petreop
    19
Everything posted by petreop
  1. esti sigur ca nu este acolo ??? verifica aici: https://bimmercat.com/bmw/en/search/selectCar/E90/Lim/BMW+320d+M47N2/ECE/66_0117
  2. nu e scumpa, esti tu prea optimist ! ... pentru cumparatorul mioritic. bafta !
  3. in portbagaj langa baterie.
  4. petreop
    X3 automat
    daca stii tu ca exista atunci e foarte bine ! :goodjob: :goodjob: anunta-i repede si pe cei de la Bayerische Motoren Werke AG ca au produs un bmw x3, e83, M47 cu cutie automata... cred ca le-a scapat modelul asta pe care l-ai gasit tu, pentru ca ei nu l-au produs niciodata ! daca-l gasesti pe undeva, anunta-ma ca-l cumpar imediat !
  5. petreop
    X3 automat
    X3 diesel cu motor de 150 de cai este M47. cel cu distributia in fata (foarte fiabil si fara probleme). din pacate modelul nu s-a fabricat si cu cutie automata.
  6. https://products.liqui-moly.com/oils/synthoil-high-tech-5w-40-1.html sau https://www.motul.com/ro/ro/products/300v-power-5w40--2
  7. THE CONSEQUENCES OF TOO MUCH POSITIVE/NEGATIVE WHEEL OFFSET. If your wheel offset is overly positive, you run the very-real risk of having the wheel sit too far inside the wheel arches, causing the inner edge of your wheels and tyres to rub against your suspension components. As if that wasn’t bad enough, this rubbing can cause serious damage to your wheels, tyres and suspension. It can also negatively affect your car’s handling, making it potentially dangerous to drive. On the flip side, too much negative offset will push your wheels and tyres outside of your wheel arches. This won’t cause as much of a problem as too much positive offset, but it will make your vehicle look fairly silly and might require you to roll your arches, or fit arch extensions to cover the wheels. succes !!!
  8. petreop
    Salutare
    https://bimmercat.com/bmw/en/search/vin_search?vin=JP17748
  9. anuntul nu mai este valabil. multumesc bmwclub, pentru gazduire !
  10. Buna dimineata ! am de vanzare un Rulou / Polita portbagaj BMW X3 E83 Se potriveste la toate modelele din 2003 - 2010 COD BMW = Roller blind f luggage compartment 51473405905 este in perfecta stare.
  11. petreop
    Bmw x3 e83
    https://bimmercat.com/bmw/en/search/selectCar/E83N/SAV/BMW+X3+2%252E0d+M47N2/ECE/27_0027
  12. pe bune... vrei raspuns pe forum la problema asta ?! si ca sa nu zici ca nu te ajuta lumea, pasii de urmat sunt urmatorii: service elevator scut motor jos vizionare constatare deviz succes !
  13. 1000 euro in visele tale ! un exemplar bun si corect ingrijit incepe de pe la 4000 euro in germania. asa ca, succes la cautari !
  14. http://www.bmwclub.ro/forums/topic/164045-download-bmw-road-maps-2015-harti-cic-nbt-ccc-mk3-mk4/page__hl__map+business
  15. intreaba-l pe prietenul "google" !!!
  16. foloseste functia "search" din dreapta-sus a paginii !
