WhySoSerious
Everything posted by WhySoSerious
  1. *diferential autoblocant e34 ,raport 3,23, carcasa(mica) tip 188 -600 ron VANDUT *planetare e34 m50b25 -100 ron buc *toba finala e34 m50b25 in stare buna -100 ron *radiator e34 m50b25 -200 ron *cheder usa dreapta e36 sedane stare foarte buna -50 ron *2 anvelope Riken Maystorm 2 B2 215/45R17 87W DOT 02.2012 rulate 3000km -400 ron VANDUT *amplificator Mac Audio MPX 2500 -170 ron VANDUT *baterie varta black 70ah in garantie(ian 2014) -200 ron Update preturi
  2. *diferential autoblocant e34 ,raport 3,23, carcasa(mica) tip 188 -600 ron *planetare e34 m50b25 -150 ron buc *toba finala e34 m50b25 in stare buna -150 ron *radiator e34 m50b25 -250 ron *cheder usa dreapta e36 sedane stare foarte buna -50 ron *2 anvelope Riken Maystorm 2 B2 215/45R17 87W DOT 02.2012 rulate 3000km -400 ron *amplificator Mac Audio MPX 2500 -170 ron *baterie varta black 70ah in garantie(ian 2014) -200 ron 0766.366.903 poze in scurt timp
  3. poze de azi http://www.imagehosting.ro/images/13520130330_173355.jpg http://i47.tinypic.com/2zptxra.jpg http://www.imagehosting.ro/images/38520130330_173407.jpg
  4. Rog un moderator sa mute topicul la sectiunea vanzari si sa modifice titlul. Jantele raman doar spre vanzare deoarece am achizitionat modelul dorit. 200 euro negociabil ,gume incluse.
  5. 3 ani m-am intrebat a cui e si daca e de vanzare masina asta .O vedeam zilnic in spatele facultatii de constructii ,folosita cam rar insa merita vazuta !
  6. 200 euro 0766.366.903 Se pot viziona vineri seara la intalnire
  7. http://postimage.org/image/f9ksr0h5z/ http://postimage.org/image/o5vkuy7s7/ http://postimage.org/image/t5t12wdev/ http://postimage.org/image/cw2v002qv/ 250 Euro roti complete 0766.366.903
  8. AC Schnitzer Type 1 Made in Germany 5x120 , 8j x 17" H2 , ET 35 http://i46.tinypic.com/2mrtkie.jpg schimb cu jante pe 17 ,latime 8/9/10 rh zw / rondell 0058 / brock b1 / borbet b / bbs rz / oz futura /Bbs Rt /style 5 / etc 0766.366.903
  9. Daca ai trecut-o la fisc in termen de 30 de zile pe numele tau nu te mai incurca nimeni.Vei putea sa primesti numerele pe care le doresti fara alte capcane/spagi/amenzi.
  10. Masina a fost vanduta < Topicul se poate inchide,multumesc pentru gazduire.
  11. Cum poti face asemenea afirmatii pe baza unor poze? Nu ai venit sa mergi cu masina sa vezi cat de ,,rupta e'' Sincer ,cred ca aveti prea mult timp liber.
  12. Cateva sute masina,cateva sute sa o faci sa mearga,cateva sute sa o aduci in Ro si cateva sute sa o inmatriculezi la BG....asa usor din taste. As dori ,daca se poate, sa se respecte regulamentul si sa discutam la obiect.
  13. Va rog ,fara oferte deplasate ca ale colegului de mai sus.
  14. Nu eu am facut regulamentul....doar 1mb pentru poze... http://www.autovit.ro/show?id=C23655361 sper sa nu fie considerat reclama.
