Hila
Everything posted by Hila
  1. Concurentii lor directi fac asta cu motorul pe masina, eram curios si eu de cum fac asta mai ales ca vreau si eu sa fac distributia preventiv .
  2. Bun ma duc si ce le zic , ce trebuie sa cer de acolo, cum adica nu am TVA de plata ? Mai precis ce certificat sau ce cer? Multumesc
  3. Unde ai facut operatia ? Pe privat daca se poate ? E mai ok cu motorul scos sau cu el pe masina ?
  4. Ce certificat Anaf ? Pe persoana juridica ce mai trebuie in plus?
  5. E61 lci navi bussines are optiunea butonului Eject blocata , am sa va citez un paragraf gasit pe forum din afara The optional extra ?anti-theft protection navigation DVD? enables a DVD lock of the navigation DVD for corporate customers. The corporate customer vehicles are delivered ex works with this optional extra. Vehicles can also be upgraded by means of the Progman and then adjusted with this service function. New vehicles are delivered with the following default settings: DVD lock always active: the eject button is disabled. Up to model year 03/2006, vehicles were delivered with the following default settings: DVD lock with PIN query active. The default 4-digit PIN is XXXX. The 4-digit PIN is queried when the eject button is operated. When the PIN is entered, the navigation DVD is ejected. This service function can be used to read out or change the settings of the DVD lock. Activating or deactivating the DVD lock The DVD lock has the three possible states described below: DVD lock inactive: the navigation DVD is ejected when the eject button is operated. DVD lock with PIN query active: the set 4-digit PIN is queried when the eject button is operated. When the PIN is entered, the navigation DVD is ejected. This service function can be used to change the 4-digit PIN. DVD lock always active: the eject button is disabled. Cine e priceput la codarii si a intampinat problema asta sa mi spuna parametrul care trebuie activat si cu ce soft. In Focsani am fost in 2 locuri unde fac tot felul de activari la bmw insa baietii nu au intalnit un caz similar si nu stiu unde sa caute . Multumesc anticipat!
  6. Exact jezzy aia e prboblema . Inca nu am comandat , sa studiez sa vad ce poate face si decid dupa aceea. Mecanic imi bag nasul insa cu soft si alte chestii , mai greu:)
  7. Apare ori dupa ce o duci la spalatorie si baga aia aspiratorul pe sub scaun , eu am avut o sticla de apa intrata sub scaun si cand am scos sticla am tras si de firele de sub scaun. Mai poate fi si de la o cadere mica de curent , baterie slaba. Ai nevoie de tester bun, incearca sa o stergi si vezi dupa daca mai apare.
  8. De unde rasariti...voi astia noi proprietari de bolizi, pe bune !
  9. pt e61 520d lci navi business de unde iau un dvd cu harta ro? Pe topicul vechi nu misca nimic!
  10. Pachet lumini nu are, oglinda e ca cea din prima poza pusa de tine, ciudat e ca am legat firele si am controlat mergea perfect, la 2 zile a luat o razna. 3 fire la motoare si unul negru si maro care devin unul alb in spatele panoului de la usa pt dezaburire oglinda. Acum macar schimb din oglinda fara sa mai dau fata de usa jos. Hmm ii dau de cap pina la urma . Zi mi te rog de dvd pt navi vin e CX38999.
  11. Din aplicatie, am bagat datele si mi a dat wi fi adaptor insa asta merge pe Bluetooth sau cum cu telefonul? Ca la masina nu am wifi, nu prea inteleg:))
  12. Salut, am citit tot pina acum insa cum nu ma pricep vreau si eu niste informatii clare, mai pe romaneste ca la prosti:)) Cumpar Carly din itunes cea de 225 ron parca Comand cablul de pe site ( care cablu) Iphone 6 cu ultima varianta ios fara jailbreak 520, e 61 lci cu ccc Si merge cam orice sa fac (, erori sterse, parametri, codare simpla) Am din fabrica optiunea de dvd block adica butonul de eject de la navi e dezactivat, se poate activa cu carly? Multumesc
  13. Azi oglinda iar face figuri deai alaltaieri mergea perfect sus jos, stanga dreapta acum indiferent ce buton apas se duce spre dreapta sus. E posibil sa fi avut optiunea de coborare la mersul inapoi si fiind schimbata cu alta fara calculator sa o ia razna ? Cum aflu daca masina a venit cu optiunea asta ca dupa vin apar putine chestii pe diferite site-uri.
  14. De obicei de la perne, se controleaza cu apa si sapun , nu prea ai alte metode!
  15. Cosmin daca iti dau seria ma poti ajuta sa identific ce harta am nevoie la navigatia bussines area -code 2. E CCC si am cam pierdut sirul la navigatii si actualizari de la E60-ul vechi. Oricum a venit cu optiunea DVD Block si trb sa o anulez sa pot scoate dvd-ul din unitate
  16. De cand am luat o in 3 zile am rezolvat cele 3 mari prb: am rezolvat cu trapa panoramica si i am facut initializarea, avea un cd cazut in magazie si am desfacut magazia complet sa l scot, si asta cu oglinda. Mai trb o deblocare la navigatie ca are optiunea de dvd block si trb sa ajung la un tester poate fac si un update si ceva activari, gen sunet la inchidere deschidere.
  17. Gata am rezolvat fir intrerupt in usa de la pasager, se pare ca oglinda a fost schimbata si mufele erau diferite , unul din cabluri nu era ok legat. Astept sa vina frigul sa vad daca merge dezaburirea la ea )) Multumesc mult Cosmin! Sa stii ca de fel habar nu am cu aparat de masurat insa luat pe bajbaite tot o scot la capat. Cum spui si tu " just love my bmw"!
