400 -
Posts posted by roninbz
am setata optiunea de inchidere automata a usilor dupa ce porneste si nu functioneaza. a mers doar de cateva ori, rar.
care poate fi cauza ?
vopseste-le cu spray pt tamburi, etriere...
Toate plansele de bord la e46 sint la fel nu conteaza motorizarea sau caroseria
Multumim !
as fi interesat eu.am un e46 coupe,dar nu stiu cum se demonteaza
sa vedem daca ti se potriveste. ce motor ai?
Car Access System (CAS) in Comfort start with immobilizer function
The following functions are grouped in the Car Access System (CAS):
· Terminal control
· Comfort start with electronic car immobilization system
· Remote control
· Central control of the central locking system
· Central control of the power windows
· Gateway module for K-CAN
Terminal control
Terminal R and 15 as well as the cable for activation of the data bus PT-CAN (wake-up line, terminal 15 WUP) are controlled in the CAS.
· When the remote control is inserted in the ignition lock, the CAS transmits the information (terminal R On) via the data buses K-CAN SYSTEM and K-CAN PERIPHERIE. Control units that are active as of terminal R (e.g. wiper module) are thus activated. There is no separate cable for terminal R.
· When the remote control is inserted in the ignition lock and then the start-stop button is pressed, terminal 15 is switched on. The CAS forwards this information across the data buses to the control units. In addition, CAS has four terminal 15 outputs to which control units or release relays are connected.
· When terminal 15 is switched on, the control units on the data bus PT-CAN are activates (woken up) across the cable terminal 15 WUP.
un schimb sau o cumpara cineva?
poate merge cu o reconectare a bateriei...
E vreo posibilitate atunci cand deblochezi usile sa se aprinda angel-eyesurile?
http://www.bimmer f e s t.com/forums/showthread.php?t=465564
cu ce soft se face codarea ?
vreau si eu un set.
sau negru, simplu.
Vand sau schimb plansa de bord gri cu una neagra
sunt replici? daca nu, le vreau eu.
Cumpar shadow line pentru E46 touring.
e topic de DONATII, nu de CERSETORIE !
Cum conduci un BMW diesel automat?
in BMW Autobahn
Posted
septronic merg si schimbate manual
