e60 schimb ulei problem.
raulitos
salutare, am schimbat uleiul la service si baietii n-au stiut sa-mi zica cum sa resetez si pe navigatie in bord, din cate am inteles trebuie sa ti apasat pe butonul din bord 10 secunde si apoi?
multumesc.
Resetarea in meniul service :
To enter this mode, with ignition on, hold the odo reset button (located on the left side of the instrument panel under the tach) for about 10 seconds.
The center of the info display will change to "service". It will have an icon for which service feature and the miles/date left until service is required. These icons are the same as displayed on the I-drive service screen. So, you can go through the Idrive service screen to get familiar with the icons prior to doing this.
Once in this mode, push the reset button to cycle through the various service items.
To reset a service item that is displayed, hold the reset button. I don't remember how long, but the display will change to a reset mode. You must release the button once it enters this reset mode. Then you will need to confirm the reset by pressing the reset button again.
The reset service interval will then be changed.
You can continue pressing the reset button to scroll through the other icons.
I think to exit, I simply shut off the ignition.
As with the previous post, be careful not to reset something you did not intend to. It is kind of hard to do this as you enter the reset function, then you must confirm it.
