F30 N47 eroare Drivetrain
Va salut, de cateva zile intampin o problema cu masina. Mi-a aparut de cateva ori in navigatie Drivetrain malfunction, masina nu mai accelereaza bine si parca are consumul mai mare. Am facut o scanare cu ISTA si a ramas stocata eroarea 297800 - "Charging pressure actuator: electrically or mechanically faulty, or excess temperature".
La un test facut tot cu ISTA actuatorul de la turbo se misca normal, vizibil face cursa asa cum trebuie.
Orice sfat e binevenit. Multumesc!
Nu stiu cat te ajuta dar uite ce am gasit cu Google dupa ce am scris fix ce ai pus tu cu bold si cu BMW in fata si dupa am raspuns ca e vorba de N47 ca motor.
For the BMW N47 diesel engine, fault code 297800 points directly to the electric Variable Nozzle Turbine (VNT) actuator mounted on your turbocharger. Unlike gasoline BMWs that use simple wastegates, the N47 relies on this electronic actuator to constantly manipulate internal turbo vanes to control boost. [1, 2]
Specific N47 Failure Points
  • Stuck VNT Vanes (Very Common): Diesel soot and carbon build up inside the exhaust side of the turbocharger. This causes the internal vanes to jam or bind. When the actuator tries to force them to move, its electric motor draws too much current and overheats, triggering the "excess temperature" or mechanical fault. [1, 2, 3]
  • Actuator Internal Gear Strip: The actuator houses delicate plastic gears driven by a small electric motor. Over time, or due to fighting stiff vanes, these gears strip out, resulting in an electrical/mechanical discrepancy error. [1]
  • Exhaust Heat Damage: Because the N47 actuator sits directly next to the hot exhaust manifold, thermal cycling can compromise the actuator’s internal circuit board or warp its connector pins. [1, 2]
Step-by-Step N47 Diagnosis
  1. Perform the "Free Movement" Test
    • Locate the electronic actuator on the side of the turbocharger.
    • Carefully remove the small retaining spring clip holding the actuator linkage arm to the turbo lever (Be careful, it is prone to flying off and getting lost).
    • Manually move the metal lever on the turbocharger by hand.
    • The Verdict: It must feel completely loose, moving effortlessly from stop to stop with zero tight spots or sticking. If it binds or catches, your VNT vanes are carbon-fouled and the turbo requires cleaning or replacement. [1, 2, 3]
  2. Inspect the Wiring Harness
    • Disconnect the multi-pin plug from the actuator.
    • Inspect the harness for oil contamination, brittle plastic, or backed-out pins. [1]
  3. Run an Actuator Test via Software
    • Hook up a diagnostic scan tool like ISTA or Bimmerlink.
    • Run the component activation test for the charging pressure actuator. Watch the arm to see if it makes a smooth, full sweep or if it chatters, hesitates, or fails to complete its range. [1, 2, 3, 4]
Repair Paths
  • If the turbo lever moves perfectly but the actuator stalls or fails the software sweep, the electronic actuator is dead. You can send it to specialty rebuilders like ECU Testing to repair the internal electronics/gears. Note that blindly swapping it with a random used actuator can cause issues because they are factory-calibrated to the individual turbo. [, 2, 3, 4]
  • If the lever binds or is physically locked up, the turbocharger itself needs to be removed and disassembled to clean the carbon out of the VNT mechanism, or replaced entirely. [1, 2]
