BMW 320 E90
Ar fi constructiv sa spuna si cum.. Dennnys are dreptate. Sa zicem totusi ca au fost sarbatorile si poate omul n-a mai avut timp sa stea pe net.
SALUTARE !!
SCUZE CA NU AM RASPUNS PE FORUM - DAR AZI MI-AM REPARAT LAPTOPUL, AVEAM O GRAMADA DE SALVAT INCLUSIV RECOVER LA PASWORD :)
REFERITOR LA MASINA E CA DR**U. TOT ASA ESTE MASINA - ,, TREMURA LA PORNIRE CAND E RECE" IN MERS CAND O ACCELEREZI USOR INDIFERENT DE TREAPTA IN CARE TE AFLI SACADEAZA - SAU ZICI CA SE INEACA.
TREBUIA SA AJUNG LA BAVARIA - DAR PERSOANA CARE O CUNOSC DIN INTERIOR MI-A SPUS CA ELECTRICIANUL SEF NU ESTE PE ACOLO - SARBATORI BLA BLA BLA.
DEJA MA SATUR SI DE ASTIA, DAR CRED CA O SA AJUNG ZILELE ASTEA - O SA O LAS DE SEARA CA SA POATA ASTIA SA PUNA TESTERUL DIMINEATA PE EA SA VADA TREMURATUL, CA DACA SE MERGE CU MASINA 5 KM nu mai tremura asa rau, nu se simte.
UN PRIETEN MI-A RECOMANDAT SA SCHIMB DEBITMETRUL - PROBLEMA ESTE CA NU AM EROARE IN BORD - DAR IAR POVESTI.
IN CAZUL IN CARE ,,SPECIALISTII" DE LA BAVARIA NU REUSESC SA-I GASEASCA BUBA - O SA MA DUC UNDEVA PE LA FILARET - AM AUZIT CA E UN SERVICE BUN PE ACOLO,.
VA TIN LA CURENT - SI SCUZE CA NU AM RASPUNS - DAR SARBATORILE SI PROBLEMA CU LAPTOPUL - DREPT DOVADA VA SCRIU ASA DE TARZIU ( LA ACEASTA ORA )
MASINA ESTE IN SERVICE - E LASATA DE SEARA CA SA SE VADA MAINE LA PORNIRE PROBLEMA.
REVIN CU UN RASPUNS IN 48 ORE.
GATAAAAAAAAAAAA !!!!!!!!!! SA REZOLVAT -
MAINE RIDIC MASINA
PROBLEMA >>>> UN DEBITMETRU - CARE REGLEAZA MOTORINA
AM RASPUNS - CA SA NU MAI REPROSATI :) ;P ( unii dintre voi)
Edited by BogdanCristian
Conform asteptarilor deci, era debitmetrul. Bine ca ai rezolvat! Drumuri bune si fara probleme in continuare!
SAl - dar nu debitmetru cel exterior (cel obisnuit) - este altul - legat de fluxul de motorina etc - maine intru in posesia hartiei oficiale si revin cu denumirea oficiala, se da admisia jos ca sa se poata schimba etc
SURPRIZA - AZI CAND AM PORNIT MASINA - FACEA LA FEL - DECI ASTIA DE LA BAVARIA AU SCHIMBAT ALA DEGEABA.
MA DUC IAR LA EI - FAC SI UN EMAIL CATRE GERMANIA
Tu chiar n-ai citit nimic despre Bavaria p-aici? :) Sunt praf oamenii..Nu stiu cum ai curaj sa mergi la ei.
Verifica si astea:RIBBED V-BELT 11287791786 (foto curele-curea mica)
RIBBED V-BELT 11287790450 (foto curele-curea mare) 134.00 lei
Vibration damper 11237805696 (foto 1 si 2- fulie motor vibrochen)
MECHANICAL BELT TENSIONER 11287790447 (foto 3,4 si 5
Deflection pulley D=70MM 11287790448 (foto 3,4 si 5
Din pacate nu pot sa mai upload-ez nici o fotografie.Siferenta intre am mea si a ta este:eu am cutie automata si tu manuala.Poza upload-ata etse Vibration damper.
Edited by adi v
Multumesc pentru sfaturi - cred ca o sa inebunesc cu chestia asta. mi-au bagat pe gat debitmetru ala de motorina si acum trebuie sa revin. Asta se numeste INSELACINE, am dat bani pe ceva care nu ma ajuta deloc, masina este la fel..
SA INTELEG CA TU AI AVUT ACEIASI PROBLEMA ???
CAND PORNEAI MASINA DUPA 12 - 24 ore - la prima cheie tremura timp de 5-10 minutte ??
AU FOST VERIFICATE - NU SA GASIT NIMIC.
AZI AU RESOFTAT SI CICA NU MAI FACE. ORICUM CRED CA O SA MA PREGATESC SI CU O RECLAMATIE.
IDEEA ESTE CA NU STIU CE ARE SAU CE A AVUT MASINA.
Ai rezolvat pana la urma problema? Daca da, ce i-ai facut? Foar resoftare??? Aceeasi problema o am si eu, aceeasi masina
  • 1 year later...
Ceea ce simtiti voi la masina este de la DPF - filtrul de particule, daca aveti masina dotata cu asa ceva, trebuie scoasa la drum intins si mers constant cu turatie mai ridicata. NU MAI DATI BANI PE PIESE DUPA URECHE.
Poi omul da daca zice macanicul nu? Sicncer nu cred ca schimba piese dupèa ureche o fi dat ceva eroare si la debitmetru ala, asteptam ... :popcorn:
