ISTA-D 4.06.22 Standalone / ISTA-P 3.62.1.003
  • Popular Post
In Torrent o sa aveti tot pachetul ISTA-D (diagnoza/programare), ISTA-P (programare) si bazele de date aferente. DOWNLOAD
Pentru a instala doar ISTA-D trebuie sa bifati din Torrent: ISTA-D , SQLiteDBs si Tools (Pentru cine are ICOM si vrea sa faca si programare cu ISTA-D poate sa bifeze si SDP care se dezarhiveaza si se copiaza in folderul PSdZ din ISTA-D)
Pentru a instala ISTA-P aveti ghidul in folderul Tools - FAQ-EN.pdf iar pentru ISTA-D trebuie doar sa urmati ghidul de mai jos.
Installation:
1. Install .Net Framework 4.5.2 version and up, from Microsoft or Tools folder.
2. Install Java.
3. Download and install the Microsoft Visual C++ 2010/2013 Redistributable Package x86/x64 from Microsoft for your language in Windows.
*** for computer x86:
- vs90_piaredist
- vcredist_x86_2005
- vcredist_x86_2008
- vcredist_x86_2010
- vcredist_x86_2012
- vcredist_x86_2013
- vcredist_x86_2015
*** for computer x64:
- vs90_piaredist
- vcredist_x64_2005
- vcredist_x64_2008
- vcredist_x64_2010
- vcredist_x64_2012
- vcredist_x64_2013
- vcredist_x64_2015
If the system is x64, vcredist must install x86 and x64, otherwise not start Rheingold.
4. Install Ediabas 7.3
5. Unblock archive if necessary. It is important to not skip this step! Unblock file, uncheck Attributes - Read-only. Then unzip.
6. Unzip to any directory, for example: C:\Rheingold, D:\Rheingold, E:\Rheingold..., C:\Program Files\, C:\Program Files (x86) - this folder for 64bit computers. You can run from USB stick too.
7. Unzip and copy SQLiteDBs in Rheingold\SQLiteDBs\
8. Add additional languages if necessary in SQLiteDBs
9. Start RCleaner. Run as administrator.
10. Apply ISTA-D and SQLiteDBs Reg Fix bit for your system from the Tools folder.
11. Start Rheingold (...\Rheingold\TesterGUI\bin\Release\ISTAGUI.exe) Run as administrator.
12. Enter the license key from the license.txt, if ask.
13. Enter 1 in the field of ISIS, ignore the error.
Edited by OPaul
  • Replies 424
  • Views 245.4k
  • ISTA v4.06.31 - DOWNLOAD   Pentru cine are versiunea precedenta 4.06.22 , doar trebuie sa il dezarhiveze cu 7zip. si sa mute baza de date in versiunea noua.
  • ĂncearcĂŁ și vei afla. Sunt alte threaduri cu versiuni mai noi, cautĂŁ.
  • Daca am intrebat..inseamna ca am incercat ! O sa caut ..esti un dragut, multumesc !
http://i65.tinypic.com/dmtgjq.jpg
sa speram ca e bug-free ..e probabil ultimul release de ista/p
Merci OPaul pt link. Am istalat fara probeme ISTA+ pe Win 10 64bit .
Pot coda cu interfata K-DCAN si ISTA+ (si PSdZ instalat), sau cu ISTA/P si K-DCAN ?
Am si eu urmatoarea problema:
Am facut tot ce scrie mai sus insa cand ma duc pe INSTAGUI.exe si ii dau rulare nu porneste nimic...? trebuie sa am neaparat cablu bagat? sau ce am gresit?
Am dat unblock la cele 3 arhive si am pus doar Read-only..dupa care am dezarhivat..
Multumesc
Multumesc
Salut, ai rezolvat? si eu am fix aceeasi problema pe W 8.1 x64.
Click dreapta cu run administrator
Am incercat, tot asa nu merge. Mersi oricum.
Salutari !
Eu am instalat in momentul de fata ``Rheingold ISTA-D 4.01.21``, ca sa mi instalez varianta aceasta ISTA-D 4.06.22 Standalone...trebuie sa l dezinstalez pe cel vechi...sau pur si simplu as putea inlocui foldere peste cel vechi ?!
Multumesc anticipat.
Edited by Luc89
Ce vrei sa faci ?
Salutari !
This post has been edited by Luc89: Today, 12:24
Trebuie sters cel vechi, aplicat regcleaner 4.4, dezarhivat cel nou..rulate patchurile de registrii si cam aia e..scrie intr-un pdf in folderul tools
Edited by derutatu
Ai instalat TOATE lucrurile din primul post ?
Da,tot ce scrie in instructiuni. Am incercat de vreo cateva ori si ma gandeam ca de vina e sistemul de operare.
nope..merge cam pe orice ..teoretic ratezi ceva din pasi
Ok, o sa reiau toti pasii astazi cand ajung acasa. Mersi de info.
Nu pot sa ma uit acum, dar sunt 70% sigur ca scrie in pdf-ul din folderul Tools. Daca gresesc, incearca http://blog.obdii365.com/2015/07/13/how-to-setup-bmw-icom-rheingold-on-inpa-kd-can-cable/ .
Am verificat exact setarile din link, asa sunt si la mine.
Multumesc frumos pentru ajutor, e clar, CABLUL E FAKE
Am mai cumparat un cablu ,astept sa vina ala
No problem. De curiozitate, pentru ce masina ?
Am luat cablul pt 3 :
Mini Cooper 2002
E90 nfl 2005
E90 lci 2009
de asemenea..antivirus si firewall off
Am rezolvat problema, mi-am pus Windows 10 si acum merge. Fix aceeasi pasi i-am facut.
Teoretic trebuie sa mearga pe orice Windows. Anyway, bine ca merge :D
Ce vrei sa faci ?
Sa actvez citire indicatoare În România Speed Limit Info SLI 1 (100% la specificatiile din fabrica)
KAFAS 3030 IMPLICIT_SPEED_LIMITS_1 NAME_1 = 52,4F
KAFAS 3010 SLI_CODING COD_ELECTRICAL_HORIZON = aktiv
