thematriksz
  • Gender
  • Location
    Tg-Mures
    BMW 318i
Recent Profile Visitors
thematriksz's Achievements
  1. Salut Am o problema stranie. La anumite turatii, 1800-2200rot, si numai aici, se aude un sunet gen vibratie a ceva, mai degraba plastic as zice eu, nicicum metal, din zona bordului, mijloc, deasupra cd-palyerului, spre parbriz si nu-mi dau sema de unde vine sau ce poate cauza. Am reusit sa fac legatura cu 2 lucruri: 1. nu se aude vara; 2. nu se aude, sau se aude foarte discret cand dau drumul si la aerul conditionat.
  2. E46 318i 2002. Am o vibratie in interior ce se aude ca si cum ar fi de sub bord sub parbriz, spre partea pasagerului, apare doar in jurul 1800-2200rpm si se aude mai clar in cazul franei de motor, la descresterea rpm. Sub si peste aceste rpm e liniste. Ce ar putea cauza?! Postez in speranta sa fie ceva cunoscut, sa nu stau jumatate de zi pe sub masina pana gasesc o tabla sau un surub nestrans ...
  3. Valabil... 3' E46, 316i, Sedan, N40, EUR, (AY11) : Rear muffler 3' E46, 316i, Sedan, N42, EUR, (AY31) : Rear muffler 3' E46, 316i, Sedan, N42, EUR, (AY32) : Rear muffler 3' E46, 316i, Sedan, N45, EUR, (EY11) : Rear muffler 3' E46, 316i, Sedan, N46, EUR, (EY31) : Rear muffler 3' E46, 316i, Sedan, N46, EUR, (EY32) : Rear muffler 3' E46, 316i, Touring, N42, EUR, (AX31) : Rear muffler 3' E46, 316i, Touring, N42, EUR, (AX32) : Rear muffler 3' E46, 316i, Touring, N46, EUR, (EX31) : Rear muffler 3' E46, 316i, Touring, N46, EUR, (EX32) : Rear muffler 3' E46, 318i, Sedan, N42, EUR, (AY71) : Rear muffler 3' E46, 318i, Sedan, N42, EUR, (AY72) : Rear muffler 3' E46, 318i, Sedan, N42, EUR, (AZ71) : Rear muffler 3' E46, 318i, Sedan, N42, EUR, (AZ72) : Rear muffler 3' E46, 318i, Sedan, N46, EUR, (ET75) : Rear muffler 3' E46, 318i, Sedan, N46, EUR, (ET76) : Rear muffler 3' E46, 318i, Sedan, N46, EUR, (EY71) : Rear muffler 3' E46, 318i, Sedan, N46, EUR, (EY72) : Rear muffler 3' E46, 318i, Touring, N42, EUR, (AX51) : Rear muffler 3' E46, 318i, Touring, N42, EUR, (AX52) : Rear muffler 3' E46, 318i, Touring, N46, EUR, (EX51) : Rear muffler 3' E46, 318i, Touring, N46, EUR, (EX52) : Rear muffler
  4. Trebuie sa-mi schimb toba finala la masina: 318i E46 din 2002, benzina, 2000cc, motor N42B20A Am gasit o toba de pe un 316i, N46B18A. S-ar potrivi?
  5. Mersi. Arat maine sper la cel care ar monta, sa dea si el cu parerea si te anunt.
  6. Corect, pe 4 cil. Mersi si de link, ma uit...
  7. Caut toba spate pt. E46 pe benzina, 2000cc din 2002, preferabil touring dar si de la sedan se potriveste, in stare buna.
  8. Am o problema la dezaburirea lunetei. Practic nu functioneaza. Siguranta OK (verificat), releu K13 OK (verificat). Am facut o verificare a retelei in sine de pe luneta cu o camera de termoviziune, unde se vede clar, ca se incalzeste doar o treime din prima linie, cea de sus, stanga. Daca va uitati in poza alaturata (nu e BMW-ul meu), se pot observa pe langa liniile orizontale, si doua verticale. La mine se incalzeste doar prrima linie orizontala de sus, pana la prima linie verticala din stanga. Banuiesc ca din coltul din stanga sus, pe aceasta linie este alimentata toata reteaua?! si o fi intrerupt acolo undeva? Pareri?
  9. Trebuie inlocuit tot manerul cu buton, sau se poate oare desface si vazut, schimbat eventual doar switch-ul?
  10. Salutare Am o mica problema legat de deschiderea geamului din spate la un touring E46. Geamul se deschide fara probleme cu cheia, insa nu se deschide din buton. Nu sunt sigur de principiul de functionare, dar banuiesc ca este un simplu microcontact, are doua fire pirn care da un semnal. Am incercat sa masor, sa "sun" cele doua fire dar nu da semnal nici fara/cu apasare a butonului. De aici cred, ca butonul este stricat. Am dreptate? Pareri?! Mersi
  11. Daca se dezmembreaza, ma intereseaza ornamentul cu perie exterioara de la geam, codul 51338194707 partea stanga, fata, daca e in stare buna (nu e umfalata de rugina etc.)
  12. Cumpar chederul, ornamentul cu perie exterioara, codul 51338194707 partea stanga. Astept oferte.
  13. Salut In prima faza vreau sa-mi cer scuze, pentru expresiile folosite mai jos, sincer nu cunosc toti termenii specifici, insa sper sa intelegeti intrebarea. Momentam am pe masina faruri cu becuri inadescente si as dori sa le schimb cu faruri cu bec xenon. Am un prieten care are pe masina asemenea faruri, vrea sa vanda masina si ar urma se le schimbam inainte de vanzare. Intrebarea mea ar fi: in afara de schimbul fizic de faruri, ar mai trebui setat ceva (ma gandesc in softul masinii) sau nu? mersi
