Everything posted by oli
Vas expansiune fisurat!
si eu am patit-o in primavara...61 de euro de la autonet orijinal.
Jante Bmw - pareri
de unde ati luat replicile? vreun site in ro?
localizare central locking computer
ma esti sigur?...o sa ma uit maine pe acolo sa vad ce pot face...poate gasesc si ceva manusi pe acolo ca niciodata nu m-am uitat io foarte atent ce-i pe acolo... merci
am gasit si chestia cu cheia. o reprogrameaza dupa ce schimba computeru ala..uite aici e in engleza ce trebuie sa faci When you have the crazy door unlocking problem chances are big you need to replace the door locking computer. This computer is located behind the glovebox compartment. Removing 5 screws will remove the glovebox compartment. In a white tray you will see the top tray is filled with a white box with three cables. Replace this computer with a used or new computer. Now reprogramming your new computer: - Make sure all doors are unlocked. - Go sit inside your car. - Close all doors. - Set ignition key to position 1 (no more then 5 seconds) and switch off (now system is ready for initialisation. Start initialising keys within 10 seconds from here) --key one-- Keep unlock key pressed while pressing lock key 3 times and let go of the unlock key. (the doors will lock and unlock when succesful otherwise start over) --key two-- Keep unlock key pressed while pressing lock key 3 times and let go of the unlock key. (the doors will lock and unlock when succesful otherwise start over) - Set ignition key to position 1 or any other position will end initialisation process. It worked for me and keys are programmed and my doors are unlocking again and in costs me 30 minutes and 50 euro for the computer. no asa se face cu cheia. da io vreau sa vad unde e computeru ala. cica in spatele compartimentului pentru manusi..in traducere directa. la ce zic astia compartiment pentru manusi? io niciodata nu mi-am pus manusile in vreun compartiment.....
nu e de la cheie..e de la Modulul general de control care tre sa-l gasesc. cred ca sint nishte lipituri reci care trebuie reparate. am tot citit pe forumuri in state si sunt o gramada de tilizatori de BMW care au problema asta. am mai deschis un topic cu aceasta problema asa ca nu o mai aduc in discutie aici. ideea e ca se poate repara baiu cu inchiderea centralizata care merge cum o duce capu inlocuind modulu ala de control si e 329 euro + manopera sau sa-l iei si sa-l verifici de lipituri si contacte. chestia e ca tre localizat ceea ce fac io acuma. ma chinui sa localizez cacatu ala de modul.
E46 :: 318i :: 12/2000
Ce naiv am fost
se fura si se zgarie... mie mi-au zgariat-o pe ambele parti intr-o noapte in fata casei pe Albini. si tocmai in noapte aia nu am bagat-o in curte...bine ca nu se fura oglinzi ca in bucuresti. asta ar mai lipsi
salut, stie careva unde e localizat "central locking computer". Am problema asta cu inchiderea centralizata care mere si nu mere dupa cum o duce capu. adica ma rog..cum fluctueaza temperatura. acum de cand sa facut frig a luat-o razna. sau daca nu stiti macar un cod al piesei. merci
probleme cu inchiderea centralizata
exact asa si la mine...aleator nu mai merge nici cheia nici butonul de pe consola centrala. si nu am alarma pe masina ca sa fie influentata de antene... oli
au revenit simptomele. aceleasi. e foarte ciudat ca numai cind vine toamna incepe si o tine pana in primavara. vara e perfect..nici o problema...daca mai aveti ceva idei despre ce ar putea fi problema ziceti aici merci
- zgarieturi
zgarieturi
din pacat estau in cluj-napoca asa ca nu ajung prea curind in bucurest..o sa incerc sa rezolv problema aici cumva. merci de informatii
zgarieturi
salut, zilele trecuter mi-am gasit masina zgariata cu cheia pe ambele laterale. toate masinile de pe strada au fost zgariate. oricum asta nu ma incalzeste cu nimic. as vrea sa stiu daca exista vreo solutie la asta..ceva rujuri corectoare sau asa ceva am auzit dar as vrea sa vad daca vreunul dintre voi stie vreo solutie inafara de vopsitul masinii. sgarieturile nu sint foarte adinci, mai mult in stratul de lac merci
reset oil service
am un link aici hxxp://forum.e46fanatics.com/showpost.php?p=3099633&postcount=2 inlocuieste x-uirle cu t si da-i bataie
Arc spate rupt
merci..stiti careva un arc pe partea stanga spate de vanzare? second binenteles
Arc spate rupt
tocmai am aflat ca am un arc de spate rupt...318 E46, 2000. aveti idee cit costa un set de arcuri...? merci
belea de 1 mai
am rezolvat-o..2.200.000 vasul, 600 mii manopera si 200 mii antigelul...vasul e original
belea de 1 mai
pai nu stiam de unde curge si ca sa vedem mai bine ce-i pe acolo a trebuit sa dam si scutu jos..de acolo am inceput cercetarile...scrie-mi te rog ce zice manualul Haynes ca m-as apuca eu sa-l schimb..merci mult
belea de 1 mai
slaut, simbata dimineata am observat o balta pe scutul masinii si m-am panicat. am deschis busonul de la radiator si nivelul era jos de tot. am bagat apa distilata vreo juma de litru si am luat-o la drum sa vad cum se comporta. binenteles toata lumea de care aveam nevoie era plecata din cluj si se intorcea numai marti, adica azi. am facut asa vreo 150 de km, in fiecare dimineata am completat cu o juma de litru antigelul. atita pierdea in 24 de ore. ok. azi am fost la mecanic si dupa ce a dat jos filtru de aer si scutul ca sa aiba acces acolo, echipat cu o oglinda din aia ca la dentist da de dimensiuni uriase am descoperit baiu. in mijlocul vasului de expansiune pe parte dinspre fata masinii iesea un firicel de lichid. deci fara sa=l fi lovit sau ceva de genu asta o crapat. acuma am comandat unul nou...61 de euro de la Autonet. vine luni. asta am scris-o ca sa vedeti ce mai pateste omu de 1 mai...
salut, de o vreme citesc si eu post-urile voastre de aici si m-au ajutat sa inteleg unele chestii. acum am o problema si poate aveti vre-un raspuns..aleator nu mai functioneaza deschiderea centralizata. nici din telecomanda nici din butonul de pe consola de mijloc. adica se inchide masina dar nu se mai deschide decit dupa mai multe incercari. am avut aceeasi problema toamna trecuta dar peste iarna nu a mai aparut si acum de cind s-a incalzit vremea a aparut din nou. daca aveti ceva sugesti cu ce ar putea fi va rog raspundeti-mi... BMW 318i 2000 merci
- bataie pe dreapta
