bmw e39
http://www.carsoft.ru/avtorepair/bmw_e34/6450.0/index.html
sau :blink: post-7162-1192137233_thumb.jpg
A2019 DDE control unit
Plug connector overview
Number X-pin, colour Description
X2019 55-pin, Black Plug connector DDE control unit
Pin assignments at plug connector X2019
Pin Type Description / Signal type Connection /
Measuring notes
1 E Signal Signal, fuel quantity control unit Injection pump
2 E Signal, fuel quantity control unit Injection pump
3 E Signal Electrical cutout Electrical cutout
4 E Signal Warning lamp preheating/error signal Light module Instrument cluster
5 A Needle movement sensor (injection time) SD nozzle
6 E Pressure converter AGR Changeover valve for exhaust gas recirculation (AGR)
7 Not used
8 E Preheater time control Glow plug relay
9 E Engine mount damping control Electrical changeover valve, engine mount
10 E Injection timing control Timed valve
11 A Ready indication signal, driving speed Instrument cluster
12 E Ground Needle movement sensor (injection time) SD nozzle
13 E Sensor ground Ground connector
14 E Centre pick-off control path sensor Injection pump
15 E Activation DDE relay DDE relay
16 E Voltage supply, terminal 30 for throttle actuator Fuse carrier, engine electronics Fuse F1 DDE
17 E Voltage supply, terminal 30 for throttle actuator Fuse carrier, engine electronics Fuse F1 DDE
18 E Ground Ground connector
19 E Ground Ground connector
20 Not used
21 A Reference coil control path sensor Injection pump
22 A Not used
23 A A/C compressor signal Heating and A/C control module
24 E Signal, A/C compressor relay Heating and A/C control module
25 A Idle switch Pedal position sensor
26 E Brake light signal Brake light switch
27 Not used
28 A Clutch signal Clutch switch
29 E Speed signal Connector for rear right wheel speed
30 Not used
31 A Brake light test signal Brake light switch
32 E/A FGR data link Multifunction steering wheel control unit
33 A Supply Pedal position sensor
34 A Supply Hot-film air mass meter
35 A Fuel temperature Injection pump
36 A Oil temperature signal Oil temperature sensor
37 E Signal Pedal position sensor Pedal position sensor
38 E Signal, hot film air mass meter Hot-film air mass meter
39 A Measurement coil, control path sensor Injection pump
40 E/A CAN bus low CAN bus low
41 E Error signal, glow plug relay Glow plug relay
42 E/A Communication link diagnosis TXD Connector TXD
43 E/A CAN bus high CAN bus high
44 E Switching signal A/C standby Heating and A/C control module
45 E Antitheft alarm system signal (EWS) Electronic immobilizer control unit (EWS)
46 E Presupply pump relay Fuel pump relay 1
47 A Speed signal Speed (rpm) sensor
48 Not used
49 A Signal Fuel consumption indicator Integrated electronic control unit (IKE) Instrument cluster
50 A TD signal (engine speed) Integrated electronic control unit (IKE) Instrument cluster
51 A Supply for boost pressure sensor Boost pressure sensor
52 Not used
53 A Coolant temperature Dual temperature sensor
54 E Signal Boost pressure sensor Boost pressure sensor
55 E Terminal 15 Fuse F14
