[Vand] Pachet piese - Noi - mecanica, telescoape, etc. BMW E46 / E36
Salutare ROBERT,
ai mai jos ce contine + GARANTIE 3 LUNI- PRNTRU ORICE PIESA - SE SCHIMBA CU UNA NOUA IN 24H!!!
PACHET 8 piese NOI MECANICA +DIRECTIE BMW E46, E36:
-1 buc. BRAT+Pivot dreapta fata
-1 buc. Brat +Pivot stanga fata
-1 buc. Bucsa dreapta brat fata
-1 buc. Bucsa stanga brat fata
-1 Buc. Bieleta directie+ capat bara dreapta
-1 Buc. Bieleta directie +capat bara stanga
-1 Buc. Bieleta antiruliu stanga fata
-1 Buc. Bieleta antiruliu dreapta fata
MERCI
RADU
0724223552
0751897607
  • Replies 406
  • Views 95.3k
SALUTARE GEO,
REVIN CU OFERTA DE MAI JOS- CEA MAI BUNA CALITATE!!
Merci. te astept cu mare placere.
OFERTA SACHS!!!!!
OFERTA SUSPENSIE COMPLETA SACHS
BMW SERIE 3 E46- AN FABRICATIE 1999-2005
TELESCOP FATA – 285 RON/BUC - SACHS
TELESCOP SPATE– 195 RON/BUC - SACHS
FLANSA TELESCOP FATA– 85 RON / BUC – SACHS
FLANSA TELESCOP SPATE – 50 RON/BUC - SACHS
KIT PROTECTIE COMPLET AMORTIZOR FATA -65 RON/ SET - SACHS
KIT PROTECTIE COMPLET AMORTIZOR SPATE – 65 RON / SET - SACHS
PRODUSELE SUNT NOI!!!
Pret: 1490 LEI
SAU SAPTAMANA VIITOARE PE GERMANIA:
- 380 ron - SET AMORTIZOARE FATA E46
RADU
0724 223 552
0751 897 607
REDUCERI DE PRIMAVARA!!!
PACHET 8 piese NOI MECANICA + DIRECTIE BMW E46,E36:
-1 buc. BRAT + Pivot dreapta fata
-1 buc. Brat + Pivot stanga fata
-1 Buc. Bieleta directie + capat bara dreapta
-1 Buc. Bieleta directie + capat bara stanga
Pachet doua TELESCOAPE SPATE BMW E46, E36:
- telescop gaz stanga spate
-Telescop gaz dreapta spate
Pret Pachet piese E46: 1250 RON
Pret Pachet piese E36: 900 RON
Pret Pachet telescoape SPATE E46/E36: 299 RON - set 2 bucati
Pret Pachet telescoape FATA E46/E36; 400 RON - set 2 bucati
RADU
0723 223 552
0751 897 607
Salut. Am un bmw 318i an 1997 luna 12 M43. Masina are 240.000 km acum. Ma intereseaza un ulei bun de motor(cati l intra in motor?) , filtru ulei, ulei cutie pt ca este hidramat, filtru benzina, si un pret pt discuri frana fata- spate cu placute. Ms.
salutare prietene,
am si eu nevoie de o serie completa de caroserie si te pot informa cu toate detaliile de care ai nevoie, cantitati de umplere, uleiuri folosite pentru motorul tau, indicative si multe alte detalii,,etc
maine vei primi toate raspunsurile supa ce primesc informatiile necesare
multumesc
Radu
0724223552
0751897607
Salutare,
Piesele solicitate:
- filtru ulei MOTOR- mann....................25 ron Knecht Mahle
- kit filtru ulei cutie hidramata.............95 ron SWAG
- filtru benzina..................72 ron Knecht
- FILTRU BENZINA MANN- SERIE:WK 516/1- INCEPAND CU AN FABRICATIE 09.94 .....91RON
- discuri frana fata + spate- AM- ATE .....................fata 2x130 ron................spate 2x115 ron
- placute frana fata + spate -AM- ................fata RH 105/Textar 140 ron........................spate RH 75,Textar 117 ron
- filtru aer-...............55ron Knecht
- FILTRU HABITACLU- MANN- MODEL CU2835- 78 RON
AI PE MASINA CUTIE DE VITEZE MODEL: A4S 310R - CANTITATE DE UMPLETE 8,8 LITRI
ULEI MOTOR DISPONIBIL PE STOC:
- CASTROL EDGE:5W40 EDGE 1LT- 35 RON/LITRUL- SINTETIC
