TURBO VS. KOMPRESOR
e46bimmer
La turbo, turbina este antrenata de gazele de evacuare.
Compresorul este antrenat mecanic direct de catre motor (similar cum este antrenata pompa de apa sau alternatorul).
Avantaj major la turbo - nu consuma din puterea motorului.
Avantaj major la compresor - raspunsul mai bun.
Multumesc mult de raspuns,Paul.
As mai avea o intrebare:care dintre cele doua mareste mai mult puterea motorului?
There are three main categories
of superchargers for automotive
use:
Centrifugal turbochargers –
driven from exhaust gases.
Centrifugal superchargers –
driven directly by the engine
via a belt-drive.
Positive displacement pumps –
such as the Roots, Twin Screw
(Lysholm), and TVS(Eaton)
blowers.
The thermal efficiency, or
fraction of the fuel/air energy
that is converted to output
power, is less with a
mechanically-driven
supercharger than with a
turbocharger, because
turbochargers are using energy
from the exhaust gases that
would normally be wasted. For
this reason, both the economy
and the power of a
turbocharged engine are usually
better than with superchargers.
The main advantage of an
engine with a mechanically-
driven supercharger is better
throttle response, as well as the
ability to reach full-boost
pressure instantaneously. With
the latest turbocharging
technology, throttle response on
turbocharged cars is nearly as
good as with mechanically-
powered superchargers, but the
existing lag time is still considered
a major drawback, especially
considering that the vast majority
of mechanically-driven
superchargers are now driven off
clutched pulleys, much like an
air compressor.
Turbochargers suffer (to a
greater or lesser extent) from so-
called turbo-spool (turbo lag;
more correctly, boost lag), in
which initial acceleration from
low RPM is limited by the lack of
sufficient exhaust gas mass flow
(pressure). Once engine RPM is
sufficient to start the turbine
spinning, there is a rapid increase
in power, as higher turbo boost
causes more exhaust gas
production, which spins the
turbo yet faster, leading to a
belated "surge" of acceleration.
This makes the maintenance of
smoothly-increasing RPM far
harder with turbochargers than
with engine-driven
superchargers, which apply
boost in direct proportion to the
engine RPM.
Roots blowers tend to be 40–50%
efficient at high boost levels.
Centrifugal superchargers are
70 –85% efficient. Lysholm-style
blowers can be nearly as efficient
as their centrifugal counterparts
over a narrow range of load/
speed/boost, for which the
system must be specifically
designed.
Keeping the air that enters the
engine cool is an important part
of the design of both
superchargers and
turbochargers. Compressing air
increases its temperature, so it is
common to use a small radiator
called an intercooler between
the pump and the engine to
reduce the temperature of the
air.
@cĂŁtĂŁlin
Nu existĂŁ un rĂŁspuns la ĂŽntrebarea ta.
Amândouã fac acelaºi lucru.
Dacã vrei putere ºi atât, mergi pe supercharger!
P.s.
Din ce scrie mai sus, turbo ar fi mai ok, atât pt putere, cât ºi pt consum. Dezavantajul major: boost lag.
La compresor, ai efect instant. DAR, compresorul poate "fura" pânã la 40% din puterea la arbore a motorului.
Din ce am mai citit eu, compresorul e preferat atunci când se urmãreºte ÎmbunãtãÞirea timpilor de acceleraÞie (cursele de dragstere, de exemplu).
ca solutie gen pus aftermarket mi se pare mai ieftina si mai fiabila un compresor.
n am prea vazut compresoare pe site urile noastre.ai ceva detalii?gasisem ceva pe 4tunning dar pentru mustang si era destul de scump...n am gasit decat kituri turbo
nici nu as cumpara de pe site-urile noastre..:)
Pentru M50b25 ai 2 solutii..
una
http://www.beastpowe...AA-BE36-SCK-325
4400 de dolari.. kit compler, garantie 2 ani. ajungi cam la 300 de cai si 380Nm..Poti sa iei un kit din China, vreo 4-500 de euro dar sa ai un stingator langa tine si o masina de urmarire sa te tracteze din cand in cand.. cam la fiecare 2 liniute sau stat mai mult 5 min la 6000 de ture..
