cipsava
Everything posted by cipsava
  1. am nevoie numai de sticla de oglinda ms oricum
  2. Mirror glas, heated, wide-angle - 2buc - part number 51168250438 e46 touring 2004 0722617751
  3. Merge!! :twoup: l-am resetat si acum a inceput de la 30.000km ce am observat la secventa de resetare: "3- cum a aparut asta ii dai drumul la boton si apesi imediat din nou inca 5 secunde si incepe sa clipeasca mesajul "RESET" sau "RE" "4- ii dai drumul la buton iarasi dupa care apesi inca o data pe el, dar de data asta scurt, fara a tine apasat pe el" la punctul 4 trebuie apasat butonul in timpul cat clipeste mesajul "RESET" (la mine a clipit de 3 ori - cca 3 sec) daca apasati dupa ce nu mai clipeste nu se reseteaza (m-am prins la a 4-a incercare :twoup: )
  4. original e cam mult 650 lei ce inseamna lampa spate gol? 230lei cu sau fara tva? @b50xxl - thx, dar raman la semnale albe bafta la vanzare
  5. 63216900473 - capac stop stg spate semnale albe, e46 touring 2004 banuiesc ca asta este codul desi poza de pe RealOEM nu prea seamana 63216900453 - garnitura aferenta thx uite o poza cu stopul dreapta (care este intreg :twoup:)
  6. Multumesc pentru informatie banuiesc ca explicatia este asta: Interior rearview mirror with automatic dimming feature The interior rearview mirror with automatic dimming feature reduces blinding from following traffic by adapting the intensity of the reflected images to correspond to levels of light registered by the unit's sensors. The mirror reverts to its undimmed setting as soon as the light source disappears. One lamp sensor is mounted on the front of the mirror housing. This sensor, which is directed forward, measures light intensity in the area ahead of the vehicle. The second sensor is integrated within the mirror's glass. The electronic control system compares the light intensity from front and rear. The difference provides the basic parameter used to modulate an electrical current and induce chemical changes in a semisolid layer incorporated in the lens. Se poate inchide :blink:
  7. Pe spatele oglinzii din interior este un senzor. ce face el? Mentionez ca oglinda este heliomata (antiorbire); masina este e46 touring din 2004 si are si senzor de ploaie si lumina.
