statie radio
dau statie radio la schimb cu piese si accesori bmw e36 320 sedan.astept oferte! stima!
Cati wati are?
Channels Refer to programmed band
Modes (AM, FM) Refer to programmed band
Operating Temp. -10°/+55°C
DC Input Voltage 13.2Vdc ±15%
Size 180(L) x 50(H) x 153(D) mm
Weight 1 Kg
TRANSMITTER
System CPU Controlled PLL
Synthesizer
Max Output Power 4W at 13.2Vdc
Modulation AM (from 85% to 95%)
FM (1.8 KHz ±0.2 KHz)
Output Impedanced 50 Ohm unbalanced
Current Drain 1100 mA (at no modulation)
RECEIVER
System CPU Controlled Double
Conversion Super
Heterodyne
IF 1° 10.695 MHz / 2° 455 KHz
Sensitivity 0.5µV for 20dB SINAD (FM)
0.5µV for 20dB SINAD (AM)
Audio Output Power @10% THD 2.5W at 8 Ohm
Audio Distorsion <8% at 1 KHz
Image Rejection 65dB
Adjacent Ch. Rejec. 65dB
Signal/Noise Ratio 45dB
Current Drain 250mA (stand-by)
nu era utila? de ce o dai?
poi mai am una in plus, ca tata a fost sofer pe TIR si am avut vreo 3 stati acum intelegi?:) stima!!!
un pret pentru statie?
nu stiu frate ce sa zic, eu asi prefera sa o dau la schimb pe un casetofon sau un GPS cva! in bani...depinde cat oferi? stima!!!
300 ron
300 ron
350 ron si facem tranzactia, ca e aproape 6 mil in magazin si e k noua stima!!!
  • 2 years later...
ce zici de 4 jante de aluminiu id meu daca vrei sa vezi jantele este gyxydan@yahoo.com
ce jante ai ,poate ti le cumpar eu si tu ii dai banii ?
