OBTINERE COD FSC METODA REUSITA
  • Popular Post
TESTAT PERSONAL PE CIC PROFESIONAL PE E90 , F10 , E60
1)AVEM NEVOIE DE CABLU ENET
2)SETAM LA PLACA DE RETEA URMATORU IP :169.254.199.98, subnet: 255.255.255.0, Gateway: 169.254.199.9
3)CONECTAM CABLU LA MASINA SI PORNIM MASINA
4)IN INTERNET EXPLORER SCRIEM ftp://169.254.199.99
5)SE DESCHIDE O PAGINA SI NAVIGAM IN URMATOARE FOLDERE /HBpersistence/normal IAR ACOLO O SA FIE FISIERUL "generalPersistencyData_DiagnosticSWTControlle r" PE CARE IL DESCARCAM PE CALCULATOR.
6)SE POATE DECONECTA MASINA
7)DESCARCAM PROGRAMUL HXD : http://mh-nexus.de/downloads/HxDSetupEN.zip
8)DUPA INSTALARE DESCHIDEM PROGRAMUL SI DESCHIDEM FISIERU SALVAT "generalPersistencyData_DiagnosticSWTControlle r"
9)APOI APASATI CTRL-F PENTRU CAUTARE SI SETATI LA MOD `` heX `` SI CAUTATI 01 01 00 1B ( STERGETI TOT CE APARE INAINTE DE 01 01 00 1B ) IAR APOI DUPA CE S-A STERS O SA MERGETI LA LINIA 130 (LA LINIA 130 SE STERGE DOAR ULTIMA COLOANA SI TOT PANA JOS(DECI LA LINIA 130 RAMAN TOATE DATELE AFARA DE ULTIMU RAND )
10)SE SALVEAZA FISIERU NUME.HEX SI TREBUIE SA FIE 319 BYTES FIX
11)INTRA PE http://codebeautify.org/binary-string-converter ACOLO ADAUGAM FISIERU SALVAT NUME.HEX SI SE DECODEAZA
12)REZULTATU DECODATULUI IL COPIEZ COPY-PASTE IN NOTEPAD SI SALVAT NUME.FSC ( SA NU FIE TXT )
13)DUPA CE AM REUSIT SA AJUNGEM LA FISIERU NUME .FSC AVEM NEVOIE DE GENERATOE DE FSC PE CARE IL DESCARCAM https://mega.nz/#!NlUkhDQb!vxbDWXcPLfCAwsMw1McOWz93VgYB3Z4rX6H8waLOGFM
14)SE DESPACHETEAZA PROGRAMUL DESCHIDEM FSC GENERATOR SI INTRODUCEM NUME.FSC SELECTAM HARTA 2016-2 SI GENERARE ( ESTE OPTIUNEA SI PENTRU COD LIFETIME DACA BIFAM )
ps : daca cumva cere login si parola la pasul 4 (username : root ,parola :Hm83stN sau cic0803
Sper sa va fie de folos . Am sa revin si cu poze sau un tutorial video
eu personal din sursa asta m-am luat : http://www.e90post.com/forums/showthread.php?t=1154524
Edited by patrutalex
  • Replies 118
  • Views 45.3k
daca nu va functioneaza user si pass folositi acestea
user: files
pass: remote.
testat pe e60 cu ultimul firmwire pe CIC.
Edited by hateganradu
cine din bucuresti ma ajuta si pe mine cu un cablu enet?
eu am sarit peste pasul 11. merge direct sa importi fisierul hex.
gasesti cablu pe olx bucuresti la 100 lei
E mult mai simplu cu swid reader si fsc generator.
eu nu am linia(offset) 130 in fisier. sa fie de la faptul ca am bagat acum ceva timp cod FSC lifetime?
trimite mie te rog pe e-mail fisieru si ti`l fac eu , ai pm cu mail
@patrutalex
Multumesc mult pentru intentie. Am reusit la E84. A mers snur treaba. Si am sarit pasul 11 din tutorialul tau. La F10 problema probabil este faptul ca deja avea introdus un cod lifetime. O sa iti trimit si fisierul pe mail.
@patrutalex
la mine a aparut , ti-am trimis
uite ca ai linia 130 . ti`am trimis pe mail totul facut
62G25VJF34I24ABIAD7Q life time
T5EPAAMEVV4BOABIAAGA single code :D
:D asta ii codu tau
Am reusit si eu, multumim!
Cine are nevoie de ajutor , sa imi trimita pm ca ii ajut !
PENTRU CEI CU MODELE NOI EXISTA SOLUTIE USOARA CU PROGRAMU : http://www.bmwai.com/download/bmwaicoder4.4.zip ( off antivurs si tot ca il vede ca virus ) si connect cu cablu enet si la options get fsc code
testat personal pe toate masinile f30,f01,f10
cine are nevoie de ajutor ii astept in privat , pot intra la ei in calculator.
Salut!
Ce face mai exact aceasta decodare/codare? Eu am un e60 cu navi business, poti sa deblochez ceva sau sa adaug optiuni ?
Multumesc!
De unde iau hartile up to date? Spune-mi te rog si daca exista un procedeu special de scriere al dvd-ului.
Verbatim 2x cu img burn ( le poti descarca de pe gpsunderground . Com )
Salut!
http://share-links.biz/_8gyrwvnjgok8
testat si merge , descarci fiecare pe rand apoi despachetezi se formeaza imagine si o scrii .
  • 3 months later...
Sa mor daca inteleg ce inseamna "se sterge doar ultima coloana si tot pana jos". Fisierul mai are o multime de info pana jos... Stergerea eu o pot face doar pe linie, nu si pe coloana...imi scapa ceva?
