CD player-ul a fost montat pe masina mea, functioneaza foarte bine FEATURES Tuner Memory Presets: Preset Stations (FM:18 / MW:6 / LW:6) Memory: Auto Memory Seek Mode: Local / DX Selection RDS RDS Functions: TA, TP, RADIO TEXT Bluetooth® Built-In or Ready: Built-In Parrot Bluetooth® module Hands Free: Hands Free Calling Phone Book: Phone Book Transfer Microphone: Microphone Included Connection for iPod® Connection Type: Full Speed™ Connection Connection: Full Speed™ Cable (Required KCE-433iV) Source Type: Dedicated iPod® Source Works with iPhone: Works with iPhone M.I.X. (Shuffle) Capability: Song, Albums, All Music Control: Song Up / Down / Repeat Available Selections: Playlist, Artist, Album, Song, Podcast, Genre, Composer, Audiobook Percentage Search: Percentage Search Information Display: Artist, Song, Album Easy Navigating: Quick Search Disc Player Disc Type: CD Player Disc Playback Type: CD/CD-R/CD-RW Music Playback: MP3/AAC/WMA Playback DAC: 1Bit DAC Zero data Mute: 0 Bit Mute Digital Servo: Digital Servo Sensor: Music Sensor Scan/Repeat Playback Control: Play/Pause/Forward/Backward M.I.X. Mode: One (Folder)/All (Random Play)/Random (CD Only) Easy Navigating: Quick Search USB Media Connection USB Connection: Front Panel Input Music Playback: MP3/AAC/WMA Playback Sound Tuning Subwoofer Level: Subwoofer Level Adjustment High Pass Filter: High Pass Filter Adjustment Bass Level: Bass Level Adjustment Bass Center Frequency: Bass Center Frequency Adjustment Bass Width: Q Adjustment Treble Level: Treble Level Adjustment Treble Center Frequency: Treble Center Frequency Adjustment Loudness: Loudness Feature General Power Output: 4 x 50 W High Power Amplifier Display: White LCD (14 Segment) Control Type: Rotary Encoder Knob Face Color: Black Illumination Buttons: Green / Amber / Blue / Red Illuminated Buttons PreOut: 2 PreOuts (2 V ) AUX-In: Front AUX Input (3.5mm mini jack) / Full Speed AUX + (Required KCE-237B) Steering Wheel Remote Control: Steering Wheel Remote Control Ready Bass & Treble: Bass & Treble Controls Fader & Balance: Fader & Balance Controls DIN Trim Plate: Detachable Trim Plate Detachable Face Plate: Detachable Face Plate Dimmer: Dimmer Input Power Antenna Lead: Power Antenna Output Remote Turn-On: Amplifier Remote Turn-On Output Audio Interrupt: Audio Interrupt Input SPECIFICATIONS Max Power Output Ratings Max Power Output: 4 x 50 W FM Tuner Tuning Range: 87.5-108.0 MHz Mono Usable Sensitivity: 0.7 µV Alternate Channel Selectivity: 80.0 dB Signal-to-Noise (S/N) Ratio: 65.0 dB Stereo Separation: 35.0 dB Capture Ratio: 2.0 dB MW Tuner Tuning Range: 531-1,602 kHz Usable Sensitivity (IEC Standard): 25.1/28.0 (µV/dB) Bluetooth® Bluetooth® Version: Bluetooh 2.0 CERTIFIED Output Power: +4 dBm Max. (Power class 2) HFP: (Hands-Free Profile) HSP: (Head Set Profile) Connection for USB USB Requirements: 1.1/2.0 Max. Power Consumption: 500 mA USB Class: Mass Storage File System: FAT 12/16/32 MP3 Decoding: MPEG-1/2 AUDIO Layer-3 WMA Decoding: Windows Media™ Audio AAC Decoding: ACC-LC format/m4a file Number of Channels: 2-Channel (Stereo) Frequency Response: 5-20 k ±1 dB (Frequency Response may differ depending on the encoder software/bit rate) Total Harmonic Distortion: 0.008% (at 1 kHz) Dynamic Range: 95 dB (at 1 kHz) Signal-to-Noise Ratio: 105 dB Channel Separation: 85 dB (at 1 kHz) Disc Player Frequency Response: 5-20 k ±1 dB Channel Separation (1kHz): 85dB Dynamic Range (1kHz): 95 dB Total Harmonic Distortion (THD): 0.008% (at 1 kHz) DAC Type: 1 Bit Wow & Flutter (%WRMS): B.M.L. Oversampling: 8x/352.8 kHz Audio Signal-to-Noise (S/N): 105 dB Sound Tuning Subwoofer Level Adjustment: 0 to 15 High Pass Filter: OFF/60/80/100Hz (Selectable) Bass Level Control Range: ±14 Bass Center Frequency: 60/80/100/200Hz (Selectable) Bass Band Width Adjustment (Q): 4 choices (1 =narrow, 4 =wide) Treble Level Control Range: ±14 Treble Center Frequency: 10/12.5/15/17.5kHz (Selectable) Dimensions Din Size: 1 Chassis Size (W x H x D) mm: 178 mm x 50 mm x 161 mm Nose Piece Size (W x H x D) mm: 170 mm x 46 mm x 25 mm General Power Requirement: 14.4 (11-16) V.DC Pre Output Voltage (Before Clipping): 2 V Operating Temperature (°C): 60°C to -10°C Maximum Mounting Angle: 35° from Horizontal Weight: 1.5 kg Recommended Accessories KCE-433iV: 2 METER CONNECTION CABLE for iPod® KCE-USB3: 2 METER USB EXTENSION CABLE KCE-237B: Fullspeed to mini jack adapter KTP-445: HEAD UNIT POWER PACK