- MOBIL 1 NEW LIFE 0W40/4LT -170 RON - SUPER SINTETIC/GERMANIA- UN PIC SUBTIRE LA PORNIRE DAR CU PROPRIETATI SUPERIOARE DUPA INCALZIRE
- MOBIL SUPER 3000 X1- 5W40/4LT- 120 RON - SINTETIC
- ULEI CUTIE VITEZE: DEXTRONII/III- CASTROL 35 RON/LT
CantitĂŁĂži de umplere Âşi specificaĂžiiUlei de motor cu filtru
4,00 litri
Specificare ulei de motor
VariantĂŁ 1 BMW Longlife-04
VariantĂŁ 2 BMW Longlife-01
VariantĂŁ 3 BMW Longlife-98
Transmisie manualĂŁ
Cutie de viteze S5D 200G Cutie de viteze S5D 250G, Cu reumplare 1,10 litri
Cutie de viteze S5D 200G Cutie de viteze S5D 250G, Cantitate de schimb 1,00 litri
Cutie de viteze S5D 260Z Cutie de viteze S5D 310Z, Cu reumplare 1,30 litri
Cutie de viteze S5D 260Z Cutie de viteze S5D 310Z, Cantitate de schimb 1,20 litri
Transmisie automatĂŁ
Cutie de viteze A5S 300J Cutie de viteze A5S 310Z, Cantitate de schimb 3,00 litri
Cutie de viteze A5S 300J Cutie de viteze A5S 310Z, Cu reumplare 7,80 litri
Cutie de viteze A4S 270R Cutie de viteze A4S 310R, Cu reumplare 8,80 litri
Cutie de viteze A4S 270R Cutie de viteze A4S 310R, Cantitate de schimb 3,00 litri
SpecificaĂžie ulei transmisie automatĂŁ
> Ulei original
DiferenĂžial osie spate
Ax 168N 1,10 litri
Ax 188N 1,70 litri
SpecificaĂžie ulei osie spate
> Ulei original
ServodirecĂžie
1,20 litri
Specificare ulei servodirecĂžie
DirecĂžie cu cremalierĂŁ ZF
Uleiuri prin BMW distribuĂžia pieselor
Numele comercial Culoarea uleiului NumĂŁr de pieseĂŁ BMW Ambalare
Ulei cutie automatĂŁ de viteze BMW RoÂşu 81 22 9 400 272 1 litri
Pentosin CHF 11S Verde 83 29 0 429 576 1 litri
Recipientele de ulei pentru uleiul hidraulic au un marcaj pe marginea recipientului de ulei, care indicĂŁ ce tip de ulei poate fi folosit.
Lichide de rĂŁcire
6,50 litri
Specificare lichid de rĂŁcire
> Etilen-glicol
Lichide de frâna la schimbare
1,20 litri
Specificare lichid de frânã
DOT 4
Agent de rĂŁcire instalaĂžie de climatizare
Condensator cu tub circular 975 - 1025 Grame
Condensator cu tub plat 800 - 850 Grame
SpecificaĂžie agent de rĂŁcire
R 134a
Pentru datele de service- BMW 318I/E36/M43
Interval de ĂŽnlocuire a filtrului de aer
la fiecare 2. Service
Interval de ĂŽnlocuire a filtrului de combustibil
la fiecare 2. Service II
Interval de schimbare a lichidului de frânã
la fiecare 2 ani
Interval de schimbare a agentului de rĂŁcire a motorului
pânã la 1994/08 la fiecare 2 ani
de la 1994/09 la fiecare 3 ani
Interval de schimbare a uleiului transmisiei manuale
Interval de schimbare a uleiului transmisie automate
Interval de schimbare a uleiului transmisiei osiei posterioare
Interval de schimbare a uleiului de motor Âşi a filtrului
la fiecare service
Interval de ĂŽnlocuire a filtrului de habitaclu
la fiecare service
MULTUMESC ANTICIPAT
RADU
0724223552
0751897607
Salut Radu,
Fa-mi o oferta pentru un pachet de mecanica la un e46 316i si ce producator au piesele.
Un review de la cei ce au cumparat acest pachet ?
Mersi.
salut, sunt interesat de cele 2 brate pentru partea dreapta, cel superior cu tot cu bucse si cel inferior + cap de bara si bieleta antiruliu pentru e39 2003, ultimele 7 de caroserie GW71310. mersi!
