F31 Codare hu_cic 8,8 inch
  • RedCap changed the title to F31 Codare hu_cic 8,8 inch
Am gasit pe un forum ceva oare sa mearga?
✅ STEP 1: Connect to Your Car
  1. Plug the ENET cable into the OBD port (driver’s footwell).
  2. Plug the Ethernet end into your laptop.
  3. Turn ignition ON (do not start the engine).
  4. Launch E-Sys.
  5. Under “Connection”, choose:
    • Target: F020
    • Interface: ENET
    • Click Connect
  6.
✅ STEP 2: Read & Modify Vehicle Order (VO)
  1. In E-Sys, go to “Expert Mode” > “Coding”
  2. In the left panel, expand “FA”, right-click it and choose Read FA (VO).
  3. Expand FA > F020 (your car).
  4. Right-click SALAPA-Element → Click Edit
  5. In the VO list:
    • Remove: $6VB (CID Mid)
    • Add: $6VA (CID High)
  6.
  7. Click Save, then click the Disk icon to save the new FA file.
✅ STEP 3: Write VO to the Car
  1. In the FA tree, right-click F020, then click “Calculate FP”
  2. Go to “VCM” tab, click “Write FA”
  3. VO is now written into your car.
✅ STEP 4: Code HU_CIC Module
  1. Go to Coding → Read ECU list (Read ECU tree)
  2. Right-click on HU_CIC, click “Code”
    • This will apply the new VO settings, including screen resolution.
  3.
