Vand cateva piese E36 si cateva scule
1. Regulator de relanti cod 13411435995 (modelul in L). Merge pe motoare M40 si M42.
Pret 130 ron
http://dl.dropbox.com/u/649244/de%20vanzare/bmw/regulator%20relanti.jpg
2. Proiectoare E36, stanga ZKW matuit (se poate polisa) - 30 ron,
dreapta HELLA stare foarte buna 60 ron.
http://dl.dropbox.com/u/649244/de%20vanzare/bmw/proiectoare.jpg
3. Bobine Bosch cod: 12139066468
Pret: 30 ron bucata sau 100 toate 4.
http://dl.dropbox.com/u/649244/de%20vanzare/bmw/bobine.jpg
4. Senzor arbore cotit 318is cod: 12141734816
Pret 75 ron
http://dl.dropbox.com/u/649244/de%20vanzare/bmw/senzor%20arbore.jpg
5. Regulator presiune benzina. cod: 13531729320, piese 6
Pret 50 ron
http://dl.dropbox.com/u/649244/de%20vanzare/bmw/regulator%20benzina.jpg
6. Fise bujii E36 318is Bremi stare foarte buna. Merg la 318is si 318ti.
Pret 50 ron toate.
http://dl.dropbox.com/u/649244/de%20vanzare/bmw/fise.jpg
7. Limitator cursa pedala de ambreiaj reglabil (clutch stop). Face schimbarile treptelor mai rapide pentru ca nu mai trebuie sa apesi ambreiajul pana la fund - foarte util celor carora le prinde ambreiajul mai sus.
Inlocuieste piesa: 35311152237
Merge pe urmatoarele modele:
Pret 30 ron
http://dl.dropbox.com/u/649244/de%20vanzare/bmw/clutch%20stop.jpg
8. Adaptor diagnoza de la mufa de 20 pini la OBD
Pret 50 ron
http://dl.dropbox.com/u/649244/de%20vanzare/bmw/adaptor%20bmw.jpg
9. Mufe bobine Bremi + instalatie electrica pentru COP (necesita adaptare)
Pret 50 ron
http://dl.dropbox.com/u/649244/de%20vanzare/bmw/instalatie%20cop.jpg
10. Cheie franceza mare.
Pret 80 ron
11. Draper vacuum diagnostic tool #59075
Suitable for testing and fault finding the following in petrol engines including:
• Spark misfires
• Poor engine compression
• Weak/rich mixture
• Ignition over advanced/retarded
• Inlet manifold and carburettor air leaks
• Incorrect valve timing
• Poor fuel economy
• Balancing carburettors
• Turbo boost gauge
• Fuel pump testing
Pret 75 ron.
http://dl.dropbox.com/u/649244/de%20vanzare/bmw/draper1.jpg
12. Termometru cu infrarosu si laser non contact
Pret 80 ron.
YM: cristimm123
tel: 0725336771
O sa pun diseara poza reala cu proiectoarele (cea de mai sus e luata de pe net).
La cele 4 mufe dinspre bobine nu trebuie facuta nici o modificare, doar la cea rotunda trebuie pusi pinii ca sa corespunda cu instalatia de M44. Nu stiu sigur nici daca mufa rotunda se infige direct in instalatia de M44 dar pinii sigur pot fi folositi.
Am pus poza reala cu proiectoarele.
Instalatia e de la un 525 de la care am luat si bobinele bremi (ebay ca la noi cer preturi mari). Eu n-am avut nevoie de mufe (M42 le are deja) dar mi-am pastrat totusi 2 bobine + 2 mufe de rezerva. ;)
• Spark misfires
• Weak/rich mixture
• Poor fuel economy
• Turbo boost gauge
• Fuel pump testing
Pret 75 ron.
http://dl.dropbox.com/u/649244/de%20vanzare/bmw/draper2.jpg
Pret 80 ron.
http://dl.dropbox.com/u/649244/de%20vanzare/bmw/termometru%20laser.jpg
Edited by cristimm
