Vlf
    4
Everything posted by Vlf
  1. Cred ca a fost mașina de ĂŽnchiriat Oricum,de flota,ceva,numai ĂŁștia au 3 revizii in 300tkm
  2. Nu se poate evalua cu metode convenționale,e ceva nou apĂŁrut,e cu minus
  3. HDC Hill Descent Control The concept HDC is a system for driving downhill in steep terrain. This system reduces vehicle speed on steep downhill gradients, thus allowing you to maintain control of your BMW under these conditions. The vehicle moves at slightly more than walking speed without active intervention from the driver. HDC is available for activation at vehicle speeds below approx. 20 mph/ 35 km/h. When driving down steep hills with a speed below approx. 20 mph/ 35 km/h, the vehicle reduces speed automatically down to slightly more than walking speed, approx. 5 mph/ 8 km/h, and then maintains this speed. You can use the accelerator or brakes to vary this automatically controlled speed within a range extending from approx. 3 mph/5 km/h to 15 mph/ 25 km/h. You can specify a target speed within the same range by using the +/– buttons of the cruise control. HDC is automatically deactivated once vehicle speed again exceeds approx. 35 mph/60 km/h. Activating the system Press the button, the indicator lamp lights up. The indicator lamp flashes when the brakes are applied automatically. Deactivating the system Press the button again; the indicator lamp goes out. HDC is deactivated automatically above a road speed of approx. 35 mph/ 60 km/h and when the ignition is switched off. Using HDC With manual transmission: Use HDC in first gear and in Reverse since the engine's braking effect is diminished in the higher gears. With automatic transmission: You can use HDC in every drive position. In case of a malfunction The indicator lamp in the button goes out in the HDC mode or does not come on when HDC is switched on: HDC is temporarily not available if brake temperature is too high. If the indicator lamp also lights up: A fault as occurred in the HDC system. Have your BMW Sports Activity Vehicle center inspect this system as soon as possible.
  4. Pai din ce sa plece,din frana?☺
  5. 3MA Individual Roof Rails Alum. Satinated 3MB Individual Ext.line Alu. Satinated 761 Individual Sun Protection Glazing 775 Individual Roof-lining Anthracite Si vopseaua: Sonderlackierung "azuritschwarz-metallic", wie Schl. Nr. S34. Astea le are individual E misto masina Dar apare 2008 08 06
  6. Noi abia avem garduri la case,si veceu in fundu curtii De ex,Deva-Arad,150 km,sunt 3,4 statii de benzina,n ai o carciuma sa mananci ceva ca lumea,nu e nimic Ma indoiesc foarte tare ca o sa apara statii de incarcare la Vințu de Jos
  7. ParcĂŁ aveai un e90 cu un milion de km, aia mai are filtru? Sau te agiți degeaba p aici?