  15. BMW E36 320i coupe -Culoare Maurituis blau metallic (287) -An fabricatie 11.1992 -Motor 2,0 24valve vanos M50B20 150CP -270.000km reali -suspensie sport KW impecabila -evacuare sport -geamuri electrice fata -inchidere centralizata -alarma originala bmw -clima manuala -obc 1 -cd player -volan M technik -covorase iarna noi originale -interior stock textil albastru curat -bara fata facelift -bara spate cu difuzor M technik -triple stock (nu mai sunt cele din poze) -roata rezerva noua tot aliaj ca pe masina -jante styling 13 cu anvelope iarna,spate noi 215.65.15, fata 60% 195.65.15 -masina este inmatriculata in bg pe nume de roman. -acte valabile(itp+asig) pana in 25 august 2012 + rovigneta Ro *defecte : %usa dreapta nu se deschide din afara %pe capota vopseaua sarita cca 3cm patrati %senzorul confort stanga la geam are mufa scoasa(iarna facea figuri si l-am deconectat) *o vand pentru ca mi-am cumparat alt coupe inmatriculat,deci nu accept schimburi. Pretul este mai mult decat corect si destul de fix.1399 EURO 0766.366.903 ym : razvansecu Poze mai mari pe ymes (forumul nu permite poze in format mai mare decat de pe site-uri externe)
  16. Ai cumparat o sonda de tip zirconia iar tu pe masina ai o sonda de tip titania. Pe scurt sonda pe care ai cumparat-o nu e buna ,functioneaza pe alt principiu,emite voltaj. Tu pe masina ai o sonda care primeste de la ecu 1v si isi modifica rezistenta ohmica in functie de amestec. Iti trebuie strict o sonda cu aceleasi culori pe fire. http://www.lambdapower.co.uk/images/techgraphs/sensor_cutaway.jpg http://www.lambdapower.co.uk/images/techgraphs/titania_cutaway.jpg Titania type 1 RED = heater +ve WHITE = heater -ve YELLOW = signal +ve BLACK = signal -ve Eu am facut treaba asta ,am legat o sonda zirconia in locul uneia titania adica ce vrei tu sa faci si nu a functionat.
  17. 1-Jante Aliaj 5x120 Originale Bmw M-Technik gume de iarna r16 7j mai multe poze cu fiecare roata in parte in curand. 5 buc (2 putin strambe-echilibrate din plumb) pret 250 euro 2-Jante Bmw 5x120 SHAPER r16 et 38 7,5j x16h2 nu sunt strambe ,nu sunt lovite ,nu au fost indreptate/sudate. 4 buc cauciucuri vara la limita legala pret 240 euro *Se schimba ambele seturi cu jante pe 17 cu latime 8.5 fata 10 spate. *Sau 1 set + diferenta. *Sau 1 set pe o suspensie sport drop min 80 cu 60-e36 fara TA Technix-raceland de preferat. Sunt interesat de: rondell,rh,brock,azev,borbet a,etc cu ET 20-35 ym : razvansecu 0766.366.903
  18. Ai zis ca consuma normal ,nu s-a marit ...in acest caz sonda lambda nu are nimic,alta este problema.
  19. Daca sonda lambda e moarta complet ralantiul nu iti oscileaza.
  20. -bujii -18x6= 110 ron -furtune aer -15 ron metru -furtune benzina -15 ron metru -furtun recirculare gaze -15 ron metru -filtru benzina -50 ron -filtru ulei -27 ron -ulei -160 ron(castrol 10w40 -6litri) -senzor temperatura ecu (ect) -50 ron -sonda lambda -de la 50 ron sh la 550 ron noua si am verificat: -debitmetru -injectoare -regulator ralanti +ceva maruntisuri : coliere ,wd40 pentru curatat ,oringuri... +scule ,ajutor de la prieteni si degete julite. Urmeaza sa trec la articulatie :bounce: si apoi :roadrage:
  21. Am schimbat : -bujii -furtune aer -furtune benzina -furtun recirculare gaze -filtru benzina -filtru ulei -ulei -senzor temperatura ecu (ect) -sonda lambda si am verificat: -debitmetru -injectoare -regulator ralanti Se pare ca si-a revenit.Urmeaza un tester.
  22. Din ce am gasit sunt 2 tipuri diferite deci nu sunt interschimbabile... http://www.lambdapower.co.uk/images/techgraphs/sensor_cutaway.jpg http://www.lambdapower.co.uk/images/techgraphs/titania_cutaway.jpg