Salutare,
BTU
pentru e46 316:
PACHET 8 piese NOI MECANICA + DIRECTIE BMW E46,E36: MARCA ATP GERMANY(ECHIVALENT MAYLE HD)
-GARANTIE PE MAGAZIN CU PIESA NOUA LA SCHIMB- 3 LUNI DE ZILE PENTRU ORICE PIESA DIN PACHET
-GARANTIE PACHET 1 AN CU DOCUMENTE DOVEDITOARE DE MONTAJ : CONSTATARE +MONTAJ
PRET PACHET :1250 RON
Sorin7650
pentru :BMW serie 5, e39, 2003, ultimele 7 de caroserie GW71310 - 06/2003 E39 525d Sedan M57 Europe Left hand drive
- brat superior cu tot cu bucsa...................470 ron Lemforder.................265 ron SWAG
- brat inferior..................410 Lemforder....................230 ron Swag
Multumesc anticipat,
Radu
0724 223 552
051 897 607
Edited by evlmaster
un pret pt telescoape fata+ telescoape spate ! eventual si preturi separate doar pt fata sau doar pt spate! masina BMW E46 320D NFL
ms anticipat
Edited by Micutzu™
Salutare Micutzu,
Multumesc
radu
0724 223 552
0751 897 607
OFERTA SACHS!!!!!
KIT PROTECTIE COMPLET AMORTIZOR FATA -85 RON/ SET - SACHS
KIT PROTECTIE COMPLET AMORTIZOR SPATE – 80 RON / SET - SACHS
OFERTA TELESCOAPE ECD/ATP!!!
SET TELESCOAPE FATA BMW E36/E46/ECD/ATP: 400 ron(SET 2 BUCATI)
SET TELESCOAPE SPATE BMW E36/E46/ECD/ ATP: 300 RON(SET 2 BUCATI)
RADU
0724 223 552
0751 897 607
Edited by evlmaster
SALUTARE,
PACHET MECANICA COMPLET ATP GERMANY(GARANTIE ORICE PIESA 3 LUNI- PIESA NOUA LA SCHIMB): E46 + FILTRU BENZINA MANN: PRET TOTAL(INCLUSIV TRANSPORT):1290 RON
MAINE SE VA FACE LIVRAREA , CONFORM ADRESEI FURNIZATE CU URGENT CURIER.
MERCI
RADU
0724223552
0751897607
Salutare,
Piesele solicitate:
4,00 litri
Transmisie manualĂŁ
> Ulei original
Ax 168N 1,10 litri
Ax 188N 1,70 litri
> Ulei original
ServodirecĂžie
1,20 litri
Lichide de rĂŁcire
6,50 litri
> Etilen-glicol
1,20 litri
DOT 4
R 134a
la fiecare 2 ani
la fiecare service
la fiecare service
MULTUMESC ANTICIPAT
RADU
0724223552
0751897607
Multumesc pt informatii.
Cum am bani te sun pt comanda.
Salutare,
Piesele solicitate:
4,00 litri
Transmisie manualĂŁ
> Ulei original
Ax 168N 1,10 litri
Ax 188N 1,70 litri
> Ulei original
ServodirecĂžie
1,20 litri
Lichide de rĂŁcire
6,50 litri
> Etilen-glicol
1,20 litri
DOT 4
R 134a
la fiecare 2 ani
la fiecare service
la fiecare service
MULTUMESC ANTICIPAT
RADU
0724223552
0751897607
multumesc pentru seriozitate !!! am montat piesele pe masina. sunt ok !! totul sa potrivit cum trebuie . piese de calitate ,pret bun,om serios. RECOMAND .
cat costa un debitmetru pentru bmw E46 316i 99 - 1895 cm ..Bosch Nou ?
Salutare,
Au sosit din Germania Saptamana trecuta/ pe stoc:
- Debitmetru ATEC - garantie 1 an / 3 luni (cu piesa noua a schimb) - 300 ron
- Debitmetru Bosch original: 820 ron / cod bbmw original:13621433565
multumesc
Radu
0724223552
0751897607
Sal Radu.
Catalizator universal euro2 pt bmw 318i an 1997, motor m43, turing.
Ms.
salut Radu . imi dai un pret pt bratul de pe dreapta bmw e46 320d ....ma lasat bucsa....mersi (a montat amortizoarele pe e 36, nu a fost nici o problema, sa vedem cum se comporta)
Salutare,
timtara - pot sa -ti fac o oferta supr buna , dar am nevoie de serie se sasiu!
adryan89- pentru un client vechi, caruia trebuie sa-i multumesc pentru numeroasele recomandari in Sibiu,
- brat dreapta fata - VAICO- NOU+GARANTIE- 400 RON(TRANSPORT INCLUS)
va multumesc pentru interes,
radu
0724223552
0751897607
Edited by evlmaster
salut,
ma intereseaza senzorii de la axele cu came, admisie si evacuare precum si sonda lamda, inainte de catalizator. VIn : JV70195.
Merci,
