F10 problema pornire
Featured Replies
Bună ! am o problema cu un F10.. nu citeste pe bord in ce treapta e dispare litera P iar in acel moment nu invarte motorul trebuie sa dau de 4-5 ori pe buton pana sa o ia, dar nu mereu face asta, uneori o ia din prima, iar in timpul mersului dispare litera “ D “, pe urma reapare, iar turometrul o ia razna in mers coboara pana pe 0 urca inapoi, cutia schimba perfect fara smacituri sau socuri, ma poate ajuta cineva va rog? las si lista cu ce coduri de eroare am
S 0235
No
No communication possible with: Electronic transmission control
S0379 No communication possible with: Gear selector switch
CEC40A
EKPS, powertrain CAN: Communications fault
CD840A
DDE, PT-CAN: Communication fault
CD040A
ZGM, PT-CAN: communication fault
CD840A
B7F68C
Instrument panel: Selector lever indication, shift point indicator, CAN
B7F67B
Instrument panel: Wake-up line status incorrect, hardware line
E11460
No message (data, display, transmission powertrain, 0x3FD), receivert
S 0379
E/1413
Message (crankshaft torque 1, OxA5) missing, receiver IHKA, transmitte
Recently Browsing 1