Alta e sa pornesti sa le faci din bucati un compresor Eaton M62, intercooler, furtune, curea, role, etc.. Nu stiu cine iti face intercooler-ul, trebuie calculat si ala..de un inginer, soft custom etc.. etc...
Ce vrei tu sa faci nu exista ieftin, puterea si modificarile ulterioare costa foarte mult.
Automat nu stai la 300 de cai cu ambreiajul care il ai..ambreiaj stage 1 sau 2 .. frane etc etc.. .. mii si mii de euro.. Sau poate tine o cutie/ambreiaj de 540i, .. alti bani.. etc etc.. nu mai bine iei tu un 540i :) ?
Vrei performanta costa..
Edited by DOMI
au traditie indelungata, din anii 30, de pe vremea cand Silver Arrows castigau tot ce inseamna Grand Prix. Sunt mai simple constructiv si din cauza ca nu nu prea au de a face cu gaze fierbinti, sunt mai fiabile. Ei de obicei folosesc variante low pressure, nu foarte solicitate, nici foarte puternice, cat sa imbunatateasca experienta unor motoroare relativ mici... ..
Si functioneaza treaba foarte bine.
Domi,fa-ma sa inteleg,compresorul acesta e similar principiului de functionare ca pe cele de camioane?si aici ma refer la compresorul de saviem sau raba,cel care producea aer in butelii pt a permite franarea camionului(bine,ca aici nu e vorba de sistemul de franare,ci de cu totul altceva).
Este cu totul altfel, de fapt sunt cateva tipuri care se impart in doua mari categorii: volumice si cu flux continuu, de exemplu cel centrifugal e identic compresorului de turbocompresor doar ca e antrenat mecanic la ax.
Gugaleste-le!
Amandoua pot mari puterea mult, dar compresorul nu se preteaza la supra-alimentari cu presiuni mari deoarece consumul prpriu e foarte mare raporatat la puterea utila.
Turbocompresorul foloseste energia gazelor de ardere pe care altfel (in lipsa supra-alimentarii) o cedeaza mediului.
De asta turbo-dieselul e mai economic ca aspiratul , la sarcini mari.
Edited by lucian81v
domi adevar graiesti.nu merita.la ceva profesional treci lejer de 6-7 mii.in lumina ultimelor evolutii la pretul carburantilor voi renunta la idee.raman la 2,5 pe care voi pune un chip(e deja pe drum)si 100% instalatie gpl.masina o voi folosi in continuare pt uzul zilnic...in schimb daca totul e ok anul asta si termin odata cu alte investitii imi iau e31 sau in cel mai rau caz e34 m5.the real thing.bineinteles neinmatriculat si ma duc la vecinii bulgari.nu ma las eu asa usor numa sanatate sa fie... :thumbsup:
Cel mai bine e sa le ai pe amandoua , kompresor pt turatii joase si un turbo mare pt turatii inalte :rolleyes:
man iti dai seama asta ar fi deja prea frumos :sorcerer:
Un material interesant despre cum functioneaza compresorul
http://www.youtube.com/watch?v=zbpuVxjtWaI
1.4 TSI de la VW e asa.. e marfa motorasul, am condus una cam o saptamana.. pacat ca era golf.. :)
cati cai au scos astia din motorul de 1,4?parca trece de 140?nu stiam ca are si compresor
Edited by sly06
in oras consuma ok pentru puterea lui, cam 8-9.. cel putin pe unde si cat am mers eu. Afara cam 6.5.. banuies ca depinde mult de cata talpa ii dai.. dar la mers normal.. e era ok.
Nu toate TSI au si turbo si compresor, asta de 1.4 140 de cai are.
