Mkl
Everything posted by Mkl
  1. Valabil pentru E46 Instructions to access the hidden OBC functions: 1. Hold Trip Reset while turning ignition key to on position 2. OBC should show "Test" 3. Use Trip Reset to select function 19.0 that unlocks all the features 3. Wait for display to show "Off" 4. Depress Trip Reset for 1/4 second and release it 5. With no delay press Trip Reset several times to select one of the following function s ========================================== BMW E46 On-Board Computer (OBC) Hidden Codes nr example description 1 Car Engine and cluster data 1.0 46nnn Chassis nr/VIN serial number (last 5 digits) 1.1 4nnn K-number 1.2 690236 Cluster Part # 1.3 045210 Coding (04)/diagnosis (52)/bus index (10) 1.4 1200 Week (12)/year of manufacture (2000) 1.5 09_160 Hardware (09) and software # (16.0) of cluster 1.6 Not used 1.7 04__44 CAN-version (04) KI-revision index (44) 2 (test) Cluster System Test - Activates the gauge drivers, indicators and LEDs to confirm function 3 SI Data 3.0 1098 Used fuel in liters since last SI (Service Inspection) 3.1 0231 Periodic inspection days; elapsed days (since last SI) 4 Momentary Consumption 4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km 4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour 5 Distance Gone Consumption 5.0 082 Average mileage; 082=8.2 liters/100km 5.1 0536 Calc. km to refuel (momentary distance to go) 6 Fuel Level sensor inputs in liters 6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters 6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters 6.2 0442+ Indicated value (44.2) and tank phase 7 Temperature and Speed 7.0 021+ Coolant/Engine temperature (2.1C) 7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135 7.2 + Engine speed / Current RPMs 1/min 7.3 + Vehicle speed / Current Speed in km/hour 8 Input value in HEX form 8.0 1d0+ System voltage ADC-Value Hex code 8.1 26C33C+ ADC Values HG left/HG right 8.2 0000 ADC Value brake degradation sensor (000=o.k.) 8.3 18C ADC Value outside temperature 9 Battery 9.0 140 Battery Voltage - 140 = UB 14.0v 9.1 242013+? 9.2 074_78+? 9.3 0011+? 10 Not used 11 Not used 12 Not used 13 GonG Gong Test 14 Not used 15 Status cluster I/O-ports (bit codes) 0=low; 1=high 1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0 Status Digital Outputs (bits) 0=inactive, 1=active 1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot 16 Not used 17 Not used 18 Not used 19 Lock Status; unlocks functions in range 3-18 19.0 L-On/L-Off Unlock: press button when "L-Off" 20 Not used 21 Software Reset; reset OBC settings 00 End of test
  2. .. e unu chiar langa radiator(asta e sigur) probabil ca al doilea e pe termostat sau langa el ..iti zic asta pt ca am comandat un senzor si nu era cel care trebuia .. asa ca l am comandat si pe al doilea. Daca vrei mai multe detalii ma pot interesa sa ti spun exact. Am niste intrebari .. pompa de apa circula incontinuu lichidu de racire? iar daca da cum pot vedea asta? cand porneste ventilatoru de pe radiator?
  3. adi_JOL .. 1, 2mm masurati la varfu acului Gim .. cei de pe furtunul de la radiator max83 .. n am verificat, dar cred ca e normal
  4. Salut Am un 318i E46 la care am schimbat printre altele si termostatu' si 2 senzori de temperatura, asta datorita consumului f mare. Consumu' si a revenit, toate bune si frumoase acum, motorul se incalzeste destul de repede iar acul imi sta putin peste jumate. E normal? cum pot vedea cate grade are motoru'(nu am computer de bord)? (firtunu de tur e cald bine, cel de retur frige)
  5. Am rezolvat si relantiul oscilant curatand regulatoru' de relanti si valvula pcv. Bafta si probleme cat mai putine.
  6. Am rezolvat problema cu consumu' schimband termostatul, senzorii de temperatura si bujiile. Bateti campii cu tandrete aia cu dume de mecanici: cu sonda lambda lenta .. bullshit .. ori merge ori nu merge. Debitmetru si sonda daca au ceva apare pe tester sau in bord. Relantiul oscilant inca nu l am rezolvat.
  7. Salut, Am si eu aceeasi problema de consum maaare si relanti oscilat, cel putin cand sunt in mers si o pun pe liber oscileaza urat intre 500-1000 ture. Am pus o pe tester si mi a zis omu sa schimb urgent bujiile, senzoru de temperatura motor si termostatu. Imi ia cam 15 la suta mers foarte lejer.
