BMW E46 318i turbo
ALC
Buna seara , doresc putin ajutor de la cei cu experienta va rog , detin un bmw e46 318i 143hp si doresc sa ii maresc putin mai mult puterea , exista un turbo sau supercharged kit pentru acest model ? mentionez ca NU ma intereseaza schimbarea masinii sau a motorului , daca iti doresti ceva este posibil iar , intr-un "proiect" trebuie sa investesti bani
in afara de filtru sport , serpisori (galeria de evacuare) si soft ce se mai poate face ?
Multumesc frumos !
Multumesc frumos !
S-a mai discutat fix problema asta pe aici, cred cĂŁ este un topic dedicat ĂŽn care se discutĂŁ cât de mult nu meritĂŁ o asemenea investiție pe motorul ĂŁsta.
Ar trebui sĂŁ te rezumi la ce ai zis tu mai sus.
Uite aici: http://www.bmwclub.ro/forums/topic/177289-n42-turbo/page__p__2372020__hl__turbina__fromsearch__1#entry2372020
Multumesc frumos !
si altii inaintea ta s-au gandit :
https://www.pistonhe...0&f=72&t=558534
http://mywikimotors.com/n42b20/
BMW N42B20 engine tuning
N42B20 Chip tuning
N42 engines are not the best choice for tuning. You may face difficulties in finding necessary dimensions and performance parts on the market. That is why you will hardly be able to implement serious upgrading project. The only way to increase the level of HP is to proceed with chip tuning. You need to buy cold air intake and cat back performance exhaust system. Don’t forget to complete engine management tuning to make everything work properly. Such modifications will make it possible to increase power rate up to 160 HP.
"If you still require more power the best way is to sell your BMW 318i and buy BMW M3 E46."
dar pe banii tai ...poti face ce vrei.
https://www.laurent-motors.com/en/turbo-kit/174-35675-kit-turbo-bmw-standard-20l-a-30l-24s.html
vad ca doar M50, M52 si M54 (versiunile de 2.0l) ar suporta un kit turbo
dar alea sunt in 6 cilindrii....si mai sanatos construite decat un N42.
Edited by wind-3er
  • Like 3
Multumesc frumos pentru ajutor , am gasit pe acel site kit-ul complet , am trimis email si am primit si raspuns :D
Hi,
Our BMW 4 cylinder turbo kits are available for the N46 engine aswell ;)
https://www.laurent-motors.com/en/61-kit-turbo-e36-e46-e34-e39-e60-
the product# 5-6-7 are for the 4 cylinders depending on the final power you are aiming for.
The N46 is the last of the three options of engine available.
il las aici poate ajuta pe cineva , sau exista posibilitate de a scapa din greutate , incepand de la baterie pana la capota din fibra de carbon , plafon , porbagaj etc , solutii exista , oricum multumesc frumos pentru ajutor !
Eu cel putin am reconditionat motorul , garnituri supape tacheti garnituri , valvetronic etc , deci ar trebui sa reziste daca nu revin cu update pentru ce modificari urmeaza sa fac :D
Multumesc frumos inca odata !
  • 1 year later...
Hi,
Salut , am si eu acelasi motor , sunt curios daca ai reusit sa faci ceva cu el ?
