problema cu kit-ul bluetoth
masina mea, un e46 325ci FL, are in dotarea standard kit-ul bluetoth si ce mai tine de el..cand vreau sa caut de pe telefonul mobil conexiunea cu acesta, imi cere un cod...de unde pot afla codul asta? :twoup: ..si care este procedura exacta pt a realiza conexiunea?
baga un cod de ex 00000 si la bluetooth-ul de la masina si la cel de la telefon si se vor conecta
va multumesc frumos amandurora! sunteti niste dulci :twoup:
off-topic: jacobs, aseara..pe un traseu de vreo 40km...piata unirii-universitate-piata romana-baneasa-..-ciolpani, resetand bc la piata unirii, schimbat tacticos la maxim 2500-2700rpm (ceva probleme la motor si nu am vrut sa fortez - s-a dovedit a fi o problema minora..) am obtinut o medie grandioasa...6,8 :twoup:
Enter the password (= ULF passkey) located on ULF Control Module that is
in the rear of the vehicle or on the Passkey Reference Card.
· Mobile phone display shows ‘BMW …… Pairing’
· Mobile phone display shows ‘Pairing Successful’
· Display screen shows ‘Pairing succeeded’ for 3 seconds
asta am gasit in manual..
1. Press the menu button.
2. Select “Connect”.
3. Select option 3: “Bluetooth”.
4. Select option 4: “Options”.
5. Select option 1: “Operation mode” and set to “On” or “Automatic”.
6. Go back one step by pressing the red phone button.
7. Select option 3: “Discover”.
Mobile Phone display shows ‘Searching’
8. Select “BMW ……” in upcoming list.
9. Select option 1: “Add to paired”.
10. Enter password (= ULF passkey) located on ULF Control Module in the rear of the vehicle or on the
Mobile Phone display shows ‘BMW …… Pairing’
Mobile Phone display shows ‘Pairing Successful’
Board Monitor display shows ‘Pairing succeeded’ for 3 seconds
11. Enter device name.
12. Mobile Phone display shows “Added to paired devices”.
13. Quit menu by pressing the red phone/NO button for several seconds.
14. Once the phone is successfully paired to the
device cycle the ignition switch off and back
on.
15. The devices should wirelessly connect within
30 seconds. The connection is established
when the phone displays the symbols
indicated, on the right side of the screen.
Daca nu merge cu 0000 sau 1234 sau altele trebuie sa demontezi tot pana ajungi la ULF
325i consum urban 6.8 pe BC ?! cam mult NU ? :))))))))))) este mai exact decat Big Benu' !!!
Edited by Jacobs
Razvan ti-am explicat acum 3 luni cum sa faci Bluetooth Pairing :twoup: , nu ma ascultai :)
Daca nu rusesti ne intalnim intr-o zii si desfacem mocheta din portbagaj in stanga si gasim acolo pass key pe modulul bluetooth, dureaza 2 minute
Edited by edy1092
mai scrie inca o data ! mai sunt poate si altii curiosi.
si daca proprietarul anterior a schimbat codul...cum se reseteaza un passkey de BT ?
mda..sper sa mearga. totusi se pare ca respectivul cod e format din 5 cifre...
cred ca sunt maxim 4 suruburi de desfacut ca sa ajungi la acel modul. citeste de pe stiker codul si gata !!!!
Multumesc pt sfaturi! O zi buna!
am desfacut sambata mocheta aia din portbagaj..si nu am vazut nici un cod/parola sau ceva de genul asta :) ..aveti vreo poza/indiciu exact cu locul in care ar trebui sa fie scrisa respectiva parola? eu unul nu am vazut nimic.. :twoup:
Desfaci mocheta din partea stanga.Si desfaci modulul bluetooth.Este situat deasupra de magazia de cduri sau MK4.Pe el o sa scrie parola.Este din 4 cifre.
Cred ca se poate afla si daca te conectezi cu laptopu la masina(eventual activezi si comenzile vocale).
L.E. acum am vazut ca ai coupe.Dar cred ca tot asa ii.
Edited by Ionut_FFF
am desfacut mocheta, am gasit parola..problema acum este ca nu se conecteaza telefonul la bluetooth-ul masinii...sta 20min si degeaba.. :twoup: . trebuie un telefon special ceva?
Nu neaparat special, doar ca nu toate telefoanele care au bluetooth sunt compatibile cu sistemul/versiunea montate pe masina ta. Avand in vedere ca ai un model un pic mai vechi de masina, s-ar putea sa mearga doar telefoane de generatie un pic mai veche. Daca ai telefon model mai nou, incearca cu unul mai vechi si vezi daca merge asa.
ce telefon ai, din ce an e modulul BT (scrie pe eticheta), eu am modulul din apr 2004 si functioneaza cu nokia 5800 xm (care are symbian)
am un nokia 6710navigator..are symbian..mai am un nokia putin mai vechi, fara symbian, o sa incerc sa vad daca acela se conecteaza..
Modulul meu era din 2004.Si am conectat fara probleme nokia E51 si nokia N97
