acest gen:
fulie vibrochen dubla masa: E46 Diesel- marca VAICO germany: 580 ron cu tot cu TVA.
Astept confirmarea dumneavoastra, maine ar trebui sa soseasca curierul UPS cu marfa.
Va multumesc.
Radu
0763041741
0724223552
0751897607
office@auto-pit.ro
Buna seara,
Va multumesc.
Radu
0763041741
0724223552
0751897607
office@auto-pit.ro
problema este ca nu stiu daca la mine este cu dubla masa si nu as vrea sa pun ceva care sa solicite mai mult alte componente.
salutare,
Nicu-Florin,
FULIA ESTE CEEA CE ESTE MONTAT LA DUMNEAVOASTRA PE MASAINA(exact ceea ce vine pe original de aceea am si specificat)- ACEASTA ESTE DENUMIREA TEHNICA A ACESTEI FULII-- rolul acestei fulii este sa balansezei si sa echilibreze motorul diesel de aceea are masa dubla compensatorie.
Pentru comanda - tinand cont ca ati mai comandat de la mine voi face un discount aditional cu tot cu transport.
va multumesc.
Radu
0763041741
0724223552
0751897607
office@auto-pit.ro
PROMOTIE PENTRU TOTI USERII Bmwclub
ULEIURI ORIGINALE BMW, CASTROL, MOBIL, MOTUL ETC- LA CELE MAI MICI PRETURI
- ULEI ORIGINAL BMW 5W30 LL04 - 36 RON/ LITRUL(TVA INCLUS!!!)- STOC NELIMITAT
- ULEI ORIGINAL BMW 5W40 - SUPER POWER OIL- LL98- 30 RON/ LITRUL(TVA INCLUS!!!) - STOC NELIMITAT
[b]OFERTELE SUNT EXTINSE PENTRU TOATE TIPURILE DE ULEI BMW ORIGINAL & AM VA ROG sa consultati lista de preturi atasata!!
- PASTA PENTRU RESTAURAREA ELEMENTELOR DE CROM, CHEDERE, GRILE(INTERIOR , EXETERIOR) OEM PART NO. 82149400890 : 30 RON
Va multumesc tuturor pentru interes,
Radu
0763041741
0724223552
0751897607
office@auto-pit.ro[/b]
AUTO_PIT_OFERTA_ULEIURI.doc
Edited by evlmaster
UP CU MARFA DE CALITATE!!!!
REDUCERI PENTRU EMBLEMELE DE MAI SUS!!!!!!!!
- HAMANN(3 PIESE/PORTBAGAJ/CAPOTA/VOLAN -ADD ON) -179 RON
- AC SCHNITZER (3 PIESE/PORTBAGAJ/CAPOTA/VOLAN -ADD ON) -179 RON
- BMW CARBON NEGRU(3 PIESE/PORTBAGAJ/CAPOTA/VOLAN -ADD ON) - 179 RON
- BMW CARBON ALBASTRU (3 PIESE/PORTBAGAJ/CAPOTA/VOLAN -ADD ON) - 170 RON
2000~2006 BMW X5
2006+ E60 M5 Sedan
Z3
Radu
0763041741
0724223552
0751897607
office@auto-pit.ro
Niste preturi pentru: bieleta antiruliu st/dr; placute de frana fata ? E46 2004 diesel 150 CP
Mersi
Lemforder - 105
Swag - 75
Delphi - 82
Febi Bilsten - 84
TRW - 105
Mog - 87
PowerDrive - 83
Toate preturile de mai sus au TVA inclus.
Activ Business
Auto-Pit
Calea Craiovei,
Bloc P4, parter
zip code: 110432
Pitesti, Romania
0763 041 741
0771 461 268
0771 461 263
0348 430 486
0348 430 487
www.auto-pit.ro
Pai si pt placute de frana? Set ma interseaza.
Mersi
Set placute frana disc - fata :
-Ate - 170 (fara lacas senzor uzura)
-Textar - 190 (cu lacas senzor uzura)
-Zimmerman - 140 (cu lacas senzor uzura)
-Trw - 115 (fara lacas senzor uzura)
-Bosch - 140 (cu lacas senzor uzura)
-Valeo - 130 (cu lacas senzor uzura)
-Ad Products -120 (nu este precizat daca are senzor sau nu )
-LPR - 90 (cu lacas senzor uzura)
-Pagid - 160 (cu lacas senzor uzura)
Toate preturile au TVA inclus.
Activ Business
Auto-Pit
Calea Craiovei,
Bloc P4, parter
zip code: 110432
Pitesti, Romania
0763 041 741
0771 461 268
0771 461 263
0348 430 486
0348 430 487
www.auto-pit.ro
Suspensie spate pt GX35498,senzor ulei,ulei pt cutie si motor si filtre..un pret si un timp de livrare?
Pentru ce masina sunt piesele respective , pentru identificare corecta a reperelor am nevoie de .
Model :
An :
Kw :
Cc :
Serie Sasiu : (ultimele 7 cifre ex. GU42915)
Multumesc anticipat.
Model :
An :
Kw :
Cc :
seria la sasiu am scris GX35498,530D,AN 2000
Model :
An :
Kw :
Cc :
Imi cer scuze mesajul acesta era destinat altcuiva . O sa va dau preturile in 5 minute.
Model :
An :
Kw :
Cc :
Senzor Ulei :
-Facet - 28
-Hella - 28
-Intermotor - 22
Filtre Mann:
-aer - 95
-ulei - 31
-combustibil - 80
-habitaclu - 193
Ulei Motor :
-Castrol Magnatec diesel 5W40 1L - 30
--Castrol Magnatec diesel 5W40 5L - 130
-Catrol EDGE turbo diesel 5W40 1L - 33
-Catrol EDGE turbo diesel 5W40 5L - 145
-BMW ORIGINAL POWER FLOW 1L -5W40 LL98 /A3/B3/B4 - 30
Termen de livrare 1-2 zile lucratoare de la comfirmarea comenzii.
Pentru uleiul de cutie automata deocamdata nu am pret o sa revin cu un post reply.
Preturile au TVA inclus.
Doar senzorul Hella ma intereseaza din lista deocamdata(sper ca e cel de pe baia de ulei nu?)...astept pret pt toata suspensia spate,vad ca nu ai cautat...ulei cutie doar daca ai si setul cu filtrul si garnitura baia,daca nu ai,caut in alta parte,multumesc frumos deocamdata
Anumite repere din cererea facute de tine le-am putut gasi pretul in programul furnizorilor, la cele care nu ti-am dat pret astept mail de la furnizori . Cand o sa primesc preturile o sa le postez.
O zi buna
