Diferential E46
BeRnEk
Am o nedumerire am comandat un diferential SH din Germania si ce am primit era mai mare (mai masiv) si distantele de la flanse nu erau bune cel putin flansa de la cardan comparat cu diferentialul meu (defect). (nu am putut descifra nimic pe el banuiesc ca era de pe un E46 NFL - M52 cel de 150CP nu pot fi sigur nici de raport nici de model doar ca e de pe un E46 dupa forma)
Masina mea este: 318i E46 anul 2002 motor 1995cmc 143cp.
Pe www.realoem.com la diferential (318i) mie imi da: 33107559330 I=3,38
cel care vreau sa il montez (320i) are codul urmator: 33107509780 I=3,38
Acesta ultimul urmeaza sa il comand si vine de o masina cu sasiul: FU04323 respectiv un 320i din 2001 (motor M54)
Totusi daca caut pe realoem diferentialul meu (33107559330) primesc urmatoarele:
http://realoem.com/bmw/partxref.do?part=33...330&lang=en
respectiv:
Part 33107559330 (Rmfd final drive) was found on the following vehicles:
E46: Details on E46
E46 316ti Compact, Europe
E46 318ti Compact, Europe
E46 316i Saloon, Europe
E46 316i Touring, Europe
E46 318Ci Convertible, Europe
E46 318Ci CoupĂŠ, Europe
E46 318i Saloon, Europe
E46 318i Touring, Europe
E46 320Ci CoupĂŠ, Europe
E46 320Ci Convertible, Europe
E46 320i Saloon, Europe
E46 320i Touring, Europe
iar in lista detaliata:
E46 320Ci Convertible, M54, Europe (BW11) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320Ci Convertible, M54, Europe (BS11) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320Ci Convertible, M54, Europe, RHD (BS12) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320Ci Convertible, M54, Europe, RHD (BW12) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320Ci CoupĂŠ, M54, Europe (BN11) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320Ci CoupĂŠ, M54, Europe (BD11) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320Ci CoupĂŠ, M54, Europe, RHD (BN12) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320Ci CoupĂŠ, M54, Europe, RHD (BD12) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320i Saloon, M54, Europe (AV11) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320i Saloon, M54, Europe (AN15) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320i Saloon, M54, Europe (EV11) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320i Saloon, M54, Europe (ET15) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320i Saloon, M54, Europe, RHD (AN16) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320i Saloon, M54, Europe, RHD (EV12) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320i Saloon, M54, Europe, RHD (ET16) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320i Saloon, M54, Europe, RHD (AV12) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320i Touring, M54, Europe (AW11) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320i Touring, M54, Europe (EN11) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320i Touring, M54, Europe, RHD (EN12) : DIFFERENTIAL-DRIVE/OUTPUT
E46 320i Touring, M54, Europe, RHD (AW12) : DIFFERENTIAL-DRIVE/OUTPUT
Acest lucru inseamna ca, daca am cautat dupa codul diferentialului meu si am primit aceasta lista, ar fi bun pe masina mea (cel de pe 320i cu motor M54) ?
Va rog cine are rabdare sa caute sau chiar ma poate ajuta in aceasta problema sa posteze :twoup:
Am mai cumparat un diferential SH din Romania si s-a facut praf dupa 50 km ...
Momentan sunt in Franta si imi este destul de greu sa imi rezolv aceasta problema.
Respecte,
Bernek
Teoretic sunt deja la al 3 lea diferential pe care il cumpar si am ajuns la pretul unuia nou demult.
Trebuie sa dau un raspuns la magazinul din Germania daca doresc diferentialul de pe FU04323 (320i - M54 - 2001).
Cautarile mele ma fac sa cred ca sunt identice dar totusi apelez si la voi cineva singur avand mai multa experienta in aceasta problema.
Edited by BeRnEk
Va multumesc mult pentru raspunsuri ! Momentan circul cu un diferential facut din cele 2 care s-au stricat si pinionul de atac e ciobit si imi suna enervant in frana de motor fiind distrusi dintii pe o parte dar inca merge pana il primesc pe cel de pe M54.
Primul s-a rupt un ax intre sateliti si am facut alt ax in romania (si cementat) dar se pare ca a rezistat numai 7 mii de km.
Al doilea cumparat SH din romania a fost de pe o masina accidentata si banuiesc ca a fost spart/crapat rulmentul de la flansa spre cardan si pe autostrada la 140 kmh a cedat dupa 40-50 km.
Al treilea ce l-am cumparat era banuiesc de pe 320i M52 1999 si era mult prea mare foarte dubios ...
Acuma il astept pe acesta de pe un 320i M54 din 2001 sper din suflet sa potriveasca !
Intrebarea mai simpla ar fi:
Potriveste un diferential raport 3.38 de pe un 320i (cod masina FU04323) din 2001 cu motor M54 pe masina mea (318i FL din 2002/02 motor N42) ?
este acelasi diferential ,daca ai cutie manuala
Da am cutie manuala si sper sa potriveasca ! Ca m-am saturat de problema asta.
se potriveste man!
daca te aranjeaza un diferential ca nou pt 318i E46 da un semn!
P.S - si aici gasesti piese SH bune numai ca trebuie sa stii unde sa cauti!
bafta
Man eu sunt in Franta de aceea caut in Germania ca fie mai aproape si sa ajunga mai repede ...
Daca eram in Romania clar cumparam din SH de la noi (oricum am luat unul din RO deja ...)
Salut !
Am o noua intrebare la voi ! Daca distanta intre flansele spre planetare e mai mare cu 2 cm se poate monta acest diferential ? Adica planetarele de pe masina mea culiseaza un pic sa zic 1-2 cm fiecare ... Nu va forta daca diferentialul e mai mare cu 2 cm per total ?
Si alta problema ar fi ca si de la prinderea din fata spre cardan e mai lung tot cu vreo 2 cm ... Culiseaza cardanul 2 cm fara sa fie probleme ?
Nu as vrea sa se strice si altceva daca reusesc sa montez un diferential cu cca 2 cm mai mare la flanse (cardan si planetare)
Va multumesc !
Te rog sa nu te superi pe mine dar ai citit topicul in intregime ? Intrebarea mea e daca planetarele e permis sa culiseze atat ca sa permita montarea unui cu 2 cm mai mare intre flanse ! Toata lumea zice ca potriveste si eu nu vad cum daca nu schimb planetare cardan etc
