matei cristian
  1. Bună ! am o problema cu un F10.. nu citeste pe bord in ce treapta e dispare litera P iar in acel moment nu invarte motorul trebuie sa dau de 4-5 ori pe buton pana sa o ia, dar nu mereu face asta, uneori o ia din prima, iar in timpul mersului dispare litera “ D “, pe urma reapare, iar turometrul o ia razna in mers coboara pana pe 0 urca inapoi, cutia schimba perfect fara smacituri sau socuri, ma poate ajuta cineva va rog? las si lista cu ce coduri de eroare am S 0235 No No communication possible with: Electronic transmission control S0379 No communication possible with: Gear selector switch CEC40A EKPS, powertrain CAN: Communications fault CD840A DDE, PT-CAN: Communication fault CD040A ZGM, PT-CAN: communication fault CD840A DDE, PT-CAN: Communication fault B7F68C Instrument panel: Selector lever indication, shift point indicator, CAN B7F67B Instrument panel: Wake-up line status incorrect, hardware line E11460 No message (data, display, transmission powertrain, 0x3FD), receivert S 0379 No communication possible with: Gear selector switch E/1413 Message (crankshaft torque 1, OxA5) missing, receiver IHKA, transmitte
