Vadim
Everything posted by Vadim
  1. MAI AM SI O MICA INTREBARE REFERITOR LA CC : AM SCOS CEASURILE DE LA BORD IAR PE SPATELE LOR AVEAU O ETICHETA PE CARE SCRIEA CEVA GENU E 32 ...... DECI CRED K CEASURILE SUNT DE E 32. INTREBARE: E POSIBIL K DIN ACEASTA CAUZA SA NU MEARGA SA SCHIMB LIMBA SI SA-SI FACA LCD TEST ????? P.S. MI-AM PUS OBC SI DIN CATE STIU EU CE SCRIE PE DISPLAY-UL DE LA OBC TREBUIE SA ARATE SI PE DISPLAY-ULDE LA CC , SI LA FEL NIMIK :blink: :)
  2. pai vezi si u care-i mai sus :)
  3. Merci mult!! franele abia le-am schimbat , la radiator cred k nu i au pus aia mufa cand l am schimbat , la peoiector am un bec ars , la vasul de la parbriz cred k e mufa si restu trebuie sa vad
  4. Am mai multe probleme la e34-ul meu si as vrea sa le rezolv , problema e ca nu prea stiu cum . Am manualul de la Haynes dar in ala nu prea gasesti nimik :blink: Pls help meeeeeeeeeeeeeee cine il are!!! P.S. sunt din Bucuresti
  5. PAI CE AR PUTEA AVEA????
  6. Pai eu am niste probleme cum ar fi :KUL WASSER STAND , ABBLEND LICHT , WASCH WASSER STAND , BREMS BELAGE , NEBELLICHT HINT , NEBLELICHT VORH .SI K SA LE VAD TRE SA STAU VRE UN MINUT K SA LE INSIRE EL PE TOATE , DECI IN CONLUZIE BUTONUL E BULIT!!! :blink: :) :)
  7. http://www.bmwe34.net/e34main/upgrade/electrical_fan.htm . Iti zice aici ce trebuie sa faci k as-ti pui electroventilator in loc de vascocupla Succes
  8. PAI NU PE ALA DE LA KM L-AM APASAT CI ALA DIN DREAPTA K MI-AM DAT SEAMA K A GRESIT , SI NU MERGE :blink: :) :)
  9. AM DEJA FARURI CU LUPA MARE :blink: DAR ORICUM MERCI PENTRU SFAT
  10. AHA MERCI MULT. CRED K LA DEZMEMBRARI CAPOTA NU POATE SA FIE MAI MULT DE 5 MILIOANE :blink:
  11. Cam cat ar cost un face lif la e34 , stie careva???????
  12. am tinut un min si nimic :) dar oricum merci de ajutor
  13. Ms mult , asta era e ars ala :blink:
  14. Aha ms mult de tot o sa caut ala cat mai curand :blink:
  15. Ms dar la mine buba e k nu mere :blink: :) :) cand apas pe butonul din dreapta nici o modificare ori cat as tine(cu contactul pus in pozitia 1) si mai e chestia k daca il tii apasat cand pui contactul ar trebui sa-si faca lcd-ul si celelalte ceasuri testul si la fel nimik :D
  16. Ms mult !! dar din pacate nu am obc :blink: P.S. stii cumva cam cat ar costa unu la dezmembrari ???? ca am inteles k se poate pune si nu trebuie sa mai tragi fire
  17. La mine sta ca in poza :blink: :) :) Si ma enerveaza foarte tare !!!, am sa-i caut si chestia aia neagra sa o pun
  18. Salut!!! Imi poate spune si mie dc nu merge sa schimb limba la computer????? :blink: Ms
  19. Problema cu incalzitul o am si eu de ceva timp.Am fost cu ea la service si aia au zis k ar fi radiatorul prea mic asa ca l-am achimbat cu unul nou dar nu se vede aproape nici o diferenta :blink: tot la prima liniuta dupa jumatate sta acul . E posibil sa se incalzeasca pt ca u am chestia aia neagra de pe radiator care vine pana-n elice???? Help meeeeeeeee!!!!!!!!! P.S. am un e 34 Motor M50
