ESD regelt
Salutare,ieri mi-a aparut la bord"ESD regelt" si "BRAKE LT CIRCUIT".Limba la bord este setata pe engleza,si tot ce apare este cu litere mari."ESD regelt" a aparut exact cum am scris,deci este in germana.Stie cineva ce inseamna?Masina este un e34m50b20.Dupa ce am oprit,si am repornit au disparut mesajele
ESD = Electronic Brake Differential
Regelt = regulation
ESD is a BMW acronym for Electronic Brake Differential -- an older accronym for slip/traction control, and "regelt" means "regulation". This fault seems to be another phantom fault that is fixed by replacing the CCM (Check Control Module). Makes sense that it could turn on the Transprogram warning, but have not heard of that. Yes, the CCM is in the fuse box. It should have ccm molded into it.
Scuze ca este in engleza. Sper ca te descurci. Eram pe fuga si nu am avut timp sa traduc.
Regelt = regulation
300397[/snapback]
In engleza este ok,merci frumos.
