Wild Cat KST
Everything posted by Wild Cat KST
  1. SINCER NU STIU,CUM POT VERIFICA?
  2. AM DESFACUT TOT CEEA CE MI ZICI U,AM CURATAT,COTUL ESTE NOU,TOT CE RAMANE DE FACUT ESTE SA VERIFIC SONDA LAMBDA.... :blink:
  3. SAL ALL! AM O MICA PROBLEMA SI NU I DAU DE CAP,POATE MA AJUTA CINEVA.... PROBLEMA SE PREZ IN FELUL URMATOR: CAND MOTORUL ESTE CALD(NUMAI CAND ESTE CALD), MASINA ARE O FLUCTUATIE DE TURATIE,CA SI CAND S AR INECA,SI DUPA UN INTERVAL DE 10-15 SEC ISI REVINE SINGURA LA TURATIA OPTIMA..... :) HELP CA NU STIU CE SA FAC :blink:
  4. deci.... simptomul este in felul urmator: cand plec cu ea mai in turatie se aude un zgomot super urat,nu l pot pot descrie,ca si cand s ar ineca in propriul lichid..... valtheval,daca poti lasa mi un nr de tel si te sun eu.... mersi mult de suportul tehnic
  5. daca deschizi geamul din dreapta,butonul din dreapta,daca nu viceversa incearca asa.... poate merge stiu ca asta e un mod de resetare al erorilor de la geaurile electrice.... ce sa zic..... BAFTA
  6. PUI CONTACTUL PE PRIMA POZITIE,DESCHIZI GEAMURILE PANA JOS,SI TI APASAT PRET DE 10 SEC BUTONUL..... AR TREBUI SA SI REVINA LA SETAREA INITIALA....
  7. SALUT,AM CRED O PROBLEMA CU CASETA DE DIRECTIE..... ARE MOMENTE CAND SCOATE UN ZGOMOT URAT, IN GENERAL CAND PLEC CU MASINA UN PIC MAI IN FORTA... CA SI CAND AR INTRA IN CAVITATIE..... :blink: :)
  8. :blink: :) CURIOS
  9. DECI..... INCEARCA LA UN TESTER, E PUTIN PROBABIL SA FIE EWS UL. DACA SE BUSESTE EWS UL NU TI MAI INVARTE NICI ELECTROMOTORUL,E POSIBIL SA NU TI MAI CITEASCA CIP UL DIN CHEIE,ASTA DACA ARE CIP! IAR LA MODEL 93-94 NU SE PUNE PROBLEMA CA DISTRIBUTIA SA FIE PE LANT,E PE CUREA.... DIN FEBRUARIE 95 AU INCEPUT BAIETII CU DISTRIBUTIE PE LANT...
